Staro 12.06.2007., 23:48   #1
domy_os
domy_os's Avatar
Postovi: 18,892
CyberLink PowerCinema 5 Patch 3807
Updated Patch: This patch file updates PowerCinema 5 to version 3807 and enables PowerCinema 5 to fully support Windows Vista 32/64 bits.
Information:
The patch is relevant for users who have experienced the following problems.
Note:
  • This patch is only for PowerCinema 5 Retail users to download.
Update List:
  • Cannot change the location of recorded TV to another drive, i.e. D: or E:.
  • PowerCinema does not launch on a secondary monitor if it was closed on the secondary monitor previously.
System Requirements:
CPU:
Intel Pentium 4 2.6 GHz or higher (higher CPU speed will yield higher video quality)
Memory:
256 MB of RAM (512 MB or more recommended)
Operation System:
Microsoft Windows XP (Home edition or Professional edition)
Microsoft Windows Vista
DirectX 9 or above
Windows Media Player 9 or above
Remote Control (Optional):
Windows XP Service Pack I is required in order to operate the remote control.
Hard Disk:
200 MB of available hard disk space required for installation (500 MB required for running the program, 1 GB of free hard disk space is required for running the TV time-shifting function).
Video Display Card:
DirectX-compatible display adapter for 16-bit colors display (32-bit color displays recommended). When using 3D UI mode, a graphic card with 64 MB or more of video memory is recommended. A 3D display card is required for PowerCinema's transparent menu index.
Audio Card:
DirectX-compatible PCI sound card, USB audio box, or built-in audio device required for audio playback and recording.
Optical Device:
DVD-ROM, DVD-R/RW, DVD-RAM, DVD+R/RW, DVD-Dual, DVD-ROM/CD-RW, or DVD Multi-drive with 1394, USB 2.0, ATAPI, SCSI, or Card Bus interface.
TV Tuner Card:
CyberLink's bundled TV tuner card has been tested and is recommended for use with PowerCinema 5. Windows-compatible analog tuner cards with a WDM driver or a digital/hybrid tuner card with a BDA driver may also be compatible. For a list of compatible tuner cards please click here.
Display:
Windows-compatible display with at least 1024x768 resolution.
Mouse:
Windows-compatible mouse or pointing device.
Download:
http://download.cyberlink.com/ftpdlo...Link.v3508.exe
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
