Staro 11.10.2007., 15:17   #1
Wayfaerer
Wayfaerer's Avatar
Postovi: 31
ASUS ili Sapphire HD2900XT
Ok moze mi neko rec sta je bolje izmedju ove dvije kartice:
VGA ASUS EAH2900XT/HTVDI/512M, ATI Radeon HD2900XT PCI-Ex16, 512MB DDR3 512-bit DDR, VIVO, HDTV, HDCP, 2xDVI-I, TV-out, engine clock 740MHz, memory clock 1.65GHz, RAMDAC 400MHz, max resolution 2560x1600
3,157 kn
ili
VGA SAPPHIRE HD 2900XT,512M DDR3,VIVO,2DVI,PCI-E 2.627 kn
i zas je tolika razlika u cijeni?
Hvala!
Wayfaerer je offline   Reply With Quote
Staro 11.10.2007., 15:55   #2
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Uzmi Sapphire.
Ili onaj 2900 PRO model sa gigom meme ako ga još imaju za prodati (microline)
Staro 11.10.2007., 16:49   #3
atha
atha's Avatar
Postovi: 9,069
___________
Just atha
x
Staro 11.10.2007., 22:15   #4
Jelc
Super Moderators
Postovi: 17,485
Jap, giga meme se možda bude i vidjela u DX10 a GPU ide na taktove XT.
Staro 11.10.2007., 22:22   #5
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
uh kako je sexy grafa...jos ta crvena boja... a koliko je opce razlika u performansama izmedju pro i xt?
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
Staro 11.10.2007., 22:29   #6
nino
nino's Avatar
Postovi: 12,613
Cijene vani u € (1€=7,35kn), znaci po redu bez poreza:
1. 2113kn
2. 1453kn
3. 1758kn
Pa eto ko je blizu Italije , a ja mislim da cu do Trsta u shopping
Staro 11.10.2007., 22:50   #7
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Autor nino5 Pregled postova
1. 2113kn
2. 1453kn
3. 1758kn
a ima sto povoljnih procesora i hddova tamo? imas neki link?
Logitech MX500
DELL 2007FP
Abit AV8
Staro 11.10.2007., 23:40   #8
Mar
Suit up!
Mar's Avatar
Postovi: 5,977
Nino, ideš tamo? Moga bi mi nešto sredit
- Barney Stinson
Staro 12.10.2007., 00:46   #9
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Da da nino baš bi mogo (i meni )
žmnpp
Staro 12.10.2007., 01:24   #10
nino
nino's Avatar
Postovi: 12,613
Leshinari bi me u zatvor strpali, prvo je bog sebi bradu napravio
Staro 12.10.2007., 01:28   #11
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
...a onda i drugima...
Evo ti možeš svoju prvi u komp stavit
žmnpp
Staro 12.10.2007., 10:55   #12
Painkiller
Painkiller's Avatar
Postovi: 9
Autor Wayfaerer Pregled postova
3,157 kn
ili
Hvala!
Moja ti je preporuka da uzmes SAPPHIRE, a sto se tice cijene, jbg Asus je uvijek bio i bit ce skuplji od konkurencije...
Painkiller je offline   Reply With Quote
Staro 12.10.2007., 11:00   #13
Router
Hejter
Postovi: 6,521
Asus je inace skuplji sa grafickim , vole stavljati drugacija hladjenja ( ne znam jer i u konkretnom slucaju tako ili su oboje se ref. kulerima ) , a i asusice dolaze sa vrlo opseznim bundelom posebno u ovoj klasi grafickih , sigurno min. 10 diskova mozes uz nju ocekivati , zato mozda i toliko razlika , po meni neporavdana . I apsolutno se slazem , Sapphire , a ova razlika u cijeni je itekako dovoljna i za posteno hladjenje grafe ako pozelis , ili za nesto drugo ....
Router je online   Reply With Quote
Staro 12.10.2007., 14:49   #14
Imp
Postovi: 31
Autor Router Pregled postova
Imam ASUS-ovu i nema tih deset diskova, jednia razlika u bundlu koju sam skuzio je sta sam dobio stalkera. Inace manual je jako lose izveden, mogli su napravit manual posebno za ovu karticu a ne napravit neki generic manual koji vrijedi cak i za agp kartice - za tu cijenovnu razliku ocekujem barem ovakve stvari. Ja nisam neki iskusni hardweras i stvarno bi mi pomogla informacija da moram skopcat oba dva konektora za struju obavezno (jer na jedno mjestu pise nesto o crossfire-u ali to nakraju ispada da vrijedi za ono napajanje sa 4 pina) ustedilo bi mi prvih 10 min frustracije oko toga "sta sad ne radi"
Malo
Sto se tice kartice (2900xtx opcenito) preporucio bi ti da je zaobidjes.
1.) Ja sam bio uvijeren da mi buka graficke nece imat utijecaja u zivotu, ali kad ti cujes ovu turbinu, zaboravi da ces igrat igre poslje 10 navecer jer ces dobit prijavu za ometanje reda i mira . sala ali zbilja nema teoretske sanse da neko u sobi do zaspe jer se cak i kroz slusalice dok igras cujes zujanje !
2.) Preformanse su jakooo osjetljive na CPU koji imas u kompu. Ja imam PentiumD 930 (2x3ghz) i ddr2 600mhz niti jedan rezultat u igrama se ne poklapa sa internet testovima. Kaska i do 20-30 frejmova za tim "testovima" sa najnovijim drajverima i patchevima. S druge strane ubo sam od frenda 8800GTS i radi ~5-10 frejmova razlike od refrentnih testova
3.) Graficka je tolko vruca da sam je moro stavit na donji PCIe jer u gornjem mi je dizala NB (pasivno NB hladjenje) temperaturu za 20 stupnjeva a CPU za 10, komp se gasio i blokiro od pregrijavanja a imam big-typhoon na CPU sto mislim da je sasvim dovoljno !!! Mogo sam ubacit vent na NB ali to je jos troskova jos truda i buke. na donjem slotu mi je efektno zakrcila sva tri PCI porta i nema sanse da ukopcam nista PCI u komp, na frendovoj GTSci je radilo sve ok na gornjep PCIe-u temperatura se digla tek par stupnjeva.
4.) Niti jedna igra nije pokrenula kako treba sa bundle drajverima. Ovo se mozda cini smijesno, al kad doma nemas neta jako je zaje*ano. Napomenut cu da se i vecina bugova nije ispravila ni s novim drajverima, nego tek s novim patchevima za igru. Nvidia mi nikad nije stvarala ovakve probleme. Novi patchevi su uvijek donos ili bolje preformanse i feature, ali nikad nije bilo toliko bugova sa igrama (onaj "the way it's meant to be played" logo ipak znaci nesto) Bioshock, Oblivion, ET:QW demo, NVN2 ... sve su imale barem nekih problema pod vistom. Pod XP-om je malo bolje stanje ali bugova je bilo pregrst
Zbilja imam osjecaj da sam se zaje*o sa ovom karticom, ovo mi je prva ATI-graficka a vjerojatna i zadnja, i pun mi je pun k* obecanja o novim drajverima i patchevima za igre, za tako nesto sigurno nebi dao 3k kn.
Eto to ti je moje frustrirajuce iskustvo s grafickom, nezelim te obeshrabrit ni nista, ako znas sta kupujes - sretno, ali za slucaj da neznas (kao sto ja nisam znao) samo ti htio dat prijateljsko upozorenje da ne ostane i tebi "gorak okus u ustima" nakon kupnje.
Imp je offline   Reply With Quote
Staro 12.10.2007., 15:17   #15
Mar
Suit up!
Mar's Avatar
Postovi: 5,977
@Imp, softverski problemi koje navodiš itekako je Nvidia iskusila u prvim mjesecima života 8800 serije, svi proizvođači u zadnje vrijeme izbacuju harver puno prije nego što dovrše drivere za njega.
Što se tiče temperature i potrošnje - 2900XT je (tržišno) između 8800GTX-a i GTS-a zato pametne glavice čekaju HD2950 seriju , nikad nevalja ići glavom u zid pa kupiti prvo što se pojavi.
Ionako DX10 je mrtvo slovo na papiru, a Windows Vista kao OS je vic.
- Barney Stinson
Staro 12.10.2007., 15:37   #16
Imp
Postovi: 31
Autor Mar Pregled postova
Vjerojatno, ali nv nije vise u prvim mjesecima života niti više ima tih problema, a ATI ih ima, i to je ono šte je meni u realnosti bitno. Nadalje nema nikakve naznake koliko ce ATIju trebat da ispravi te bugove ... Sta ja trebam cekat jos jednu generaciju kartica da oni izdaju optimalne drajvere
[/quote]
Čemu onda i plasirat proizvod kao 2900xt ? U mom slucaju, ja sam imo lovu kod sebe i htio sam kupit komad hardwera koi ce mi osigurat bar sljedecih 2 godina igre. Nisam mogo cekat jer bi mi lova vjerojatno isparila na gluposti i kasnije bi tesko opet tolko para skupio. Ispalo je da i neke sadasnje igre poprilicno zezaju i sa zadnjim drajverima (colin dirt npr.), graficka se grije i trosi ko luda (to nijedni drajveri nece ispravit), a skuplja je od GTS-ice. Za high-end cijenu dobio polu-proizvod koi ce vec za manje od godinu dana bit od upitne vrijednosti, a da bi ga optimalno iskoristio moro bi ulozit jos 1k kn za novi proc i jos tolko za brze rame... Jos kad spomenem da sam moro i 500kn dat za novo napajanje... a GTS-ica je pod starim napajanjem sljakala kako treba, i cpu joj nije toliko smetao. jasno je zastoa se osjecam ko budala .
I nije da mi je sad stalo da pretjerano pljujem po grafickoj vjerojatno cu se uspjet mjenjat uz nadoplatu za neku gts/x-icu, ali ko sto i sam spominjes - netreba glavom u zid, radje da uzme testiranu i jeftiniju NV ili ceka tu novu verziju, ili zna nesto sta ja neznam pa uzme ovu ...
Kako god sretno sa izborom
Staro 12.10.2007., 16:02   #17
Painkiller
Painkiller's Avatar
Postovi: 9
tu bi se slozio s tobom, stvarno je Windows Vista u najmanju ruku presmijesan OS...
Staro 12.10.2007., 18:08   #18
nino
nino's Avatar
Postovi: 12,613
Kako stvari stoje, u utorak bi mogao pasti jedan mali review za hd2900pro 512 i hd2900pro 1gb, a ako ulovim Mortal-a, da mi posudi crossfire bridgeve mogao bi past i jedan testic u crossfire samo neznam dali ce moj Seasonic 430w to izdrzat, wolv?
Staro 13.10.2007., 02:41   #19
thedman
User Registered
thedman's Avatar
Lokacija: europe
Postovi: 229
je i ja sam vlasnik hd2900xt i isto tako savjetujem ikao sam fan od ati kartica
da je ako možeš zaobiđeš ili da barem pričekaš ovu najnoviju serije 2950
istina je da se jako zagrijavaju i da su dosta buče što nekad zna iritirat...........
thedman je offline   Reply With Quote
Staro 13.10.2007., 02:47   #20
nino
nino's Avatar
Postovi: 12,613
Cuj, zato dobijam po prihvatljivoj cijeni, valjda ce biti na trzistu nekog alternativnog hladjenja, barem je dosada bilo, ako je to u pitanju. Nego kako si zadovoljan performansama?
Staro 13.10.2007., 05:06   #21
thedman
User Registered
thedman's Avatar
Lokacija: europe
Postovi: 229
pa igre i sve ostalo oke nemam komentara
jedina zamjerka je glupi ventilator koji je užasno glasan ali istina pali se tak kada igra radi
nekad dok su stari drajveri bili palio se sam od sebe,a ja na netu-u!??!??!
bez obzira na sve još uvijek sam ati fan
Staro 13.10.2007., 09:53   #22
Wayfaerer
Wayfaerer's Avatar
Postovi: 31
Ljudi, kupio sam ovu sapphire, al ne znam dal moram staviti i 6 pinski i 8 pinski kabel za napajanje unutra ili samo jedan od njih. 8 pinski koji mi izlazi iz napajanja ima drugaciji oblik pinova pa mi ne zeli uci u slot.
Staro 13.10.2007., 09:57   #23
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,312
2 6pinska PCI-E upikni. Novija napajanja imaju i 8pinski PCI-E kojeg kartica treba za overclock preko drivera.
Ovaj 8 pinski kojeg si probao piknuti...je za ploču
Staro 13.10.2007., 09:58   #24
Wayfaerer
Wayfaerer's Avatar
Postovi: 31
2? ok budem probao, hvala
Staro 13.10.2007., 12:07   #25
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Autor Gilbert5 Pregled postova
Bilo mi je interesantno procitati da su ona dodatna dva voda izmedju 6-pinskog i 8-pinskog PCI-E zapravo samo dva GND-a. Jos jedan marketinski potez "ajmo kupit nova napajanja".
To sam procitao na nekom nedavnom testu od HD2900XT ili Pro kartice, navodno je to Sapphire potvrdio testerima.
Staro 15.10.2007., 10:35   #26
Wayfaerer
Wayfaerer's Avatar
Postovi: 31
Puno hvala na savjetima ljudi! Eo sad mi komp zgleda ovak!
E sad za buku: Mene to tolko i ne dira previse, mislim cuje se dosta ali nije tolko strasno, uspio sam zaspat ko beba dok mi se Half-Life 2 skido! XD
A kaj se tice zagrijavanja tu nisam neki expert ali imam kuciste od Nzxt[brijem da se tak zove]; btw. unutra su 3 venta od 120mm i mislim da se ne grije bas tolko a sad ne znam....
Mozda sam nes krivo spojio?
Mislim prvi put kad sam spajo grafu spojio sam ovaj 6-pinski + 2-pinski konektor u ovaj 6 pinski na grafi i upalio komp i drzo otvoreno kuciste u krilu! Nije bilo slike, crvena ledica mi se upalila na grafickoj i nije bilo slike ali se to culo ko da avion polijece! Shvatio sam da sam nes krivo slozio pa sam uzeo 6-pinski kabel koji sam dobio s grafickom i piknuo u prvi konektor umjesto ovog 6-pinskog+2-pinskog i taj 6 pinski u ovaj 8-pinski s tim da 2 pinski nisam spajo, kolko sam skuzio to je za OC pa sad..
Pokreto sam 3d mark i dobio 8300...:S
Meni se cini ko da je to malo.... al sad nisam neki strucnjak ne al mislim da mi score dost manji zbog proca [valjda?!]
Anyway u HL2 sam imo oko 70 FPS s tim da ko da nije htio ici preko toga al je mogo [ne znam ko da je ogranicen] i to je bilo na 1280x1024 8AA i 16AF brijem u principu sve na max
Jel zna netko jel to ok ili me nes koci jos a da se to moze popravit nekak...?
Staro 15.10.2007., 13:00   #27
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
Pa to je ok ja mislim jer ti je proc na 2.0 Ghz trebal bi ga malo dic barem na 3.0 Ghz
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 15.10.2007., 14:11   #28
Wayfaerer
Wayfaerer's Avatar
Postovi: 31
Hm da i ja bih ga htio dic al ne znam bas kak!
Malo sam svrljao po forumu i vidio da treba dizat napon proca [wtf?!] Mislim imam boxed procesor i sad ne znam jel trebam novi cooler ili tak nes...
Ima neko link jer ja nisam puno toga naso a ono kaj sam naso nisam bas shvatio prevec :S
Staro 15.10.2007., 14:17   #29
elvis again
In the ghetto
Postovi: 1,943
Znaci zakljucas voltazu proca na defoultu (za e4400 je ja mislim 1.325V) i onda dizes FSB dok ne dojdes na 3 GHz ak ti se vc prije proc nece dic znaci da je tu max. Imas po forumu zaljepljenih (sticky) postova o OC-u. Pa probaj cak i sa stock coolerom mozes ako je voltaza defoultna.
Staro 15.10.2007., 16:10   #30
Wayfaerer
Wayfaerer's Avatar
Postovi: 31
E hvala, mislim da cu prije neg kaj dizem ista promijeniti paste na procu, i chipsetima! Sam kaj ne znam kak da skinem pasivni cooler s maticne i kak da stavim ventilator na to ak se opce moze?
