Postovi: 527
(rijeseno) CoD 2 (Xfire) problem
dakle, imam Xfire i instalirao sam Call of Duty 2 i patchiro ga sa 1.3 verzijom. Sada, kad želim ući u igru, on krene ulazit i odjednom sam izađe i "izbaci se" prozor kojem je "ime" Xfire Exception u kojem piše: <?xml version="1.0" encoding="utf-8" ?> <ExceptionReport Version="4"> <Application Build="27409" Command=""d:\Igrice\CoD 2\CoD2MP_s.exe" +connect 84.2.39.214:28971"/> <OperatingSystem Type="2"><Version Major="5" Minor="1" Build="2600"/></OperatingSystem> <Exception Code="C0000005" Address="0260A467"><Module Section="0001" Offset="00009467" FileName="C:\WINDOWS\system32\nvappfilter.dll"/></Exception> <Registers EAX="00004880" EBX="0264C3A0" ECX="11230CE8" EDX="00130001" ESI="0264423C" EDI="02644238" CS="001B" EIP="0260A467" SS="0023" ESP="1123FCE0" EBP="1123FCF8" DS="0023" ES="0023" FS="003B" GS="0000" Flags="00010202"/> <BackTrace> <Frame ProgramCounter="0260A467" StackAddress="1123FCE0" FrameAddress="1123FCF8"> <Module Section="0001" Offset="00009467" FileName="C:\WINDOWS\system32\nvappfilter.dll"/> <StackHexDump From="1123FCE0" To="1123FCF8">02 00 00 00 43 29 60 02 02 00 00 00 20 fe 23 11 d0 2a 61 02 ff ff ff ff</StackHexDump> </Frame> <Frame ProgramCounter="026055ED" StackAddress="1123FCE0" FrameAddress="7C91043D"> <Module Section="0001" Offset="000045ED" FileName="C:\WINDOWS\system32\nvappfilter.dll"/> <StackHexDump From="1123FCF8" To="1123FD78">3d 04 91 7c ed 55 60 02 f8 cb 61 02 3c 79 61 02 eb 03 00 00 78 7d 61 02 02 00 00 00 4c 2a 64 02 d0 41 64 02 8a 18 91 7c 78 fd 23 11 49 4b 60 02 3c 42 64 02 38 42 64 02 00 00 00 00 04 4d 60 02 d0 41 64 02 00 00 00 00 bc 0b 00 00 01 00 00 00 b9 9c 60 02 6d 27 00 00 00 00 00 00 8c fd 23 11 00 00 60 02 01 00 00 00 01 00 00 00 11 5c 60 02 78 fd 23 11 00 00 00 00 6a ad 60 02 00 00 60 02</StackHexDump> </Frame> <Frame ProgramCounter="05706800" StackAddress="1123FCE0" FrameAddress="0000A068"> </Frame> </BackTrace> </ExceptionReport> hitno molim pomoć!! ![]() |
Postovi: 9,067
Probaj uci normalno u igru, preko multiplayera ili preko HLSW/ASE. Ako ti bez problema ulazi, xfire je problem. Onda preporucam reinstall tog malog govneta, i ponovno konfiguraciju za CoD2 podesavajuci tocan patch do CoD2MP_s.exe.
___________ Just atha x |
#3 | |
Postovi: 527
kad hoću uć u igru (a xfire radi u pozadini), opet se javlja... a patch sam downloadirao sa xfire-ove stranice... |
Strichek Moderator
Postovi: 9,343
ASE-> All Seeing Eye Prvo ugasi Xfire, onda uđi u Multiplayer, nađi neki server i spoji se na njega, ili se spoji na neki server preko ASEa, ako će onda radit onda te Xfire zeza, pa ga probaj reinstalirat. Za slučaj da ni onda ne radi, reinstaliraj COD, ne traje dugo a može biti puno brže nego nabadat ovako.
žmnpp |
Strichek Moderator
Postovi: 9,343
Inače bilo bi red i fer da napišeš kak si to riješio da i drugi znaju ak im se to dogodi..
žmnpp |
Postovi: 527
jednostavno sam patcho i nije mi radilo...i onda mi je jedan prijatelj dao SAMO FOLDER pod imenom pb (punk buster) i ja sam ga zamijenio s mojim folderom koji se zove pb...i to je to! ![]() |
