običan user
Lokacija: Phuket, Thailand
Postovi: 844
Sastavljam si novi komp
INTEL Core 2 Duo E6750 BOX, (2×2.66GHz, 1333MHz, 4MB), Socket 775, Conroe 1.470,00 vemil EVGA, 8800 GTS GeForce 8800 GTS, 320 MB, tv-out, Dual DVI 2.464,66 adm Gigabyte P35-DQ6, s775, intel P35+ICH9R, FSB 1333/1066/800MHz, 8xSerial ATA II, 1xUDMA133, 2xPCI, 3PCI-E x 1, 2PCI-E x 16, 4DDR II (Dual channel 1066/800/677/533 MHz), 8-channel audio, Gb LAN,2xFW, USB 2.0, HT, ATX 1.389,64 vemil RAM PC-8500, 2048MB, DDR2, CRUCIAL Ballistix, KIT, 1066 MHz, 2x1024MB 1.187,13 links HDD 150.0 GB WESTERN DIGITAL Raptor, Serial ATA, NCQ, 16MB cache, 10000 okr/min 1.680,43 links Kućište COOLERMASTER Stacker rev 2.0, srebrno, STC-T01, BIG, ATX / BTX nadogradivo, bez PS 1.170,03 links OCZ power supply GameXStream 700W, SLI-ready, crno, EPS, ATX 2.2, 4×12V (72A), 12cm blue led FAN 977,56 links SM932BF Black, 19" Design Gaming LCD Monitor, 1280x1024, 300cd/m2, DC 2000:1, 160°/160°, Response time 2ms - World's record breaking response time, the fastest monitor ever, Glossy Black, MagicTune, MagicBright2, MagicColor, Analog/Digital, TCO'99, LS19PEDSFV 2.115,53 adm UKUPNO 12.454,98 |
Postovi: 11,642
Nemam pojma gdje si ti uspio spiskati 12k....u 19'' monitor??? Evo jedan prijedlog: Procesor: Intel Core 2 Duo E6750 - 1244kn, Diskont24 Matična: Gigabyte GA-P35 DS3P - 910kn, ADM Memorija: 2x1GB Crucial Ballistix 800 - 824kn, Links Grafička: Albatron GF8800GTS 640MB DDR3 - 2583kn, Ve-Mil Hard disk: Samsung Spinpoint 320GB, T166 - 549kn, ADM Optika: LG GSA-H62N, SATA, black - 260kn, Ve-Mil Napajanje: Corsair VX450W - 550kn, Optimum Kućište: Antec Solo - 662kn, ADM ------------------------------------------------------------------------------ UKUPNO: 7582kn, sve iz različitih dućana, bez monitora. Cijenu možeš korigirati ubacivanjem slabije memorije (ako ne namjeravaš clockati) Kingmax 667 (s kojim bi uštedio ~350kn), ili jeftiniim/skupljim kućištem. |
običan user
Postovi: 844
Pa pogledaj malo bolje o kojim se komponentama radi, monitor je samo 2k kn, a odlican je, hard disk se vrti na 10k okretaja, napajanje 700 Watt-i, graficku su cini mi se bas na ovom sajtu testirali i ocijenili dobro itd itd... Eh da, i cijene su sve izracunate na kupnju na kreditnu, uskoro mi stize revolving mastercarcd pa kupujem kantu, nego....bi li ja mogao kome uvalit ovu moju staru kantu? Zadnje izmijenjeno od: McG. 25.09.2007. u 00:17. |
Lokacija: Križevci
Postovi: 307
Daj malo pogledaj po forumu koje su komponente najkvalitetnije i najisplatljivije. Da ja dajem 12000kn za komp valjda bih tjedan dana po forumima gledao i tražio komponente. Kod ove tvoje konfe nanekorisniji mi je Raptor. Testiranja su pokazala da nije nešto posebno brži od ˝običnih˝ HDD-a, iako se vrti na 10k rpm, skup je i malog kapaciteta. S druge strane za tu lovu možeš imati kapacitet od 1TB. Zatim napajanje. Što će ti 700W, to je već opće poznato da svi pretjeruju s wattažom. Watti ti ne igraju nikakvu ulogu u performansama sve dok napajanje nije preslabo. Da staviš 1000W bilo bi isto kao da si stavio ovog Corsaira. Da sam ja na tvom mjestu, uzeo bih ovo što ti je Razor preporučio i investirao u dobar i veći monitor. I da, ne moraš potrošiti svih 12 soma, čuvaj, vjerojatno ćeš se uskoro opet zagrijat za neku nadogradnju ![]() |
Lokacija: CROATIA-Vukovar
Postovi: 2,354
pozdrav
Da sve super složeno i dobre preporuke ali kad več uzimaš grafu za 2.450-ak kuna da još 2 stoje i uzmi GTS sa 640MB ovu: Leadtek GF 8800GTS, 640MB, PCI-E, TV-out, 2 x DVI=2.665KN ili Albatron GF 8800GTS, PCIE, 640MB, TV out, dual DVI=2.584KN u Ve-milu ali ima skoro svagdje mislim da je to isplativija kupnja i bolji ulog za ubuduče. ![]() |
Postovi: 11,642
Lokacija: NaN
Postovi: 3,438
Mani se te grafe (eVGA), ja sam tu istu kupio u ADM(nije bilo druge, pa sam bio prisiljen) 'em je skupa kao sam vrag bez razloga 'em je bundle katastrofalan. Raptor ćeš uzeti zato kaj se vrti na 10k... ako ćeš tako razmišljaš kupi si onda grafu koja ima više meme od 8800GTS, X1300PRO 512MB ![]() |
Postovi: 7,568
Recite vi meni, zakaj odgovarate DFP ekipi koja tak i tak sve zna i kupuje ono kaj su prvotno zamislili. Vi ste stvarno uvjereni da bude on kupil ono kaj mu je Razer predložil i vi argumentirali? Ne bude, znate vi, a zna i on. Trošite vreme i znanje bezveze. |
običan user
Postovi: 844
DFP Ekipa? O cemu ti pricas? Da nisam mislio da cu dobiti dobar savjet, ne bih nista ni postao. Stvar je u tome da dugo nisam pratio sto se zbivalo na hardverskoj sceni i isao sam sastavljati komp po mojim starim saznanjima. Ako Razor kaze da je disk neisplativ, onda jest, ali koliko ja vidim po cjenicima, najvise MB se za kn dobije na disku od 320MB. Takodjer i to napajanje od Corsaira namjeravam uzeti. I tek sad vidim da sam zaboravio przilicu i ventilator. Zalman? Scythe? Lite-on ili Teac? |
Postovi: 11,642
Kako vidiš stavio sam LG-jevu pržu. Od coolera: Do 250kn: Freezer 7 Pro, Coolermaster Hyper UC, Scythe Katana 2 Preko 250kn: Scythe Infinity/Ninja+, Thermaltake Sonic Tower/Big Typhoon. |
#12 | |
Lokacija: n/a
Postovi: 6,128
Postovi: 11,642
Veliki umovi isto misle ![]() I mislio sam da ćeš reći nešto na GB-ovu ploču ![]() |
