Staro 14.06.2007., 19:32   #1
PcKinG in da VŽ
PcKinG in da VŽ's Avatar
Postovi: 14
Konfa
koja grafa 8600 gt ili 7900 gs?
Mašina koja čeka update:
CPU: Pentium 4 Prescott core 2.80GHz @ 3.2GHz
MBO: ASUS P3C800
GPU: NVidia GeForce 7600GS AGP
RAM: 1024 MB 400MHz
HDD: 80GB WD Caviar
Power Supply: 450w ms industrial- crkava polako
Costum case maded By King & Ice
PcKinG in da VŽ je offline   Reply With Quote
Staro 14.06.2007., 19:38   #2
PcKinG in da VŽ
Postovi: 14
Intel Core 2 Duo E6420 BOX, 2×2.13GHz, 1066MHz, 775-pin, 4MB 1.398,91
MB Gigabyte 965P-DS3P, s775, i965P, DDR II, SATA II, FW, GLAN 949,22
*HDD HITACHI HDT722516DLA380 160GB SATA300 7200rpm 8MB 390,90
DDR2 512MB PC6400 (800MHz), Kingmax 139,08
Mode Com midi tower Harry, bez PSU, USB 2.0, audio, 92mm fan, 2×cd cover, crno 155,00
Chieftec power supply 400W, ATX 2.0, 2×12V, Active PFC, AFC, 12cm fan, 2×SATA connectors 320,00
VGA PCI-E XFX, GeForce PCX 8600GT, 256MB, DDR3, 2xDVI, TV
ovo je moja konfa pa me zanima sta mislite? Jeli bolje xfx 8600gt ili gigabyte 7900gs?
MBO: ASUS P3C800
RAM: 1024 MB 400MHz
HDD: 80GB WD Caviar
Staro 14.06.2007., 19:41   #3
Postovi: 7,568
To si mogel komotno i na nVidia podforumu pitati ili u već otvorenoj temi.
Staro 14.06.2007., 19:42   #4
Razer
Razer's Avatar
Postovi: 11,642
Prvo otvoris ovu temu - http://forum.pcekspert.com/showthread.php?t=72012
Dobiješ prijedlog, otvoriš drugu temu, s tim da prethodnu vjerojatno nisi ni pogledao, i trazis koju grafu...mislim i sad ti reci da poštuješ nečiji trud...
Staro 14.06.2007., 20:16   #5
PcKinG in da VŽ
Postovi: 14
nisam upoznat s ovi forumom je ja nisa pcking vec njegov frend
MBO: ASUS P3C800
RAM: 1024 MB 400MHz
HDD: 80GB WD Caviar
Staro 14.06.2007., 20:21   #6
Postovi: 34,094
Onda se registriraj po svojim nickom i postavljaj pitanja.
Staro 14.06.2007., 20:40   #7
PcKinG in da VŽ
Postovi: 14
Neki kažu da je 8600gt bolja a neki da je 7900gs pa neznam sto uzet! Što mislite opcenito o mojoj konfi je li u redu?
MBO: ASUS P3C800
RAM: 1024 MB 400MHz
HDD: 80GB WD Caviar
Staro 14.06.2007., 22:11   #8
Stipezd
Stipezd's Avatar
Lokacija: Zd
Postovi: 53
Ajte odgovorite,jel se isplati uzet ovo: Maticna
ili neku drugu maticnu da se dobro clocka s tim procom( e6420 )i jel dovoljan kingmax 800Mhz???
Stipezd je offline   Reply With Quote
Staro 14.06.2007., 22:13   #9
Razer
Razer's Avatar
Postovi: 11,642
Ok izbor, iako bi i P35-DS3 bila dovoljna...inače Kingmax će biti sasvim dovoljan, možeš i 667 uzet, nema razlike...
Staro 14.06.2007., 23:29   #10
Stipezd
Stipezd's Avatar
Lokacija: Zd
Postovi: 53
Ok,fala....
Staro 15.06.2007., 03:58   #11
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
nadalje, ostatak konfe je solidan, osim sto bi vjerojatno bilo isplativije uzet 1x1024 rama, pa kasnije kupit jos jednu istu plocicu s obzirom na cijenu. Osim toga graficka je bolje 7900gs jer se divljacki moze clockati, a i standardno je malo brza u trenutnim igrama od 8600gt, s tim da 8600gt ni s dx10 igrama nece biti upotrebljiva bas.
i mozda ipak neko jace napajanje za buduce potrebe...
Msi x79a GD65
Intel i7 3930k @ 4.7 1.4V
4x 4GB Kingston 1866 9-11-9
Gigabyte gtx 460 1gb
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Coolermaster Stacker 831
HP LP2065 / LG IPS231P
Windows 7 Enterprise
Trenutno nepostojeci
Staro 15.06.2007., 15:46   #12
PcKinG in da VŽ
Postovi: 14
onda definitivno uzimam 7900gs! HVALA!!!!
MBO: ASUS P3C800
RAM: 1024 MB 400MHz
HDD: 80GB WD Caviar
