Staro 17.06.2007., 17:56   #1
AnG
Lokacija: //
Postovi: 136
Odabir laptopa
Ovako laptop bi se koristia dosta za AutoCAD,znaci potrebni mu je brzine da to sve otvara koji preporucujete od ova 3
1.
*HP 6710s GB893EA Core 2 Duo T7500 2x1GB 160GB 15.4'' WXGA DVDRW DL X1300 Vista Business
Zaslon 15.4-inch WXGA BrightView
Rezolucija 1280 x 800
Procesor Intel Core 2 Duo T7500, 2.20GHz (4MB cache)
HDD 160 GB (5400 rpm)
FDD -
Optički pogon DVD+/-RW DL
Memorija 2 x1 GB DDR2 667MHz (proširivo do 4GB)
Grafika Integrirana, ATI Radeon X1300
Fax modem 56K
Mrežna kartica 10/100/1000 Ethernet Mbps LAN
WiFi kartica
Multimedia Ugrađeni stereo zvučnici
I/O 4x USB 2.0 port, PC Card slot tip I/II, VGA izlaz, mic in, line out, 1 x RJ11, 1 x RJ45, S-Video Out
Dimenzije 357 x 265 x 35 mm
Masa 2.7 kg
OS Windows VISTA Business
Ostalo Ugrađen Bluetooth modul
Čitač kartica 5u1
FPR modul
Priključak za docking
2.
*HP 6715b GB835EA Turion 64 X2 TL60 2GB 160GB 15.4'' WXGA DVDRW DL WiFi BT 4u1 W Vista Buisness
Zaslon 15.4" WSXGA anti-glare display (1600 x 1024)
Procesor AMD Turion 64 X2 TL60 2.20GHz, L2 Cache 2x 512 KB
HDD 160 GB (5400 okretaja)
FDD -
Optički pogon DVD+/-RW DL Supermulti Fixed
Memorija 2 GB DDR2 (2 x 1024) 667 MHz
Nadogradivo do 4 GB
Grafika ATI Radeon X1250
Do 512-MB dijeljene memorije
Fax modem 56K modem
Mrežna kartica LAN (10/100/1000)
Broadcom 802.11a/b/g
Multimedia Intel High Definition Audio
I/O 4 USB 2.0 porta, VGA, stereo microphone in, stereo headphone/line out, Firewire (1394a), RJ-11, RJ-45, S-video TV out, 1 Type I/II PC Card
Dimenzije 3.5 x 35.7 x 26.5 cm
Masa 2.7 kg
OS Windows Vista Business
Ostalo Bluetooth, Čitač otiska prsta
3.
*HP nx9420 RU478EA Core 2 Duo T5600 2GB 120GB DVDRW DL 17'' WSXGA+ WVA BV Vista Home Basic
Model nx9420 RU478EA
Zaslon 17" WSXGA+ TFT + WVA Bright View
1680x1050 rezolucija
Procesor Intel Core 2 Duo T5600 1,83GHz, 2 MB L2 Cache, 667MHz FSB
HDD 120 GB, 5400 rpm
Optički pogon DVD+/-RW Dual Layer
Memorija 2 x 1024MB DDRII 667MHz
Nadogradivo do 4 GB
Grafika Odvojena, ATI Mobility Radeon X1600
256 MB memorije
Fax modem 56K Modem
Mrežna kartica Broadcom Gigabit 10/100/1000
Intel® Wireless LAN 802.11a/b/g MOW2
Multimedia Sound High Definition, Audio 24 Bit Audio DAC
Integrirani stereo zvučnici
I/O RJ 11, RJ 45, 4 x USB 2.0, VGA, S-Video-TV, IEEE 1394a, priključak za docking, audio ulazi/izlazi, PCMCIA Type I/II PC Card
Dimenzije 393 x 275 x 33 mm
Masa 3.35 kg
OS Windows Vista Home Basic
Ostalo Integriran Bluetooth modul!
Ugrađen čitač kartica 7u1
Ambient light sensor
Po vasem izboru koji bi uzeli laptop znaci za autoCAD???
AnG je offline   Reply With Quote
Staro 17.06.2007., 18:07   #2
nino
nino's Avatar
Postovi: 12,613
Cuj koliko znam, za CAD je vazan sto veci monitor, tako da od ovih 3. ulazi kao najbolji izbor, a ima i grafu odvojenu...
Staro 17.06.2007., 18:37   #3
AnG
Lokacija: //
Postovi: 136
Mozete preporuciti neki laptop iz ve-mila ili hgspota da moze CAD pokrecat bez problema do 10 000kn jer neznam sta to znaci odvojena graficka ako nekom nije problem moze li mi odabrati neki
Staro 17.06.2007., 18:54   #4
Postovi: 34,084
Integrirana grafika znači da ona za svoj rad koristi RAM laptopa. A dotični je UVIJEK sporiji od GDDR memorije koja se koristi na odvojenim graf. karticama.
Za AutoCAD najbolje su ti nVidia Quadro graf. kartice, dok su ATI Fire GL zericu slabije. Njih ćeš naći u HP seriji nw8xxx i nw9xxx.
Moj iskreni savjet je da pročitaš 'Vodič za kupnju..' koji imaš zalijepljen na vrhu ovog podforuma. Ako imaš keš, najbolje ti se obratiti gospodinu koji je taj tekst napisao jer ti može ponuditi odlične laptope po najpovoljnim cijenama.
Staro 17.06.2007., 18:54   #5
Pak
Pak's Avatar
Lokacija: Ploče
Postovi: 264
Pročitaj ovo
http://forum.pcekspert.com/showthread.php?t=52798
dosta će ti pomoći - kasnije češ moći i sam odabrati.
edit:coconut je bio brži
Pak je offline   Reply With Quote
