Staro 26.04.2007., 01:04   #1
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
"HTPC" za muziku, divx i DVD filmove? (Celeron 566)
Znaci ovak, nabavih za 100 čunas par starih komponenata. Od toga sam mislio napravit kao neki HTPC, al neznam jel ce to vrtit.
Posto mi je riko telkac, mislio sam slozit nekaj da vrti DVD, divx i muziku. CRT necu, a za LCD nemam love.
Dakle konfa je:
Proc - Celeron 566MHz (coppermine)
MB - MSI
RAM - 256MB PC 133
Grafa - GeForce2 MX400
HDD - 30GB WD
Zvucna - Pikirat cu SB Live ili Audigy SE (jos jednu )
Kuciste - Nemam jos (kupio bi neko slim, pa cu ga malo zmodat)
Monitor - 17" CRT Proview
EDIT: Kuciste bi vjerovatno uzeo ovo:
http://www.frontier.com.tw/htm/product/18a/OPERA.htm
2x 12cm unutra i ostatak pasiva.
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 26.04.2007., 03:02   #2
CatKiller
al se nekad dobro jelo...
CatKiller's Avatar
Postovi: 3,312
Jučer sam bio sa prijateljem u Metrou i kupio si je Elta DVD player koji uz klasične konektore (SCART, Component, Composite) ima i VGA out, spojili na monitor i super radi, podržava USB Host i ima 3-in-1 čitač za mem kartice.
Player je glossy crn i ima amber rasvjetu pa izgleda miljama skuplje od 200kn.
Godina dana garancije, a ako vrisne nakon toga, nije neki gubitak.
Hoću ti reći > Ako si ograničen buđetom, kupi ovo gore i spoji USB HDD na player, lako punjenje podacima i ne trošiš medije. Ispunjava sve tvoje uvjete, doduše nije PC, ali to nije nužno loše s obzirom na namjenu
Staro 26.04.2007., 07:36   #3
daytripper
Ultrabitchinfast
daytripper's Avatar
Postovi: 880
Mislim da hdd nede gore, ako se ne varam.
http://forum.pcekspert.com/showthread.php?t=61628
daytripper je offline   Reply With Quote
Staro 26.04.2007., 07:47   #4
horza
ono ispred konpjuktora
horza's Avatar
Datum registracije: Apr 2003
Postovi: 3,659
Uz ovo što je ketkila reko, MX400+30GB WD+Celeron 566MHz kada ih opteretiš reprodukcijom divx-a uz malo postprocessinga na 1280x1024 ćeš dosta teško hladiti isključivo pasivom. a iskreno, za HTPC mi je čak i 2x120mm bučno... IMHO.
Horza (death dwarf)
birthsign: rebel
character perks
major skills
greater powers
artifacts of choice
Staro 26.04.2007., 08:38   #5
Panzer
Panzer's Avatar
Postovi: 1,814
Autor horza Pregled postova
Znaci vrtit ce kanta to? Nisam jos imao tak slab proc, tak da neznam.
Inace, na 1024x768 ce vrtit.
Jucer sam slozio konfu na stolu za mali test, radila je nekih 15-20min, bez ikakvog venta i temp je dosla do 40.
2x12 mi ziher nece bit glasno, s obzirom kak je glasna sadasnja kanta.
Onak, hrpa ventova+bucno napajanje.
Ovo kaj je ketkilla reko mi ne odgovara jer imam vec DVD, tak da mi je bezveze uzimat jos jedan. USB HDD nemam pa bas i da ide na taj DVD player, znaci jos dodatni trosak.
UPGRADED...
Staro 26.04.2007., 10:16   #6
CatKiller
CatKiller's Avatar
Postovi: 3,312
Autor Panzer Pregled postova
Samo ubaci ovaj maxtor 30Gb u vanjsko USB kuciste.
Staro 26.04.2007., 10:28   #7
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
Uz dovoljno velik hladnjak na procu ce ti i samo 120mm na desnoj strani (kod proca) biti uvrh glave. Ostalo sve pozacepljuj. Koliko sam shvatio, napajanje uvlaci zrak, right? Koliko se grije disk?
Staro 26.04.2007., 15:34   #8
Panzer
Panzer's Avatar
Postovi: 1,814
Autor Matesonik Pregled postova
Hladnjak je Thermaltake Volcano 6Cu+. Mislim da bi trebalo to na pasivno ic jer proc ima TDP od 11.9 W. Jos mozda i manje jer mu je voltaza spustena. Vjerovatno cu danas stavit windoze gore, da vidim kak to radi.
Iskreno, neznam za napajanje, i kolko se grije HDD.
UPGRADED...
