Staro 21.02.2007., 18:51   #1
domy_os
domy_os's Avatar
Postovi: 18,894
ATi Tray Tools 1.3.6.1000 Beta
What's New:
  • Updated existing translation files
  • Added Polish translation
  • Updated Advances Tweaks databases
  • Fixed procedure to collect monitroing sources from ATT in "MotherBoard Sources" FlashOSD Plugin
  • Fixed current 3D profile detection in non CCC compatible mode
  • Updated Monitoring Graphs module to support external plugins. This excellent idea was first implemented in RivaTuner by Unwinder. ATT and RT plugins are incompatible
  • Added example Monitoring Graphs plugin "Memory Monitor". Which can monitor global memory statuses like Memory Load %, Physical memory Available, Page File usage, Virtual memory usage. Source code included
  • Added monitoring pluginsd "HDD Temperature". Allows to monitor temperature of HDD disks via S.M.A.R.T.
  • Updated plugins SDK to support new monitoring graphs plugins
  • Minor GUI updates
  • Updated Driver level Overclocking support for RV560/RV570 boards
  • Added test support for voltage regulation on X1950XTX boards
  • Added monitoring plugin "X1xxx Voltages" to provide monitoring sources for GPU/Mem voltages
  • Updated installation interface
  • Added new configuration option. "Disable using OverDrive in "Driver Level" overclocking mode". This option can be useful if your video board has support for OverDrive, but ATT unable to overlock using "Driver Level" mode. Can be changed in atitray.ini or at installtion process
  • Updated Overdrive 3 support detection procedure
  • Updated Core Names database. Added infotmation about RV610/M74/M72/M76/RV630 chips
  • Updated registry handling function under CCC compatibly mode
Download Link:
http://atitray.fangel.ru/b1/attsetup.exe
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Zadnje izmijenjeno od: domy_os. 23.02.2007. u 23:22.
Staro 21.02.2007., 20:53   #2
Salih
Salih's Avatar
Lokacija: BiH
Postovi: 50
thnx, care
PC:
E2180@Freezer7
Asus P5QL/EPU@3gb ram
ECS 8800GT@accelero s1
WD200GB, Frontier Shinobi
Samsung 22" P2250 fullHD
Notebook:
Acer aspire one d250
Salih je offline   Reply With Quote
Staro 21.02.2007., 22:41   #3
domy_os
domy_os's Avatar
Postovi: 18,894
Nažalost, još uvijek ne radi na Visti...
Staro 21.02.2007., 22:49   #4
Mirko Z. Genije
lep
Lokacija: Zagreb, Ravnice
Postovi: 119
Znači li ovo da će se moći bolje oc 1950pro?: stoopid
Mirko Z. Genije je offline   Reply With Quote
Staro 21.02.2007., 23:00   #5
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Autor Salih Pregled postova
thnx, care
Je li ti rijesilo problem sa onim ventilatorom?
Staro 22.02.2007., 14:07   #6
Salih
Salih's Avatar
Lokacija: BiH
Postovi: 50
Autor SRV Pregled postova
nazalost nije : hitthewa, ali sam se bio obradovao mislio sam mozda to bude rijesenje al nazalost nista od toga
PC:
E2180@Freezer7
Notebook:
Staro 22.02.2007., 14:38   #7
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Pa jel puno galami?
Staro 22.02.2007., 15:15   #8
Salih
Salih's Avatar
Lokacija: BiH
Postovi: 50
Pa jel puno galami?
Ma kako sam kupio napajanje i stisao ventove na 7v i 5v, one tt, fino je podnosljivo, samo ima jedna cinjenica da nema grafe nebi se cuo da radi : lol2 :
PC:
E2180@Freezer7
Notebook:
Staro 22.02.2007., 15:34   #9
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Nema sanse, TT ventovi se i ugaseni cuju. Trebas jednom doc do mene da cujes(tj. ne cujes) sta je tisina
Staro 22.02.2007., 15:37   #10
domy_os
domy_os's Avatar
Postovi: 18,894
Treba pričekat finalnu verziju, možda se srede stvari...
Staro 22.02.2007., 15:47   #11
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Autor domy_os Pregled postova
Ma njegovoj grafi nema pomoci : lol2 :
Staro 22.02.2007., 17:48   #12
strikoo
strikoo's Avatar
Postovi: 986
Ni ja ne mogu na svojoj vent mrljavit. Također je najglasniji u kućištu...
acelero... kao to bi trebalo biti tiho...mh mh
strikoo je offline   Reply With Quote
Staro 22.02.2007., 20:25   #13
Salih
Salih's Avatar
Lokacija: BiH
Postovi: 50
Ma ja kako sam cuo, cak dobio informacije od W1zzarda (on je programirao ATi Tool) kako se na toj grafi pokusalo ustjedeti i nije ugraden temp. senzor niti se na onovu toga moze regulisati brzina vrtnje, tj dzabe software bez harware-a na grafi, ondosno dzabe i finalna verzija kad nece moci pomoci da se vidi temperatura i da se regulise brzina vrtnje vent.
a "STRIKOO" bas me cudi svi kazu kako je acelero taj veoma tih cak tisi od vf900
PC:
E2180@Freezer7
Notebook:
Staro 22.02.2007., 20:34   #14
domy_os
domy_os's Avatar
Postovi: 18,894
Salih, ti znači nemaš senzora za temperaturu na toj grafi?
Staro 22.02.2007., 21:11   #15
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
LOL ustedjeti : lol2 :
VF900 je tih samo kad se stavi neki tih 80mm vent, ako cemo o tisini. Stock vent na VF900 bas i nije tih(no vecini ce svejedno bit tih).
Staro 22.02.2007., 21:11   #16
Salih
Salih's Avatar
Lokacija: BiH
Postovi: 50
Tako je, nazalost
PC:
E2180@Freezer7
Notebook:
Staro 23.02.2007., 00:15   #17
strikoo
strikoo's Avatar
Postovi: 986
Kako? pa na mojoj ima temperaturni senzor.
CCC, att i everest temperature uredno očitavaju, kao i njihove promjene...
acc je meni prebučan s obzirom na vf 700cu na 5V koji sam imao na 6600gt.
Možda je nešto s mojim zbrkano, probat ću ga rastavit nekad kad mi se bude dalo...
Staro 23.02.2007., 22:56   #18
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Bem te ludog...pa to JE verzija za Vistu.
Više:
http://forums.guru3d.com/showthread.php?t=215843
Staro 23.02.2007., 23:17   #19
domy_os
domy_os's Avatar
Postovi: 18,894
Ma je malo sutra, probao sam, prvo napuca jednu jezgru proca na 100%, a onda kaže da nešt ne valja s driverima...
EDIT: Damn it, updateali su na noviju verziju, sad je na tom linku 1.3.6.1000... Ajd promijeni naslov.
Staro 23.02.2007., 23:20   #20
Jelc
Super Moderators
Postovi: 17,485
Ma je malo sutra
Čuj-tako veli čovjek koji je napravio soft, brijem da zna kaj radi.
