Staro 05.08.2007., 20:20   #1
salafek
salafek's Avatar
Postovi: 6
Post konfiguracija cca 2000 kn
MBO ASROCK, s. 775, 775XFire-VSTA, i925X, BUS 800 MHz, serial ATA, 428.00 kn Podržava LGA 775 for Intel® Pentium® 4 / Celeron® D, Cedar Mill procesore
- FSB 800/533 MHz
- Northbridge: Intel® 925X, Southbridge: Intel® ICH6R
- 4x DDRII DIMM, Dual Channel DDRII, max. 4GB
- 3x PCI, 1x PCI Express x16, 1x AGI Express slot (PCI Express x 4), 1x PCI Express x1
- Realtek ALC888 7.1channel CODEC
- Realtek PCI LAN 8101L 10/100 ethernet
- 4x Serial ATA, 1x ATA100 IDE
- 1x PS/2 miš, 1x PS/2 tipkovnica, 1x Serial Port: COM1, 1x Parallel Port, 4x USB 2.0, 1x RJ-45 LAN
- Dimenzije 30.5 cm x 21.8 cm (ATX)
Intel® Pentium® 4 631 3.0GHz, 800MHz, 2MB, Cedar Mill, EM64T, LGA775, HT, 65nm, BOX
463.00kn
- Radni takt 3.0 GHz
- BUS 800 MHz
- Cache 2 MB
- 95 nm tehnologija
- Socket 775
- Prescott jezgra, EM64T
RAM, 1 Gb, DDR 2, PC-6400, 800 MHz, KINGMAX
340.00kn
Midi Tower, NEON CX-8058, 400 W, ATX 2, bijelo
226.00kn
VGA PCI-E EVGA, 7300 GS HDTV, GeForce 7300 GS, 256 MB, tv-out, DVI
506.00kn
EVGA, 760 GT KO
- Chipset GeForce 7600 GT KO
- 550 MHz GPU
- 650 MHz memorija
- 4 Pixel Pipelines
- 400 MHz RAMDAC
- 5.2 GB/s Memory Bandwidth
- PCI-E 16x
- DVI-I, DVI-I, HDTV-7
HDD HITACHI 120 GB, serial ATA-II, 7.200 o/min., 8 MB cache
319.00kn
Jel je konfiguracija u redu za tu cijenu.
jel ima kaj bolje!!!
salafek je offline   Reply With Quote
Staro 05.08.2007., 21:11   #2
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,409
Staro 05.08.2007., 21:27   #3
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
Bolje da uzme plocu s AMD690G chipsetom koji ima dobru integrusu i Codegena koji ima 120mm vent na napajanju. Za razliku bi se ugurao jos jedan GB rama...brijem.
Ili nek uzme ECS nforce4-A plocu i onda se moze stavit i Radeon X1600pro ili 7600GS. Ono za napajanje i dalje stoji.
