Staro 27.05.2007., 17:55   #1
Caddy Master
Caddy Master's Avatar
Postovi: 90
Talking konfa za oko 7000 kunica
fred mi uzima novi komp intel c2d obavezno, pa eto ako netko ima malo vremena pa da sastavi nesto. sve bi trebalo biti iz ve-mila, ako nesto nije, nije problem. i da, VGA mora biti s podrskom za DX10.
ekran, mis, tastatura, zvucnici netreba. hvala
konfa je za igranje i gledanje filmova
dobro, ***iga potkrala se greska
Zadnje izmijenjeno od: Caddy Master. 28.05.2007. u 00:12. Razlog: EDIT
Caddy Master je offline   Reply With Quote
Staro 27.05.2007., 20:12   #2
BladeRunner
Type R
BladeRunner's Avatar
Postovi: 1,485
Konfa od 7 000 000 kn?za to možeš uzet deep blue...
David linčujem Davida Finčera
BladeRunner je offline   Reply With Quote
Staro 27.05.2007., 20:27   #3
Tekla
Tekla's Avatar
Lokacija: livno
Postovi: 1,065
sorry zbog spama.
dobar naslov
Tekla je offline   Reply With Quote
Staro 29.05.2007., 15:10   #4
Shinichi
Taiketsu Master
Shinichi's Avatar
Lokacija: Suzuka, Japan
Postovi: 150
@Caddy Master
HDD Seagate ST3320620AS, 320 GB 16MB, S-ATA300, NCQ3, 7200 3 god. 593,00
Gigabyte GF 8800GTS, 320MB DDR3, TV-out, Dual DVI 2 god. 2.316,84
Gigabyte mid tower GZ-X2BPD, bez PS, crno, USB, Fire wire, audio, 2×120mm fan, airduct, instalacija uređaja bez alata, 4×5,25", 6×3,5", 478×185×410mm (dך×v) 2 god. 331,96
MB Gigabyte 965P-DS3, s775, i965, Core 2 Duo ready, FSB 1066/800/533MHz, 6xSerial ATA II, 1xUDMA100, 3PCI, 3PCI-E x 1, 1PCI-E x 16, 4DDR II (Dual channel 800/677/533 MHz), 8-channel Intel High Definition audio, Gigabit LAN, USB 2.0, HT, ATX 2 god. 810,14
DDR2 1GB PC5300 (667MHz) Kingmax 3 god. 253,82
DVD+RW/-RW/RAM LG H42LRBB, DVD+R DL (10x), DVD-R DL (10x), Multi-Format Writing, DVD+RW (8x), DVD+R (18x), DVD-RW (6x), DVD-R (18x), DVD-RAM (12x), CD-RW (32x), CD-R (48x), ATAPI, 2MB buffer, Superlink Buffer Underrun Error Protection, LightScribe, black, bulk 2 god. 249,19
INTEL Core 2 Duo E6600 BOX, (2×2.4GHz, 1066MHz, 4MB), 65nm, Socket 775, Conroe 3 god. 1.691,02
Power Supply FORTRON 400W, HQ, PFC, 2 x 12V, 12cm fan, 24pin konektor 2 god. 313,00
UKUPNO: 6.812,79
Shinichi je offline   Reply With Quote
