Staro 07.08.2007., 18:27   #1
alimilano
alimilano's Avatar
Lokacija: Split Hrvatska
Postovi: 936
Virtumonde debsrv.dll problem
Rijetko mi se desi da ne mogu uklonit neki spyware ali evo jedan, Spybot kaže da je Virtumonde a datoteka je debsrv.dll koja se nastanila u system32 folderu.
Problem je šta je povezana sa winlogon-om pa je nikako ne mogu maknit a neman drugi komp u blizini (izvadia bi disk pa...)
Probao sa AVG, Spybot, Adaware 2007, Smitfraud, HijackThis itd
Sa kojim boot cd-om bi moga pristupit disku i izbrisat taj dll...
alimilano je offline   Reply With Quote
Staro 07.08.2007., 18:57   #2
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Moj preijedlog ti je da probaš iz recovery console...
Dakle XP cd u drive i oderi ga...
Have a nice day...
Staro 07.08.2007., 19:53   #3
WraGG
WraGG's Avatar
Lokacija: Stuttgart
Postovi: 1,601
Zar ti spybot ne ponudi da ga ocisti pri slijedecem rebootu?
Staro 07.08.2007., 22:53   #4
alimilano
alimilano's Avatar
Postovi: 936
Autor yedwy Pregled postova
probaću, to mi nije palo na pamet
Autor WraGG Pregled postova
naravno da ponudi i ništa mu ne može ???
Staro 08.08.2007., 08:01   #5
greenfly
Od nonine sestre kunjado
greenfly's Avatar
Lokacija: (Vinjro)
Postovi: 1,130
Probaj VUNDOFIX
evo i uputa na engliš :
  • Double-click VundoFix.exe to run it.
  • Click the Scan for Vundo button.
  • Once it's done scanning, click the Remove Vundo button.
  • You will receive a prompt asking if you want to remove the files, click YES
  • Once you click yes, your desktop will go blank as it starts removing Vundo.
  • When completed, it will prompt that it will reboot your computer, click OK.
  • Please post the contents of C:\vundofix.txt and a new HiJackThis log in a reply to this thread.
Note: It is possible that VundoFix encounters a file it can not remove. In this case, VundoFix will run again on reboot,
If this occurs, simply follow the above instructions starting from "Click the Scan for Vundo button" when VundoFix appears upon rebooting.
greenfly je offline   Reply With Quote
