Staro 29.09.2007., 00:44   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
RivaTuner v2.05
Glantz novi
Od kad se vratio sa godišnjeg Unwinder malo-malo izbaci novu verziju...
Minor bugfixes:
- Fixed I2C write routine for ATI R600 graphics processors family, which has been erroneously commented the previous version's source code.
- Minor UI and localization fixes.
What's new:
- Updated databases for Detonator and ForceWare drivers. Added databases for ForceWare 163.69 and 163.71.
- Improved driver-level overclocking module for NVIDIA display adapters:
- Added new user interface for independent G8x GPU family shader clock control interfaces of the ForceWare 163.67 and newer drivers. New UI includes:
- New independent slider for adjusting shader domain clock.
- New "Link clocks" option allows you to use either traditional shader/ROP clock ratio based overclocking or completely asynchronous shader/ROP clock overclocking. Now you may either tick "Link clocks" options and adjust ROP clock only, allowing RivaTuner to overclock shader domain using VGA BIOS default shader/ROP clock ratio similar to pre-163.67 drivers, or untick "Link clocks" options and adjust domain clocks fully independently.
- New overclocking profile format supporting independent shader clocks. Please take a note that old overclocking profiles are not supported by RivaTuner, so you must recreate previously existing overclocking profiles.
- Previously available power user oriented ShaderClockRatio registry entry is now obsolete and it no longer exists in RivaTuner's database. Previously available ratio based shader domain overclocking functionality is now fully covered by new independent shader clock slider and new "Link clocks" option.
- New user interface is provided by default under ForceWare 163.67 and newer drivers under Windows Vista, however Windows XP owners can also force Vista specific overclocking interfaces usage by setting NVAPIUsageBehaviour to 1. If needed, shader clock control can be forcibly disabled and old traditional overclocking module UI appearance can be forced by setting NVAPIShaderClockControl to 0.
- Power user oriented adjustable minimum and maximum clock slider limits have been expanded from 25%-300% to 10%-800%.
- Added experimental SLI overclocking for Vista. Please take a note that I have no SLI rig for testing and development, so this feature has been added blindly and RivaTuner still doesn't provide official SLI support.
- Minor UI changes and improvements.
Obratite pažnju na "Added new user interface for independent G8x GPU family shader clock control interfaces of the ForceWare 163.67 and newer drivers. "
http://downloads.guru3d.com/download.php?det=163
Staro 29.09.2007., 01:57   #2
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Što bi reklo da se mogu taktovi shadera dignuti? Ima to kakve velike koristi/dobitka?
Matth€w je offline   Reply With Quote
Staro 29.09.2007., 02:05   #3
Jelc
Super Moderators
Postovi: 17,485
Autor Matth€w Pregled postova
Pa probaj kvragu
Da mi je neka Nevidia biže već bi ja probao...
Staro 29.09.2007., 02:15   #4
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Ma neću, pa da još nešto zafušam, to mi je novo područje, prustiti to prvo drugima
Btw. nisam ni mogo naći nigdje shader clock (imam FW 163.69), OC malo drukčije zgleda, ima neku rupu izmedju, prazno nešto, valjda bi to trebalo biti mjesto sa shader clock
Staro 29.09.2007., 02:47   #5
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,381
Pa sta ne vidis da pise da je to vista only fičr, da bi to radilo ne xp-u moras nes ukljucit u onim power user opcijama. Inace samo da znas shader clock ti se i inace dizao kad si klokao gpu, samo je sad napravljeno da se sve kloka odvojeno.
Slobodno me dodajte na PSN
Staro 29.09.2007., 12:04   #6
Jelc
Super Moderators
Postovi: 17,485
Je, možda si trebao pročitati ono iz prvog posta
"- New user interface is provided by default under ForceWare 163.67 and newer drivers under Windows Vista, however Windows XP owners can also force Vista specific overclocking interfaces usage by setting NVAPIUsageBehaviour to 1. If needed, shader clock control can be forcibly disabled and old traditional overclocking module UI appearance can be forced by setting NVAPIShaderClockControl to 0."
Staro 29.09.2007., 14:32   #7
dugixy1
Postovi: 577
nemaš se šta bojati ,ja shadere mjenjam odavno ali u samom biosu grafičke, tako da bi sa rivim trebalo biti jednostavnije.
dugixy1 je offline   Reply With Quote
Staro 30.09.2007., 13:06   #8
Jelc
Super Moderators
Postovi: 17,485
Za one kojima je preteško skužiti kaj piše u dokumentaciji-u slikama
Enabling the new Shader overclock slider in Windows XP:
http://www.guru3d.com/newsitem.php?id=5958
