Staro 19.08.2007., 17:42   #1
marko1303
marko1303's Avatar
Lokacija: Zaprešić
Postovi: 84
colin dirt
da li je ikako moguče pokrenuti colin dirt na radeonu x800xl s 512MB DDR3??
marko1303 je offline   Reply With Quote
Staro 19.08.2007., 17:52   #2
vedo
FC Bayern supporter
vedo's Avatar
Datum registracije: Mar 2002
Lokacija: Kutina
Postovi: 454
Kao prvo thread o Colinu već postoji pa si mogao tamo pitat,a kao drugo taj Radeon ne podržava Shader 3.0 tako da neće ići!
Pozdrav!
Vedran
vedo je offline   Reply With Quote
Staro 19.08.2007., 18:33   #3
dDario
dDario's Avatar
Datum registracije: Jun 2004
Postovi: 1,567
DiRT PC Demo
Information
System Requirements
TCP/IP mode (2-100 players) Requirements
Broadband internet connection required - 512kbps + Recommended
TCP/IP Network
Minimum Specifications
- Windows XP
- DirectX 9.0c
- Pentium 4 @ 3.0GHz or Athlon 64 3000+
- 1GB RAM.
- Graphics Card: GeForce 6800 / Radeon X1300 or above
- DirectX Compatible Sound Card
Recommended Specifications
- Windows XP/Vista.
- DirectX 9.0c
- Intel Core 2 Duo @ 2.66Ghz or Athlon X2 3800+
- 2GB RAM.
- Graphics Card: GeForce 8800 or Radeon X1950
- Sound Card: Creative Sound Blaster X-Fi Sound Card.
Supported Graphics Cards
Shader Model 3 is a MINIMUM REQUIREMENT for this game.
- ATi Radeon x1300, x1600, x1800, x1900, x1950
- nVidia Geforce 6800, 7100, 7300, 7600, 7800, 7900, 7950, 8800
Not compatible with all integrated sound/graphics solutions (inc.Laptops)
Known issues:
Users with Windows Vista and ATi Radeon x1950/1900 graphics cards may find that bonnets do not get drawn on 2 of the demo cars.
Alt-TAB, Alt-ENTER etc minimise the game but the game will not recover.
On certain graphics cards they may be some graphical corruption e.g. flickering textures/shadows.
There may be some slowdown on certain graphics cards.
Supported Controllers
DiRT™ can be configured to use almost any PC controller, however we recommend the following controllers for the best game play experience:
- Logitech G25
- Logitech MOMO
- Logitech Driving Force Pro
- Microsoft X360 controller
DiRT™ provides default configurations for all of the above, meaning that you should be able to plug-and-play, with no tweaking required.
IBM T43 > Centrino M750 > 2GB DDR2 > 60GB > DVD-RW > 14" XGA
Atom 230 > D945GCLF > 1GB Buffalo > 120GB > DVD-RW > HP L1940
Atom 330 > D945GCLF2 > 2GB G.SKILL > 160GB > DVD & DVD-RW > SM720N
E1400 > G31-M7 TE > GB DDR2 > 80GB > DVD & DVD-RW > SM720N
E1400 > G31-M7 TE > 2GB DDR2 > X1600Pro > 250GB > DVD & DVD-RW > SM932B
X4 9950 > AM2NF3-VSTA > 2x2GB G.SKILL > Parhelia 256 > 2x 640GB > DVD-RW > 2x SM205BW
E6300 > ASUS P5B > 2xGB kingmax > X1900AIW > 2x320GB > DVD-RW & DVD-RW > LG 194WT
dDario je offline   Reply With Quote
Staro 19.08.2007., 19:12   #4
marko.maky
marko.maky's Avatar
Lokacija: Vukovar
Postovi: 160
Tvoja grafa nema shader 3.0 i koliko ja znam nema šanse da je pokreneš.
marko.maky je offline   Reply With Quote
