Staro 28.10.2003., 14:21   #1
Bl@de
Bl@de's Avatar
Lokacija: Ispred kompa
Postovi: 2,004
Nero Speed update
Dakle ako vam je smetalo da nero pise samo brzinu pisanja koju ste odabrali sa ovime mozete vidjeti svarnu brzinu. Link sam izgubio pa cu prenjeti samo ono kak se postelava.
Changing a setting in the Registry you may obtain the REAL TIME
speed buring with Nero! Here is how to do it:
1.Start Regedit
2.Go to 'HKEY_CURRENT_USER\Software\ahead\Nero - Burning
Rom\Recorder'
3.Search for DWORD 'ShowSingleRecorderSpeed' item
4. Right-click it and select "Modify"
5.Change the value from "0" to "1"
That's all! Now when you burn with Nero you should be able to see the speed varying in real-time.
Ak nemate "ShowSingleRecorderSpeed" jednostavno ga napravite u tom dir i radi ko beba.
Intel i5 4670k
ASrock Z87 Extreme 3
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
OCZ SSD Vertex 4 - 128 GB
Samsung T166 500 GB 7200 okr/min 16 MB HD501LJ
Samsung F1 1 TB 7200 okr/min 32 MB HD103UJ
Dell S2522HG
Chieftec DX-01BD-V, Corsair 520W CMPSU-520HXEU
Bl@de je offline   Reply With Quote
Staro 28.10.2003., 15:38   #2
choby
Postovi: 1,178
čovjeka vesele takve sitnice...
choby je offline   Reply With Quote
Staro 28.10.2003., 16:42   #3
Bl@de
Bl@de's Avatar
Postovi: 2,004
I sitno je bitno!!
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 28.10.2003., 18:00   #4
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,962
Odlično. Radi, efo ti piva
Staro 28.10.2003., 22:10   #5
horza
ono ispred konpjuktora
horza's Avatar
Datum registracije: Apr 2003
Postovi: 3,659
ajd evo jedna i jedan princo da ne ostanu tragovi na stolu :-)
Horza (death dwarf)
birthsign: rebel
character perks
major skills
greater powers
artifacts of choice
Staro 28.10.2003., 22:19   #6
Bl@de
Bl@de's Avatar
Postovi: 2,004
Tnx Horza za pifce ali princo mi ne treba imam cijeli set. Mogao bi ih prodavati po sest komada u kutiji u dvije razlicite boje, onoj "normalnoj" srebrnoj i "istrosenoj" zutoj.
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 30.10.2003., 20:05   #7
medo
#erase startup-config
medo's Avatar
Postovi: 3,623
ili za one koji vole samo dva puta kliknuti...
i još kada bi dečko tko je započeo thread pazio na velika i mala slova, pa onda ja ne bi morao editirati svoj post i pitati se: "a zakaj to meni ne dela..."
File Type: zip nero pokazi brzinu snimanja.zip‎ (266 byte, 144 views)
Zadnje izmijenjeno od: medo. 30.10.2003. u 20:34.
Staro 30.10.2003., 20:19   #8
>>>KUKY<<<
>>>KUKY<<<'s Avatar
Lokacija: Vinkovci
Postovi: 1,055
Medo da si zensko poljubio bih te
Sig mi nije u skladu s pravilima.
>>>KUKY<<< je offline   Reply With Quote
