Staro 01.12.2003., 14:56   #1
sbp
PC Ekspert
Datum registracije: Sep 2000
Postovi: 377
Dynamic disk (??? koji vrag...)
Alo ekipa,
Ajmo, vi ste pametni, dajte mi pomozite. Stvar je ovakva...
U stroj sam usteko drugi hard (nikakav raid, obicnjak master/slave IDE)... Taj drugi hard je neko staro dzubre, vjerojatno isparticionirano, nemam pojma koji fs
Windoze ga vide ko "Dynamic disk" - nemre se nis s njim radit (nemres formatirat/otvorit u partition magicu itd itd). Kaj s tim radit? (Kak isformatirat)?
Probo sam prek system tools-a (disk management), i tam ima opcija "Convert to basic disk" koja nis ne napravi...
Pomagajteeeee...
Zaboravih rec, Windoze XP SP1a (Masina je p4b 2.4, i845g)
sbp je offline   Reply With Quote
Staro 01.12.2003., 15:22   #2
Elven
Elven's Avatar
Datum registracije: Sep 2002
Postovi: 2,721
Evo što kaže TechNet
Back up all the data on all the volumes on the disk you want to convert to a basic disk.
Log on as Administrator or as a member of the Administrators group.
Click Start, and then click Control Panel.
Click Performance and Maintenance, click Administrative Tools, and then double-click Computer Management.
In the left pane, click Disk Management.
Right-click a volume on the dynamic disk that you want to change to a basic disk, and then click Delete Volume.
Click Yes when you are prompted to delete the volume.
Repeat steps 4 and 5 for each volume on the dynamic disk.
After you have deleted all the volumes on the dynamic disk, right-click the dynamic disk that you want to change to a basic disk, and then click Convert to Basic Disk.
NOTE:You must right-click the gray area that contains the disk title on the left side of the Details pane. For example, right-click Disk 1.
Staro 01.12.2003., 15:29   #3
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
WTF is Dynamic disk?!
Staro 01.12.2003., 15:37   #4
Elven
Elven's Avatar
Postovi: 2,721
www.microsoft.com/technet
upiši Dynamic Disk, traži, čitaj.
Iskreno, nemam ni ja pojma
Staro 01.12.2003., 16:28   #5
sbp
PC Ekspert
Postovi: 377
Da, bilo bi super kad bi mi dao opciju "Delete volume" (koju naravno ne daje). Da samo "Convert to basic disk" koja kad se klikne, nis ne napravi (ko sto sam vec izlozio)...
GROOAAR
Staro 01.12.2003., 16:44   #6
Elven
Elven's Avatar
Postovi: 2,721
Ovaj note se odnosi na delete volume ili convert to basic disk?
Ne znam, nisam pokušavao, možda je to u pitanju :confused:
Staro 01.12.2003., 17:20   #7
sbp
PC Ekspert
Postovi: 377
Hijao, pa ipak takav tuljan nisam da neznam di kliknut
Ma nije bio problem u "right clicku" neg u tome kaj technet to super objasni...
Naime, opravio sam nakon kaj sam sam iso pimplat. Radi se o tome da je disk bio formatiran, al neznam dal je bio particioniziran (uhh, jel sam dobro ovo spelovo?), i da mi ga je pokazivo ko 4GB volume unutar explorer-a...
Kad sam probo bilo kaj radit sa partition magicom/xp-jevim disk managerom, nikakve opcije nije davo (odnosno, manager je davo opciju "Convert to basic..." koja nije nis radila)
Onda sam oso u command prompt, uzo diskpart, i s njim probo prvo konvertirat, ali nis od toga, onda sam napravio "Clean disk", pa "Create volume", i onda "Convert to basic" i proradilo
Inace, Dynamic Disk je novi super-duper feature XP-ja (i 2-hiljadarke) - kao, "bezbolno i brzo sredjivat/uredjivat vise diskova" - mos mislit!
Staro 01.12.2003., 17:29   #8
mitzek
Prigorec po defaultu
mitzek's Avatar
Lokacija: Pušća Gornja
Postovi: 1,410
Talking inace...
he-he....ja donio jedan takaf Hojzi.......u al me je na sva kola izpsoval!!!!
mitzek je offline   Reply With Quote
Staro 01.12.2003., 17:47   #9
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
Super ultra dupa fičur...Moš mislit.
Staro 01.12.2003., 21:41   #10
msvrtan
Datum registracije: Oct 2001
Postovi: 2,735
cekaj kaj nije dynamic disk fora da od vise diskova napravis jedan? nekakav softwarski raid...
po meni je guba fora ako imas 10 diskova od 4 gb a treba ti jedan od 40gb..ne zbog brzine nego da dobijes suprotan ucinak particioniranju...
msvrtan je offline   Reply With Quote
Staro 01.12.2003., 23:01   #11
horza
ono ispred konpjuktora
horza's Avatar
Datum registracije: Apr 2003
Postovi: 3,659
dynamic disk je naziv za tip diskova koji se koriste u raid poljima... mitzek nisam ti ja preklel zato kaj nemrem niš s njim, nego zato kaj ti je to sistemski pa ti je trebal.
XP i 2K imaju opciju izrade dynamic diskova. njima je to potrebno zbog jedne funkcije koja radi SAMO na Win2kServer, 2k3Server i ostalim serverskim izdanjima. to je disk mirroring. dakle, kada nemamo raid kontroler (niti onboard niti pci), nego obične ide kanale pomoću mirroringa se može složiti "virtualni" raid. veliki nedostatak je kaj to kolje procesor. to govorim iz iskustva jer sam prije cca 6 mjeseci to pokušavao složiti na običnim win2k i nije htjelo... kad ono vidi vraga radi samo na serverima.
i normalno da ni partition magic niti išta slično to ne vidi jer nema partition table-a. dakle, ako ga oš' nazad u basic disc trebalo bi to napravit onak kak sbp-u nije uspjelo (nemam pojma zakaj... si probo magnetom
Staro 02.12.2003., 12:21   #12
Elven
Elven's Avatar
Postovi: 2,721
Kak nisam imao pojma na što se odnosi taj note, nisam ni mogao znati jer to pametan note. sorry
Kao i mnoge druge stvari
