Postovi: 8
toshiba ili hp
toshiba A100-847 Zaslon15,4" WXGA LCD Toshiba TruBrite TFT display Rezolucija 1280x800 ProcesorIntel® Core™2 Duo Processor T7200, 2.0 GHz Front Side Bus : 667 MHz 2nd level cache : 4 MB HDDHard Disk 100 GB Optički uređajDVD Super Multi drive (Double Layer) Memorija512 MB DDR2, (533 MHz) Nadogradivo do 4 GB GrafikaOdvojena, NVIDIA® GeForce™ Go 7600, 256 MB Fax modem56 Kbps V.92 Mrežna karticaEthernet LAN 10/100 Base- TX Intel PRO/Wireless 3945ABG Multimedia16-bit stereo Harman Kardon® stereo zvučnici Toshiba Bass Enhanced Sound System with SRS® TruSurround XT™ System and SRS® WOW I/O1 x DC-in, 1 x external monitor, 1 x RJ-11, 1 x RJ-45, 1 x TV-out (S-video), 1 x i.LINK® (IEEE 1394), 1 x external microphone, 1 x headphone (stereo), 4 x USB 2.0, 5-in-1 Bridge Media slot (supports SD™ Cards, Memory Stick®, Memory Stick Pro™, MultiMedia Card™, xD-Picture Card™), PC Card slot for 1x Type II card, type : Express Card™ slot Dimenzije360 x 267 x 29.8 (front) / 36.8 (back) mm Masa2.72 kg OSMicrosoft® Windows® XP Home Edition OstaloIntegriran Bluetooth ili hp nx9420 (RH436EA) Zaslon17" WSXGA+ TFT 1440 x 900 rezolucija ProcesorIntel Core 2 Duo T5500 1,66GHz, 2MB L2, 667MHz HDD80 GB, 5400 rpm Optički pogonDVD+/-RW Dual Layer Memorija512MB DDRII 667MHz Nadogradivo do 4 GB GrafikaOdvojena, ATI Mobility Radeon X1600 256 MB memorije Fax modem56K Modem Mrežna karticaBroadcom Gigabit 10/100/1000 Intel® Wireless LAN 802.11a/b/g MOW2 MultimediaSound High Definition, Audio 24 Bit Audio DAC Integrirani stereo zvučnici I/ORJ 11, RJ 45, 4 x USB 2.0, VGA, S-Video-TV, IEEE 1394a, priključak za docking, 7-in-1 Media Reader,audio ulazi/izlazi, PCMCIA Type I/II PC Card Dimenzije393 x 275 x 33 mm Masa3.35 kg OSMicrosoft® Windows® XP Home OstaloIntegriran Bluetooth modul! Integrated TPM Security Module 8-cell Lithium-Ion battery Treba mi i za igre osim ostalog,da napomenem da ću ga prenositi,ne toliko često ali ipak par puta godišnje,avioni,busevi itd,i biti će dosta izložen vibracijama,ili možda imate neki bolji model do 10000kn,napominjem da bi i igrao na njemu.Hvala |
Datum registracije: Mar 2002
Postovi: 258
ovo ti malo prelazi granicu ali kad se radi o prenošenju daleko je izdržljiviji od ova dva. može se nači i po 12000kn http://www.mikronis.hr/shop/item.asp...=4376&catid=16 ili ovaj http://www.mikronis.hr/shop/item.asp...=4762&catid=16 |
Postovi: 8
Stvarno su dobra oba 2 koja si mi ponudio,nisam uopće gledao IBM nekako su me odbijali,ali vjerojatno su najkvalitetniji,imaju dobru rezoluciju,mogao bi se malo strpiti pa vidjeti za onaj od 12000.hvala. |
Suit up!
Postovi: 5,977
Meni tošibe imaju ljepši ekran od HP-a (iako imaju onaj filter). No HP je manje delikatan što se tiče izrade.
Postovi: 258
toshiba ima sigurno bolji ekran ali je sjajan šta dosta smeta pogotovo kad se radi na bateriji i kad je osvjetljenje slabije. toshiba definitvno izgleda najljepše ali jednostavno je "premekana", bar za moj ukus. poklopac je tako slab da možeš dotaknuti matricu kad malo jače pritisneš (nije ni HP puno bolji) i vidjeti dugine boje na ekranu. tako nešto se na IBM-u neče dogoditi, pogotovo ne na z61m sa titan poklopcem. meni je izrada uvjek bila prije dizajna i nakon thinkpad-a sve mi izgleda loše. @lemaan savjetujem ti da otiđeš negdje pogledati te laptope u živo, pogotovo z61m jer zbog tog titan poklopca izgleda odlično |
Postovi: 8
Bio sam danas u vemilu baš pogledati taj IBM,bila je gužva a nisam imao vremena,ali mogu ti reći da sam se zapalio za taj ibm.Nije problem u nošenju,nosim ga svaka 2 mj onda opet miruje tih 2mj,jedino vibracije(brod),ostalo nije frka.Možda stvarno uštedjeti još malo pa na ibm,dobra je rezolucija. |
Postovi: 10,805
ako bi išao iskeširat tolko love, onda bi mi taj ibm bio pri vrhu definitivno. |
