Staro 09.10.2007., 22:48   #1
amerix
Lokacija: NY
Postovi: 505
MSN error login - 80072745
Evo nemogu se od danas logat na msn
Jučer sam mogo'
Evo šta sam pokušo ja ali ne radi
-Reinstal msn-a
-Port forwarding
-Ona fora sa registriyem (što obrišeš policy i shared)
-Isključio firewall
ima neko još prijedloga ?
amerix je offline   Reply With Quote
Staro 10.10.2007., 08:32   #2
piplica
Postovi: 4
bit ce ti malo smjesno ali pogledaj si datum i sat.
ja sam imao problem sa tim msn-om radi pogresnog datuma, i kad sam vratio na pravi datum problem je bio rjesen
piplica je offline   Reply With Quote
Staro 10.10.2007., 12:44   #3
amerix
Lokacija: NY
Postovi: 505
Autor piplica Pregled postova
datum i vrijeme su dobri
edit:http://www.imagesforme.com/viewer.ph...17untitled.JPG
i sad bi ja htio pobrisat ono što imam dodano od # Start of entries inserted by Spybot - Search & Destroy al nemogu ..tj. kaže mi acces denied
Zadnje izmijenjeno od: amerix. 10.10.2007. u 12:54.
Staro 10.10.2007., 13:00   #4
vinja
vinja's Avatar
Postovi: 789
ja sam imao isti problem... no ne mogu se sjetiti kako sam rjesio... al sve mi se cini tek nakon reinstalla windowsa :S
vinja je offline   Reply With Quote
Staro 10.10.2007., 13:30   #5
Thommy
Thommy's Avatar
Postovi: 469
> I can't login to windows live messenger and a error code 80072745 displayed,
> before that , tie said the name cannot be changed...how come ? Any one can
> help me? I got loss with all my friends....
Well I too had the same problem. I tried reinstalling Microsofts wonderful
software but to no avail. I tried flushing out the DNS cache but that didn't
work either. After several hours of soul searching and troubleshooting I
think I finally discovered what it might be. I went into my Netgear router
config and noticed that the DNS Address section had the 'Get Automatically
from ISP' so thinking of static routes I changed it to 'Use these' which then
uses the two IP addresses I had placed in there previously for the primary
and Secondary DNS.......I think its fair to say that if your ISP has a small
DNS pool then every now and then you'll use the same server and therefore the
80072745 error appears random.... Anyway try it...It worked for me withour
rebooting...... And besides, reading the inane responses you've received thus
far, what have you got to lose....
Any response that support or negates what I have found as a work around to
yet anthoer Mircosoft feature, would be warmly received.......
ili opsirnije na
http://www.microsoft.com/communities...e09d2b5c20&p=1
neki dan se isto nisam mogao spoiti na msn nesjecam se koji je error bio ali pomoglo je sljedece start-settings-control pannel-internet options-connections-lan settings i ako je ukljucena kvacica kraj use automatic configuration script iskljuci ju
Thommy je offline   Reply With Quote
Staro 10.10.2007., 23:31   #6
amerix
Lokacija: NY
Postovi: 505
Ček šta bi sad trebo?
postavit DNS servere ?
Staro 11.10.2007., 10:44   #7
amerix
Lokacija: NY
Postovi: 505
neznam ni šta ni kako ali sad radi
EDIT:Evo dodem iz skole upalim komp i opet mi ruka onaj error
Zadnje izmijenjeno od: amerix. 11.10.2007. u 20:45.
Staro 12.10.2007., 11:34   #8
amerix
Lokacija: NY
Postovi: 505
*bump*
probo sam i onaj error fix sa msgshit.net al ni to ne radi...
Staro 12.10.2007., 20:08   #9
domy_os
domy_os's Avatar
Postovi: 18,957
A je li rade neki drugi MSN klijenti (Miranda, Gaim, Trillian,...)?
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 12.10.2007., 21:17   #10
amerix
Lokacija: NY
Postovi: 505
Autor domy_os Pregled postova
hmmm...trilian mi ne radi a mirandu baš i nisam skužio...tj. vjerojatno ni ona ne radi...a web messenger radi
http://www.imagesforme.com/viewer.php?id=3166omg.JPG
edit:
http://www.imagesforme.com/viewer.ph...948weird=).jpg
jel bi ovo trebalo "biti dobro" ?
Zadnje izmijenjeno od: amerix. 12.10.2007. u 22:45.
Staro 13.10.2007., 20:07   #11
amerix
Lokacija: NY
Postovi: 505
...imo' sam instalirane windoze na drugom hardu i probo sam sad na njima ali ne radi...
jel moguće da se neko igro sa acc pa ga "zamrznio" ? 'akeri ovo ono
Staro 27.10.2007., 19:39   #12
amerix
Lokacija: NY
Postovi: 505
...uhm...
cini se da mi mali zeleni u kompu
evo ponovo sam instalirao windoze i NE RADI
