Povratak   PC Ekspert Forum > Računala > Overclocking > Memorije
Staro 08.08.2007., 16:37   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
OCZ SPD-Z (SPD memory flash tool)
Oni koji duže prate http://www.xtremesystems.org/forums/ znaju da takav ili sličan komad softa postoji već jedno vrijeme.
OCZ's answer to the ever increasing needs of the enthusiast is a tool that allows you to reflash the SPD on your OCZ memory for either improved compatibility, improved performance or in some cases BOTH!
OCZ Technology Group today unveiled a new tool for end-users to enhanced and stabilize their memory modules when upgrading to a new motherboard. OCZ’s SPD-Z!
Tehnology is for DIY users to reprogram their memory’s SPD (serial presence detect) and remedy an inefficient module and mainboard interface completely independent of BIOS tweaks.
Thanks to this method of reconfiguring the SPD, consumers can now enjoy ultimate compatibility, stability, and performance.
OCZ’s renowned technical support staff will be on hand to offer advice and tips for those in need. New SPDs will be added every week and community involvement and discussion is highly encouraged on the forum so OCZ can provide the best level of compatibility and service.
The tool is very easy to use and will actually look at the part number on the modules and point you to SPD's available on the repository here on the OCZ forum specific to the modules part number. All the end user has to do is make sure the system is 100% stable and not over clocked during the reflash of the modules, once complete the end user can reboot and commence testing.
SPD-Z works within windows, and is GUI based for ease of use, no command line or DOS boot is needed.
http://downloads.guru3d.com/download.php?det=1696
Staro 08.08.2007., 16:51   #2
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Hmm čini se da radi samo sa OCZ memorijama?
Ali čini mi se super alatka. OCZ-u pohvale za programčić
EDIT: thx Jelc što si donio vijest
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 08.08.2007., 17:03   #3
Razer
Razer's Avatar
Postovi: 11,642
Čuo sam za taj program, sličnu stvar radi i SPDTool (radi sa svim (radnim) memorijama).
Staro 08.08.2007., 17:05   #4
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Radi samo sa OCZ-ima i to nekima, jer se ravna prema nekim podacima na netu, ali update-aju to svakodnevno koliko sam skužio.
Za ostale, SPD Tool ako se dobro sjećam. Iako, to nije mala stvar i lagano je usrat motku.
EDIT:
Razer je bio brži.
Staro 08.08.2007., 17:34   #5
Jelc
Super Moderators
Postovi: 17,485
Ma, ja sam ga skinuo na hard (SPDTool) čim se pojavio ali nisam našao žrtvu za ekspirimentiranje
Staro 08.08.2007., 17:40   #6
Razer
Razer's Avatar
Postovi: 11,642
Nije to baš toliki bauk. Frend je svoje ''otiske'' ostavio na dosta memorija
