Postovi: 34,081
Šta bi ti s njime - igre, 3D, video obrada, sve pomalo,...?
Lokacija: livno
Postovi: 1,065
Gigabyte 965P-DS3, s775, i965, FSB 1066/800/533MHz, v3.3 733KN
Procesor Intel Core 2 Duo E4400 , 2.0GHz, socket 775, 2Mb cache, 911KN 4x DDR2 1024Mb ( 1Gb ) PC5300 Kingmax MARS , CL5 999KN Point Of View GeForce 8800GTS EXO, PCI-Ex16, 320MB DDR3 2098KN HDD Seagate 320GB, Serial ATA II, 7200 rpm, Barracuda 7200.10 579KN Napajanje CHIEFTEC 550W, EPS, 120mm ventilator, Active PFC 479KN THERMALTAKE Soprano VB1000BWS, MIDI, black, bez napajanja 532KN Samsung monitor SM225BW, 22" LCD, 1680x1050, 280cd/m2, 700:1, 16 2939KN Ukupno: 9311KN Fali optički pogon ali to si izaberi i stavi.ako oces uzmi monitor samsung 226BW.i za ostatak pojacaj jos nesto ako bas oces da bude 13000KN ali mislim da se ne isplati. AMD konfa: DDR2 1024Mb ( 1Gb ) PC5300 Kingmax MARS , CL5 999KN HDD Seagate 320GB, Serial ATA II, 7200 rpm, Barracuda 7200.10 579KN Napajanje CHIEFTEC 550W, EPS, 120mm ventilator, Active PFC 479KN THERMALTAKE Soprano VB1000BWS, MIDI, black, bez napajanja 532KN Samsung monitor SM225BW, 22" LCD, 1680x1050, 280cd/m2, 700:1, 16 2939KN Procesor AMD Athlon 64 X2 3800+ , socket AM2, BOX ! ,0.09, 1024K 564KN Gigabyte M59SLI-S4,nForce 590 SLI 899KN Point Of View GeForce 8800GTX 768MB (1.1ns) 2xDVI2 HDTV/HDCP 4124KN U ovu sam stavio 8800GTX jer sam iso sto blize 13000kn posto si reko da bi komp od 13000kn.ali mislim da se ne isplati stavit gtx.dovoljna je gts.ali ako ti oces stavi sebi tu gtx.i ako oces stavi x2 5600+ Obe su konfe iz adm-a. I u obe fali opticki pogon. |
Postovi: 7,568
Prijedlog:__________________________________________________ Procesor:
Grafička:
DVD/RW: LG GSA-H42N, Black - 218 kn (Links) Napajanje: Corsair HX-520W, 12cm FAN - 759 kn (Optimum) Kućište:
__________________________________________________________ Ukupno: 10.806 / 13.581 kn.....sve iz različitih dućana |
Sith'ari
Postovi: 18
Igre; maya, photoshop; pa da, zapravo sve pomalo.... @Tekla; lol, ne mora biti nuzno 13k, vazno mi je da to funkcionira ... dulje vrijeme; dok cijena, ona moze biti tako oko 13k max ![]() moze prijedlog za 19'' monitor , jer mi je 22 jednostavno preveliko, .. doslovo, nema shanse da mi stane na stol :lol: i, intergrirani zvuk, je to ok?, jer imam 5.1 sustav; a zvucna i nije nesto sto cu mijenjati svakih 2-3-4 god., za razliku od grafe npr !!! BTW... thx !!! |
Soul Eater
Lokacija: Isolated
Postovi: 538
Ako ne želiš integrušu, slobodno si uzmi audigy 4 i budeš zadovoljan. |
Lokacija: livno
Postovi: 1,065
ok.kuciste. |
