Staro 22.09.2007., 15:25   #1
delboy666
delboy666's Avatar
Lokacija: sdas
Postovi: 2
Gamer Konfa molim misljenja
Molio bi mišljenja stručnjaka što kažu na stroj...
isključivo za vrtit igre bi se koristio...
a sad jel treba nešto smanjit ,povećat...?!?
CPU AMD Athlon64 X2 4400+ (64-bit, integ.DDR2 mem. kontr., 1M L2 on-chip cache, 2300 MHz, Windsor dual core), 65nm, Socket AM2, BOX
3 god. 679,00
Powercolor Radeon X1950GT PCIE, 512MB, TVout, dual DVI
18 mj. 949,22
MB GIGABYTE MA69G-S3H, Socket AM2, AMD 690G, 4 x Serial ATA II, SATA RAID, UDMA133, VGA ATI Radeon X1250 shared, 2PCI, 1PCI-E x1, 1PCI-E x4, 1PCI-E x16, 4DDR II (Dual Channel, 800/667/533MHz), 8 channel High Definition Audio, HDMI, Gigabit LAN, IEEE 1394 FireWire, USB2.0, ATX
2 god. 555,16
Chieftec power supply 450W, ATX 2.0, 2×12V, Active PFC, AFC, 12cm FAN, CE, FCC, TUV, OVP, SCP, OCP
2 god. 370,00
DDR2 2GB PC6400 (800MHz) OCZ, gold XTC, 5-5-5-15 5 god. 901,00
*HDD Seagate ST3250310AS, 250 GB 8MB, S-ATA300, NCQ, 7200 Akcija!
3 god. 447,55
Mode Com midi tower Active LCD, 400 W PSU s pasivnim PFC-om, 12cm fanom, AFC-om i 2×12V, LCD display sa kontrolama i podacima o vrtnji ventilatora, temperaturi procesora i kućišta itd., USB 2.0, audio, 80mm fan, 1×cd cover, bijelo-crno; 3×5,25", 6×3,5", 477×180×415mm (dך×v) 1 god. 335,00
Monitor Samsung SM 920NW, 19“ LCD WideScreen, 5 ms, 1440*900, 700:1, crni
3 god. 1.599,00
DVD+RW/-RW/RAM NEC AD-7170BKSA, DVD+R (18x), DVD+RW (8x), DVD-R (18x), DVD-RW(6x), DVD+R DL (8x), DVD-R DL (8x), DVD-RAM (12×), CD-R (48x), CD-RW (32x), 2MB buffer, SATA sučelje, bulk, black
1 god. 229,00
total 6.063,00
delboy666 je offline   Reply With Quote
Staro 22.09.2007., 15:35   #2
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,506
Idi na intela, 21x0 i neku P35 ploču! Snimač LG, čemu case sa napajanjem, hard Samsung/Hitachi, memorija Crucial ili Kingmax, napajanje Fortron 350W ili Corsair 450W, imaš pun K konfiguracija, malo prolistaj forum!
http://forum.pcekspert.com/showpost....59&postcount=8
Staro 22.09.2007., 15:52   #3
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
pozdrav
Procesor 4000X2 ti je dosta malo clockneš2.6-2.8) i ide ko onaj duplo skuplji.
Glede ovog što ti je kolega -POP- predložio je uredu sve zavisi koliko si se spreman "ispružiti s kuničima" ali dalo bi se složiti dobar stroj u Intel varijanti.
Naravno izbor tvoj(ovo su samo savjeti).
EDIT: Za cca 6.100KN imaš ovo u Intel varijanti:
Procesor Intel Pentium Dual-Core E2180 , 2.0GHz, socket 775 BOX=631KN
Gigabyte P35-DS3R, s775, intel P35+ICH9R, FSB 1333/1066/800MHz=843KN
VGA Ati Radeon X1950GT, 256Mb GDDR3, 256bit, Dual DVI, PCI X=908KN
HDD SAMSUNG SpinPoint P120 250GB 7200rpm 8MB cache Serial ATA II=450KN
DDR2 1024Mb ( 1Gb ) PC5300 Kingmax MARS , CL5 X2=500KN
Philips 190C7FS, LCD, 19", 5ms, 300cd/2, C: 800:1,DVI+D-Sub=1500KN
SHARKOON Rebel9 Economy-Edition, midi tower, crno, bez napajanja=317KN
Napajanje FORTRON 350W, Super Silent, 12cm ventilator, ATX2=200KN
Ovo izađe cca 5.400KN znači imaš još love pa ako želiš nešto promjeniti ima mjesta(Samsung monitor ili veči hard,drugo kučište)...
Sve je sklopljeno u ADM-u u ZG-u.
Zadnje izmijenjeno od: ECHO. 22.09.2007. u 16:08.
Staro 22.09.2007., 15:56   #4
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,506
Autor tdominov Pregled postova
Izbaci iz moje konfiguracije zvučnike, miš i tipkovnicu i dobiješ cca 5850KN... Znači manje nego njegova, a bolja.
Staro 23.09.2007., 23:47   #5
delboy666
delboy666's Avatar
Lokacija: sdas
Postovi: 2
CPU INTEL PENTIUM E2180 Dual core(2.0 GHz, 800 MHz, 1MB), 64-bit, Socket 775, BOX 3 god. 693,82
MB Gigabyte P35-DS3R, s775, iP35, Core 2 Extreme Quad-Core/Core 2 Duo ready, FSB 1333/1066/800MHz, 8xSerial ATA II, SATA RAID, 1xUDMA100, 3PCI, 3PCI-E x 1, 1PCI-E x 16, 4DDR II (Dual channel 1066/800/677 MHz), 8-channel Intel High Definition audio, Gigabit LAN, USB 2.0, HT, ATX
2 god. 868,09
DDR2 1GB PC6400 (800MHz), Kingmax
3 god. 272,37
3 god. 272,37
Gigabyte Radeon X1950Pro 256MB DDR, PCIE, TVout, Dual DVI
2 god. 1.273,74
DVD+RW/-RW/RAM LG GSA-H62N Dual Layer, SATA, 18x, bulk, black
2 god. 260,78
Power Supply FORTRON 350W, ATX 2.0, HQ, PFC, 12cm fan
2 god. 211,15
Monitor Samsung SM 940NW, 19“ LCD WideScreen, 1440x900, 300cd/m2, 700:1, 160/160, 5ms, MagicTune, MagicBright2; TCO’03
3 god. 1.599,00
Mode Com midi tower Harry, bez PSU, USB 2.0, audio, 92mm fan,2×cd cover, crno, ulazi za zrak sprijeda; 4×5,25", 6×3,5", 480×180×415mm
1 god. 155,00
*HDD Seagate ST3320620AS, 320 GB 16MB, S-ATA300, NCQ3, 7200 Akcija!
3 god. 596,56
6.199,00
Evo odlucio da cu uzet ovo,mozda case neki drugi ,najvjerojatnije...al mislim da ce ovo biti krajnja konfa...jos jednom da pitam jel ok?
Staro 24.09.2007., 00:07   #6
Slash555
Slash555's Avatar
Lokacija: Slatina
Postovi: 362
19" widescreen je dosta "nizak", možda će ti bit dovoljan, al tek toliko da znaš. ja sam uzeo lg 20" ws za nekih 1700-1800
a ta grafa će malo teže gurat novije igre
Slash555 je offline   Reply With Quote
