Staro 05.05.2007., 13:30   #1
BOGDO
klanfa
BOGDO's Avatar
Lokacija: ZG-Dubrava
Postovi: 494
Asus MW201U 20"
Kaj mislite o ovom lcd-u?
Monitor LCD ASUS MW201U, 20" WSXGA+ (1680x1050), 0,258 Pixel Pitch, 300cd/m2, kontrast 700:1, kut gledanja 176/150, vrijeme odaziva 2ms, D-sub, DVI-D digital, stereo zvučnici
Panel Size: 20.1" Wide Screen
True Resolution: WSXGA+ 1680 x 1050
Pixel Pitch: 0.258mm
Brightness (Max.): 300cd/㎡
Contrast Ratio (Max.): 700:1
Viewing Angle (CR≧10): 170°(H)/150°(V)
Display Colors: 16.7 M
Response Time: 2ms (Gray to Gray)
Trace Free Technology: Yes
SPLENDID™ Video Intelligence Tech: Yes
SPLENDID™ Video Preset Mode: 5 modes
Skin-Tone Selection: 3 modes
Color Temperature Selection: 3 modes
HDCP: Yes
Stereo Speaker (built-in): 1W x 2 stereo, RMS
SPLENDID™ Video Preset Mode Select: Yes (5 modes)
Auto. Adjustment: Yes
Brightness Adjustment: Yes
Volume Adjustment: Yes
PC Input: DVI-D & D-Sub
PC Audio Input: 3.5mm Mini-jack
Earphone Jack: 3.5mm Mini-jack
Analog Signal Frequency: 30~86 KHz(H) / 55Hz~75 Hz(V)
Digital Signal Frequency: 30~83 KHz(H) / 56Hz~75 Hz(V)
Power ON: < 65W
Power Saving Mode: < 2W
Chassis Colors: Black + Silver
Tilt: +20° ~ -5°
VESA Wall Mounting: 100 x 100mm
BOGDO je offline   Reply With Quote
Staro 06.05.2007., 15:15   #2
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
za 2100kn koliko kosta doticni ne mozes dobiti bas bog zna sto. Monitor je relativno los, no ako je to novcani limit do kojeg se moze ici onda ok
Monitor ima TN matricu te samim time je ogranicen po pitanju boja koje moze prikazat (18-bit umjesto 24 kod drugih matrica - 262k naprama 16m), ono je marketinski trik samo s interpolacijom na 16m, ne funkcionira bas!
osobno bi skupio jos malo novca i uzeo neki bolji monitor manje rezolucije radije..
Msi x79a GD65
Intel i7 3930k @ 4.7 1.4V
4x 4GB Kingston 1866 9-11-9
Gigabyte gtx 460 1gb
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Coolermaster Stacker 831
HP LP2065 / LG IPS231P
Windows 7 Enterprise
Trenutno nepostojeci
