Staro 17.09.2007., 22:23   #1
uploader
uploader's Avatar
Lokacija: Germany
Postovi: 694
AMD konfa 6500kn (pomoc!)
GMC G30 ExtraMidi Tower ATX (bez napajanja), black
195kn
Napajanje Corsair VX Series, CMPSU-450VXEU 450W
537kn
MB MSI Socket AM2 K9N SLI-2F, nForce570, DDR2, PCI-E, ATX
660kn
AMD Athlon 64 X2 5600+, 2800 MHz, 2 Mb c., socket AM2, BUS 2000 MHz, BOX (Windsor Dual Core)
1200kn
2x RAM PC-6400, 1024MB, DDR2, CRUCIAL, Rendition, 800 MHz
508kn
HDD SATA300 160 GB WD Caviar 7200rpm, 16MB, RAID EDITION, WD1600YS 465kn
SAPPHIRE ATI X1950GT GDDR3 256 MB PCIE16
900kn
DVD+RW/-RW/RAM LG GSA-H62N Dual Layer, SATA, 18x, bulk, black
240kn
Miš Logitech OEM S96 Optical Wheel Mouse
50kn
Neka slim tipkovnica...molim preporuku
70kn
zvucnici do 150kn
LCD 1500 do 1600kn max
_______________________________
TOTAL cca 6500kn
Zadnje izmijenjeno od: uploader. 17.09.2007. u 22:47.
uploader je offline   Reply With Quote
Staro 17.09.2007., 22:32   #2
bliss_zg
bliss_zg - take, muljanje na tržnici
Lokacija: ST
Postovi: 305
Gigabyte MA69G-S3H, AMD 690G, S. AM2, 4 x Serial ATA II Gigabyte MA69G-S3H, AMD 690G, S. AM2, 4 x Serial ATA II
496,18Kn
Procesor AMD Athlon 64 X2 6000+ , socket AM2, BOX ! , 0.09, 2048 Procesor AMD Athlon 64 X2 6000+ , socket AM2, BOX ! , 0.09, 2048
1.316,38Kn
DDR2 1024Mb PC5400 SuperTalent, T667UB1GC4 , pasivni hladnjak, C DDR2 1024Mb PC5400 SuperTalent, T667UB1GC4 , pasivni hladnjak, C
619,31Kn
Napajanje FORTRON 500W, BlueStorm, 12cm ventilator, ATX2 Napajanje FORTRON 500W, BlueStorm, 12cm ventilator, ATX2
544,00Kn
Philips 190C7FS, LCD, 19", 5ms, 300cd/2, C: 800:1,DVI+D-Sub Philips 190C7FS, LCD, 19", 5ms, 300cd/2, C: 800:1,DVI+D-Sub
1.499,01Kn
DVD upisivač NEC AD 5170A, DVD±RW 18x crn DVD upisivač NEC AD 5170A, DVD±RW 18x crn
209,23Kn
VGA Ati Radeon X1950Pro, 256Mb GDDR3, 256bit, Dual DVI, PCI X VGA Ati Radeon X1950Pro, 256Mb GDDR3, 256bit, Dual DVI, PCI X
988,76Kn
HDD Seagate 250GB, Serial ATA II , Barracuda 7200.10, 16Mb cache HDD Seagate 250GB, Serial ATA II , Barracuda 7200.10, 16Mb cache
480,63Kn
Aplus CS-185A PC Case, w/o PSU, RoHS Aplus CS-185A PC Case, w/o PSU, RoHS
185,31Kn
Ukupno: 6.338,81Kn
mozes eventualno ustedit na procu malo...
i uzet gt-icu umjesto pro
EDIT:sad sam vidio da je do 6.500kn...pa ak oces izbacis ovo kuciste i uzmes si neko koje ti se svida....
bliss_zg je offline   Reply With Quote
Staro 17.09.2007., 22:37   #3
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,508
544,00Kn
Fortron 350W PNF po 211KN ga pojede...
http://forum.pcekspert.com/showthread.php?t=80521
Staro 17.09.2007., 22:39   #4
bliss_zg
Lokacija: ST
Postovi: 305
nisam ga uspio nac...
pa sam stavio ovo...
EDIT:da al ej autor teme editirao post...stavio je athlona pa sam mislio da oce athlona...
Staro 17.09.2007., 22:40   #5
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,508
Autor bliss_zg Pregled postova
Za te pare imaš Corsair 450W!
Staro 17.09.2007., 22:41   #6
bliss_zg
Lokacija: ST
Postovi: 305
a ***at ga sad...dobro mu je i ovo
Staro 17.09.2007., 22:42   #7
bliss_zg
Lokacija: ST
Postovi: 305
Autor uploader Pregled postova
zvucnici do 150kn
ajd se skuliraj pa reci kaj ti sve treba...i jel oces intel il amd??
Staro 17.09.2007., 22:46   #8
uploader
uploader's Avatar
Lokacija: Germany
Postovi: 694
aj mi prvo recite koji je INTELOV proc. ekvivalentan ovome AMDu 5600+
Staro 18.09.2007., 01:27   #9
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
pozdrav
Nepotrebno bacanje love na taj proc(5600-6000X2)kad če 4000X2 kad ga klokneš isto to obaviti za duplo manje love.Ako se več ide na tako skup procesor onda je bolje odabrati Intel varijantu(4400 ili jače verzije 6750 bolje za rad više keša) a moje je mišljenje i da su trenutno bolje(pogotovo glede clocka ).Evo pogledaj i malo usporedi što te zanima:
www23.tomshardware.com odeš pod CPU charts i usporediš.
Naravno to je moje osobno mišljenje(imao 4200X2 i prešao na Intel).
Staro 18.09.2007., 16:56   #10
bliss_zg
Lokacija: ST
Postovi: 305
al ak se covijek ne zeli uplitat u OC vode onda amd...jeftinije ce proc...
Staro 24.09.2007., 18:43   #11
uploader
uploader's Avatar
Lokacija: Germany
Postovi: 694
Ma nemogu vjerovati.....ova gore konfa je sastavljena prije tjedan dana a danas je cca. 500kn jeftinija....uzas kako cijene padaju.....previse!
Staro 20.10.2007., 23:35   #12
uploader
uploader's Avatar
Lokacija: Germany
Postovi: 694
270 Frontier Irock ExtraMidi Tower 400W P4 ATX Silver/Black (bez napajanja)
466 CHIEFTEC 550W
890 Gigabyte P35-DS3P, s775, intel P35+ICH9R, FSB 1333/1066/800MHz
1193 Intel® Core(TM) 2 Duo E6750 2x2.66 GHz,
390 2x Kingmax Mars DIMM 1GB DDR-2 800MHz 240pin (KLDD4)
486 HDD Seagate, 250 GB 16MB, S-ATA300, NCQ3, 7200
1975 Gigabyte 8800GTS , 320Mb GDDR3 320bit, Dual DVI, PCI-X
270 DVD+RW/-RW/RAM LG GSA-H62N Dual Layer, SATA, 18x, bulk, black
48 Miš Logitech OEM S96 Optical Wheel Mouse
51 Genius Slimstar 100
152 Logitech S200 zvucnici
1400 Philips '190WV7CS-19.1" LCD, widescreen, 300 cd/m2, 850:1, 5 ms, 1440 x 900 @ 75 Hz
UKUPNO : 7591kn
Dajte to smanjite na 6000 maximalnooo 6500
Zadnje izmijenjeno od: McG. 21.10.2007. u 00:06.
Staro 21.10.2007., 00:20   #13
Postovi: 7,568
Tražiš AMD konfiguraciju i složiš ju u prvom postu i sad si nakon par prevrtanja na Intelu za ~7.600 kn. A kažu da Lana Jurčević ima nagle promjene mišljenja i raspoloženja. Svašta...
E2180 ili E4400, Chefitec 450W ili CoolerMaster 430W, a za karticu si dobro razmisli dal buš kupil sad ili čekal da stigne nova 8800GT. Da ne bi posle bilo kak si se zayebal i zakaj niko neće kupiti karticu staru dva tjedna. U slučaju da nećeš čekati, kupi HD 2900Pro. Ili ako baš hoćeš/moraš/trebaš kupi GTS 320.
Staro 21.10.2007., 00:33   #14
killerbee
Wannabe Pilot
killerbee's Avatar
Lokacija: High In The Sky
Postovi: 493
Autor McG Pregled postova
LoL. Nešto u zadnje vrijeme voliš uspoređivati komponente s ženama.
killerbee je offline   Reply With Quote
Staro 21.10.2007., 00:33   #15
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
1 x Gigabyte P35-DS3L
2 x DDR2 1024Mb PC5300 Kingmax
1 x HDD SAMSUNG SpinPoint 250GB
1 x Napajanje CORSAIR 450W
1 x DVD upisivač Liteon
1 x Aplus CS-185A PC Case
1 x Miš Logitech UltraX
1 x Tipkovnica Logitech Deluxe 250
1 x Zvučnici Logitech X-240, 2.1
1 x Procesor Intel Core 2 Duo E4400
1 x VGA Ati Radeon X1950Pro, 512Mb
1 x Philips 190S7FS, LCD, 19"
6.301,30Kn u www.adm.hr
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 21.10.2007., 11:46   #16
uploader
uploader's Avatar
Lokacija: Germany
Postovi: 694
a ***iga decki....malo sam progooglao i vidio da Intelovi procovi nekako bolje stoje sa overclockom....imaju više cachea.....a ovu prethodnu konfu od 7600kn mi je sastavio frend..
a nemam ja tolko....pa sam mislio da malo skrešete to na bar 6500
