Zaključane teme
Staro 09.05.2007., 21:49   #1
HondaFreak
Postovi: 58
Powercinema overwrite with pcm?!
Pise: Download trial, extract/unrar package to a temporary folder and overwrite original file with included PowerCinema.pcm.
Then install application.
If you have already installed the package, just navigate to the location of the file and overwrite it.
Now you have full version and you get online radio as a bonus.
pa mi sad nije jasno kak to overwrite-at. pokusao sam ali nemogu jer se file ne zove isto i nije isti, tako da bi molio pomoc ako je moguce?!
HondaFreak je offline
Staro 09.05.2007., 21:51   #2
Facelessone
Facelessone's Avatar
Postovi: 4,203
khmmm, ovo ti je malo siFkasta zona...
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Facelessone je offline
Staro 09.05.2007., 22:10   #3
domy_os
domy_os's Avatar
Postovi: 18,809
Jesi nesposoban, to je barem jednostavno... Tko ne zna crackati, jaše na bananama...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
domy_os je offline
Staro 09.05.2007., 22:29   #4
Facelessone
Postovi: 4,203
Imaš objašnjenje tu, ak neko pita, nisam ti ja dal taj link LINK
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Zaključane teme
