Lokacija: ...
Postovi: 685
Asshole
Lokacija: RH
Postovi: 2,358
Postovi: 355
C/P sa http://setiathome.berkeley.edu/forum...d.php?id=33307 : Dual core is simply a generic term referring to any processor package with two physical CPUs in one. The Pentium D, Core Duo, Core 2 Duo and Athlon X2 are all current CPUs that have dual cores in one package. The Pentium D is simply two Pentium 4 Prescott cpus inefficiently paired together and ran as dual core. The Core Duo is Intel's first generation dual core processor based upon the Pentium M (a Pentium III-4 hybrid) made mostly for laptops (though a few motherboard manufacturers have released desktop boards supporting the Core Duo CPU), and is much more efficiently than Pentium D. The Core 2 Duo is Intel's second generation (hence, Core 2) processor made for desktops and laptops designed from the ground up to be fast while not consuming nearly as much power as previous CPUs. Note - Intel has dropped the Pentium name in favor of the Core architecture as Intel is restructuring and refocusing it's efforts to become number one again (and are doing a fine job, might I add). The AMD Athlon X2 CPUs have two revisions, the first one is essentially very similiar to the Pentium Ds in that they are simply two Athlon 64 chips fused together, making power requirements quite steep (around 89 watts). The second revision is made more efficiently, like the Core Duos, with much less power consumption (around 65 watts). There are, of course, other differences, but that is the gist of dual cores as it relates to Intel and AMD. Zadnje izmijenjeno od: wlcasemodding. 25.06.2007. u 20:49. |
Prečupavi mod
Postovi: 9,106
Ne kuzim sto ce ti toliki sig, a jos manje kuzim zasto ekipa brije na te speedtestove u sig-u? Nista debilnije nisam vidio...
Member of PCE 100+kg demolition squad Pozz, nezz, ojzz, jbt, owak, onak, inst, bzvz, svst, kuiš, neam, dns, nzm, oc, went, graf, laikam, oču, neču, e ovako, e sad, probo, neče, psmtr, ne beliiwam, ugl probo o5, tkđ neradi, pčkmtrnu, mslm onaak haaalo, reko dbr, stv, dali, jeli, zato jel, jer mi može neko, rispekt, thx......... ...wau, radi, zkn, pozz!?!?11 |
Spiderpig
Postovi: 2,043
a ja ne znam koji će Qrac ekipi komp i u sigu i pod opcijom moj komp? ![]() Iskreno i meni je bezveze ovo u sig pogotovo jer sad odjednom svi stavljaju, ali neda mi se mjenjat... točnije nemam ideja ![]() |
Gens Una Sumus
Lokacija: Zagreb-Dubrovnik
Postovi: 123
...war,war never changes... |
Spiderpig
Postovi: 2,043
onda napiši u moj komp pod ostalo da imaš dva kompa i ako nekoga zanima koje djelove imaš u toj kanti neka ti se javi na PM. Šta nekog boli neka stvar koliko ih imaš. "Moj komp" je uveden radi ljudi koji dođu, otvore temu, naslove je kao upomoć neradi mi, i kažu u čemu je problem. ![]() |
