Staro 18.04.2007., 01:32   #1
Newmie
Postovi: 1,396
Konfa do 5000kn!
Sastavio sam neku konfu pa bi vas molio da prokomentirate... dali se treba nesto mjenjati..
Uvjet je da sve treba biti iz Ve-mila i do 5000 kn bez periferije!
dakle:
CPU: AMD Athlon64 4000+ BOX, SckAM2
MBO: MB Gigabyte M55plus-S3G, sAM2, GeForce 6100, VGA, SATA, FW,GLAN
RAM: DDR2 1GB PC6400 (800MHz), SuperTalent, CL5
HDD: HDD HITACHI HDT722525DLA380 250GB SATA-300 7200rpm 8MB
VGA: Gainward BLISS 7900GS, GF 7900GS, 256MB, PCI-E, TV-out, DVI
Kuciste: Thermaltake mid tower Soprano, bez PS, crno, USB, Fire wire, 2×120mm fan, 1×90mm fan, prozor
Napajanje:
Chieftec power supply 450W, ATX 2.0, 2×12V, Active PFC, AFC, 12cm fan, 2×SATA connectors
Hvala!
Staro 18.04.2007., 02:52   #2
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
Ja ti preporucam Intel konfu ko i vjerojatno vecina ostalih. Ja bi za malo preko 6 k iso sigurno na ovak nekaj:
2x DDR2 1GB PC5300 (667MHz) Kingmax 399,86
MB Gigabyte 965P-S3, s775, i965, DDR II, SATA II, GLAN 763,78
Intel Core 2 Duo E4300 BOX, 2×1.80GHz, 800MHz, 775-pin, 2MB 1.079,00
HDD HITACHI HDT722516DLA380 160GB SATA300 7200rpm 8MB 395,44
DVD+RW/-RW Pioneer DVR-111DBK, Dual Layer, 16x, black, bulk 259,00
Gigabyte GF 8800GTS, 320MB DDR3, TV-out, Dual DVI 2.316,84
Chieftec power supply 450W, ATX 2.0, 2×12V, Active PFC, AFC, 12cm fan, 2×SATA connectors 375,00
Thermaltake mid tower Mambo, bez PS, crno, USB, audio, 1×120mm fan 335,70
Ukupno: 6324,48 za gotovinu
Jer mi se cini da ova S3 ploca nije uopce losa za OC a jeftinija je od P5B za oko 300kn.
http://www.xbitlabs.com/articles/mai...965p-s3_6.html
Ti mozes ustediti na grafi zbog novcanog ogranicenja i uzet onu koju si napisal i ispadne te oko 5k ili
Gigabyte Radeon X1950Pro 256MB DDR, PCIE, TVout, Dual DVI 1.320,10
ili
Point Of View GF 7900GS, 256MB, PCI-E, TV-out, 2 x DVI 1.233,36 sa ovom karticom umjesto GTS Ukupno: 5241 za gotovinu
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 18.04.2007., 08:52   #3
Postovi: 34,041
Umjesto chiefa uzmi Fortron PNF 350W i razmisli je li ti baš potrebna ploča sa integriranom grafom. Isto tako razmisli o uzimanju Kingmax 667 meme. I to 2 keksa po 1Gb.
Staro 18.04.2007., 10:50   #4
Newmie
Postovi: 1,396
Hvala!
Ma to u biti sastavljam za frenda pa onda moram vidjeti kako ce on to komentirati!
Sto se tiče integrirane grafe, naravno da ne treba, nisam to ni vidio...
Staro 18.04.2007., 11:42   #5
Postovi: 34,041
Ploče koje u svom imenu na kraju imaju slovo G znači da imaju integriranu grafu. Vidi malo sticky 'AM2 zrelo voće' jer su dečki tamo radili isto s nekom Gigabyte-icom koja je rasturala, a jeftina je.
