Povratak   PC Ekspert Forum > Računala > Storage > Mediji
Staro 13.09.2007., 23:48   #1
tpint10
tpint10's Avatar
Lokacija: Zgb
Postovi: 150
xD Olympus izgubljene slike
prije ljeta kupio sam novi... preedobar fotić mju725sw.. i sve super.. radi ispod vode i ovo i ono... kupil sam si dodatnu karticu od gige... i otišo na ljetovanje...slikal sam cca500 slika... kad sam se vratio... išel sam to prebacit na komp preko card readera na laptopu... i prvo mi je izbacio da je write protected.. onda sam iščupao ga i ponovo gurnuo nazad... sve je proradilo... ali mi neke slike nije htio otvorit... vratio sam karticu u fotić i nije prepoznal karticu i tražil je format.. što nisam napravio...
napravio sam na kompu error check i on je to odvrtio... izbacio ovo... i te slike i dalje nemrem vidjet...
u prilogu je što se događalo...
a sad pitanje... jel ima neko neki program... ili bilo kakvu ideju kak vratit te slike...
btw slike su promijenile veličinu s 1,5mb na 16kb...
Checking file system on E:
The type of the file system is FAT.
One of your disks needs to be checked for consistency. You
may cancel the disk check, but it is strongly recommended
that you continue.
Windows will now check the disk.
The size of the \DCIM\100OLYMP\P7240104.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7240105.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7250106.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7250107.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7250108.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7250109.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7250110.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7250111.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7260112.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7260113.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7260114.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7260115.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7260116.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7260117.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270118.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270119.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270120.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270121.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270122.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270123.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270124.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270125.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270126.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270127.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270128.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270129.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270130.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270131.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270132.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270133.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270134.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270135.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270136.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270137.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270138.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270139.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7270140.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7280141.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7280142.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7290143.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7290144.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7290145.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7290146.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7300147.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7300148.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7300149.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7300150.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7300151.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7300152.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7300153.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7300154.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7300155.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7300156.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7300157.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7300158.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7300159.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7300160.MOV entry is not valid.
The size of the \DCIM\100OLYMP\P7300161.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7300162.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7300163.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7310164.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7310165.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7310166.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7310167.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7310168.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7310169.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7310170.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7310171.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7310172.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7310173.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7310174.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7310175.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7310176.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P7310177.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P8010178.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P8010179.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P8010180.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P8010181.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P8010182.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P8010183.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P8010184.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P8010185.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P8010186.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P8010187.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P8010188.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P8010189.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P8010190.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P8010191.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P8010192.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P8010193.JPG entry is not valid.
The size of the \DCIM\100OLYMP\P8010194.JPG entry is not valid.
Convert lost chains to files (Y/N)? Yes
134250496 bytes in 8102 recovered files.
Windows is verifying free space...
Free space verification is complete.
Windows has made corrections to the file system.
1048182784 bytes total disk space.
294912 bytes in 3 folders.
694222848 bytes in 8571 files.
353665024 bytes available on disk.
16384 bytes in each allocation unit.
63976 total allocation units on disk.
21586 allocation units available on disk.
Zadnje izmijenjeno od: domy_os. 14.09.2007. u 02:07.
tpint10 je offline   Reply With Quote
Staro 14.09.2007., 00:55   #2
BmwMPower
Lokacija: VG
Postovi: 1,128
http://www.pcinspector.de/
pokušaj, nemaš što izgubiti (više)
BmwMPower je offline   Reply With Quote
Staro 14.09.2007., 11:06   #3
domy_os
domy_os's Avatar
Postovi: 18,892
Sličnu situaciju sam i ja imao sa svojim Olympusom i pomogli su mi Easy Recovery i Final Data Enterprise, svaki je spasio nešto. Inače, i u drugim slučajima koristim ta dva programa i do sad imam najviše uspjeha s njima.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 14.09.2007., 19:04   #4
tpint10
tpint10's Avatar
Lokacija: Zgb
Postovi: 150
hvala puno na pomoći... isprobal sam sve programe i sa svakim sam dobil par slika... najviše mi je pomogao program Easy photo recovery... skoro sve sam slike uspio spasiti...
fala još jednom
Staro 26.06.2009., 23:05   #5
Jablan
Jablan's Avatar
Datum registracije: Jul 2004
Postovi: 756
Da ne otvaram novi post, da li ovi programi mogu pomoći i u spašavanju podataka sa SD card iz foto aparata?
Jablan je offline   Reply With Quote
Staro 27.06.2009., 15:15   #6
Jablan
Jablan's Avatar
Postovi: 756
Trebam li SD karticu umetnuti u nekakav card reader, ili je dovoljno ostaviti karticu u foto aparatu? Kada pokrenem Easy Recovery, ne prepoznaje karticu u foto aparatu..
Staro 27.06.2009., 16:06   #7
Vrga
Lalalallalaaaaaa
Vrga's Avatar
Datum registracije: Mar 2009
Postovi: 521
card reader.
Vrga je offline   Reply With Quote
Staro 27.06.2009., 16:32   #8
Jablan
Jablan's Avatar
Postovi: 756
Znači ništa bez card readera? Hebem ti sada se treba baciti u potragu.., hvala na savjetu Vrga.
Staro 01.07.2009., 19:56   #9
Vrga
Lalalallalaaaaaa
Vrga's Avatar
Postovi: 521
hebga, obično kad čitaš prek digitalke, ona u biti zalock-a karticu na read-only mod... bar moj Canon A450 to radi, a uostalom, brže čupa sa card readerom.
