Staro 10.06.2007., 16:36   #1
toni101
Postovi: 153
što znači snagless
Zna li tko što znači snagless kod utp kabela. Neki belkin kabeli imaju tu oznaku.
Hvala
toni101 je offline   Reply With Quote
Staro 10.06.2007., 18:31   #2
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,527
Autor toni101 Pregled postova
Hvala
Inače postoji dota objašnjenja na ovom linku a ako ti je lijeno evo copy/paste sa jednog od ponuđenih:
Why Use a Cable with a Snagless Molded Strain Relief?
When used in a home distribution panel, all the wires overlapping each other can sometimes get snagged upon removal. When a regular cable's RJ-45 clip gets caught on other wires, it can easily break off when removed from the cabinet. The molded boot not only adds strain relief to the cable but also covers the clip, allowing the cable to be removed from these sometimes-cluttered places with ease. This feature makes these cables ideal for networking and home automation use.
Are Cat. 5e Cables Backwards-Compatible with Older Standards and Accessories?
While these cables are made to handle data rates up to 1 gigabit per second, they easily handle slower data rates and are excellent for voice usage. Use these cables with 10BaseT or 100BaseT network cards and hubs.
Why use Stranded Patch Cables?
A stranded patch cable is made up of multiple wires, each of which has several strands of small copper wires within the insulation sleeve. Stranded cables are more flexible than solid conductor cables, which make them ideal for connecting between components. This construction is great for the flexing and the frequent changes that occur at the wall outlet or patch panel. Stranded conductors do not transmit data signals as far as solid cable.
Solid conductor cables have one larger gauge wire within each sleeve. Solid cable has better electrical performance than stranded cable and has been used for years inside walls and through ceilings. Since these cables are not likely to be disturbed and the runs are usually longer, solid conductor cables make more sense.
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 11.06.2007., 16:26   #3
toni101
Postovi: 153
Hvala LAcy. Ako sam dobro shvatio to je malo ojačan kabel. Vjerovatno je onda i deblji i manje savitljiv tako da ću ipak uzet običan.
Pozdrav
Staro 11.06.2007., 18:22   #4
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,527
Pozdrav
To je kabel koji u slobodnom prijevodu nema kvrga, nije manje savitljiv, malo je deblji i gladak, ljepši
MacBook M1 Pro
MacBook Air M2
Moto Edge
