Staro 02.03.2007., 02:03   #1
deToNaTor
AMD XP2800+ (2412MHz)
deToNaTor's Avatar
Lokacija: ST
Postovi: 74
Nemogu patch-at heroje 5?
Instalira sam ''Heroes of Might & Magic V; Release version 1.0, May, 2006'' i tija sam instalirat patch 1.01, 1.2, 1.3 i 1.4, ali nemogu svaki put mi izbaci ''heroes of might and magic V is not installed.Patch cannot be applyed.''
Neznam sta da radim i kako da instaliram patch-eve, please pomozite.....
T-N-T
Formula : C7H5N3O6 ; Boiling pointecomposes at 295°C
MW (g/mol) : 227 ; Melting point: 81°C
DEf (kJ/mol) : -54.39 ; Explosive velocity: 6,900 m/s
deToNaTor je offline   Reply With Quote
Staro 06.03.2007., 15:43   #2
Big Guy
RPG player
Postovi: 1,574
možda ovo
"Installation Information
Please make sure that you install the right patch for your game version!
If you downloaded your copy of the game from Direct2Drive, you will need to install the [D2D Download Version] patch. If you downloaded your copy of the game from Boonty, you will need to install the [Boonty Download Version] patch.
If you have the US CD/DVD version of the game, you will need to install the [Retail CD / DVD Version] patch."
sa http://www.ubi.com/US/Downloads/Info.aspx?dlId=1628
ako nije ono iznad onda
- probaj reinstall i onda patch
ili
- uninstall i install u drugi folder/particiju/disk
I hate to see you leave, but I love to watch you go
Big Guy je offline   Reply With Quote
Staro 06.03.2007., 19:59   #3
Paske
Ekspert iz sjene ...
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
ILI - si crackal igru, jerbo NEMAŠ original, u kojem slučaju je preporuka Algoritam ili Crovortex ili neko treće riješenje ....
Staro 06.03.2007., 21:51   #4
Chuby
Chuby's Avatar
Datum registracije: Feb 2004
Postovi: 1,309
Da ne koristis crack mogao bi patchat
imaj to na umu i upotri***i kak hoces, ak nikak drugacije odi u Algoritam
Chuby je offline   Reply With Quote
