Staro 30.04.2007., 12:18   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Intel releases critical Core 2 Duo microcode update - Silently
Samo za info.
Ako je već negdje postano nek mod pobriše.
Around April 10th, 2007, Intel released a microcode update (BIOS flash to the rest of us) so resolve several major issues with how Intel Core 2 series processors operate.
Intel has provided a microcode update as a critical software fix. This Intel microcode update addresses an improper Translation Lookaside Buffer (TLB) invalidation that may result in unpredictable system behavior such as system hangs or incorrect data. OEM's are making available a system BIOS upgrade that integrates a new version of this Intel microcode to address this potential but extremely rare issue. While the occurrence of this issue is extremely rare, OEM's strongly recommends upgrading the system BIOS to an updated version. Intel has indicated that the microcode update has no known measurable performance impact and provides a complete and comprehensive resolution to this issue.
The issues can affect any workstation that uses Intel Core2 Duo desktop processor E4000 and E6000 sequences, Intel Core2 Quad desktop processor Q6600 and Intel Core2 Extreme processors X6800 and QX6700 processors.
While the implications of the issue are difficult to quantify, any of the following symptoms can occur:
The system may stop responding to keyboard or mouse input.
A system operating in a Microsoft Windows environment may generate a blue screen.
A system operating in a Linux environment may generate a kernel panic.
Watch for BIOS updates for your motherboards!
http://www.rage3d.com/board/showthread.php?t=33889728
Staro 30.04.2007., 12:26   #2
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,784
Autor Jelc Pregled postova
/snipsnipsnip
Fala qurcu, mozda napokon srede PS/2 keyboard issue na BadAxe 2 plocama...
Programer
Staro 04.07.2007., 15:51   #3
brajko2
Postovi: 77
Vidiš - vidiš.. dobro da je još vidljiv ovaj stari post. Jer je prije 10ak dana microsoft izdao zakrpu za izgleda ovaj problem. Ali očito je pitanje da li i dalje sve radi o.k....
brajko2 je offline   Reply With Quote
Staro 04.07.2007., 16:24   #4
As Hope Dies
Postovi: 38
Gdje se moze nabaviti MSov patch bez verifikacije?
As Hope Dies je offline   Reply With Quote
Staro 04.07.2007., 17:11   #5
domy_os
domy_os's Avatar
Postovi: 18,914
Staro 04.07.2007., 17:44   #6
As Hope Dies
Postovi: 38
Pa nije to warez request
Svi MSovi patchevi su potpuno besplatni, no ne zelim instalirati WGA samo zbog toga.
No stogod, vjerujem da ce biti u autopatcheru(koji je isto 100% legalan)za kojih tjedan dana.
Zadnje izmijenjeno od: As Hope Dies. 04.07.2007. u 17:55.
Staro 05.07.2007., 20:09   #7
Ph03n1x
Ph03n1x's Avatar
Lokacija: Varaždin/Zagreb
Postovi: 1,846
zanemarite ovaj post. odgovarao sam bubbi, a da nisam zamijetio da je post star preko 2 mjeseca
Ph03n1x je offline   Reply With Quote
Staro 05.07.2007., 20:15   #8
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,784
Autor Ph03n1x Pregled postova
Star 2 mjeseca ili ne, kod mene je problem jos uvijek aktualan, tako da...
Programer
Staro 05.07.2007., 20:19   #9
Ph03n1x
Ph03n1x's Avatar
Postovi: 1,846
u biti...vise je bio komentar nego neki konstruktivan odgovor
prvi put cujem za problem s ps2 tipkovnicama i misevima s obzirom da imam badaxe 2 vec skoro pola godine i nikad nisam zamijetio problem, pa me zainteresirao tvoj post...detaljnije?
