Datum registracije: Jun 2004
Postovi: 368
Mjenjati ili ne...
Dali mi se isplati mjenjati ovu memu iz siga za OCZ 2x512 DDR Gold El? ![]() |
Lokacija: n/a
Postovi: 6,128
imho bezveze ti je ulagat u ram osim u kakav 2x1GB kit. |
You'll Never Walk Alone
Postovi: 1,287
i ja isto mislim da se neisplati,radje idi na 2x1gb ako bas hoces...
Member of PCE 100+kg demolition squad |
Postovi: 368
Ma samo me zanima koja mema od te dvije se moze bolje OC.... |
od LemilicE
Lokacija: Veli Lošinj
Postovi: 4,712
Ovisi o čipovima koje ima...
Postovi: 1,567
Samsung TCB3/Micron (6ns rev B) and few Winbond BH-6 -->
XMS-PC3000C2 Rev2.1 (2-3-3-6-1T) --chip--> should Winbond BH-6 XMS-PC3200C2 Rev1.0 (2-3-3-6-1T) --chip--> Winbond CH-5 XMS-PC3200C2 Rev1.1/2.1 (2-3-3-6-1T) --chip--> Winbond BH-6 XMS-PC3200C2 Rev1.2/2.2 (2-3-3-6-1T) --chip--> Winbond CH-6 XMS-PC3200C2 Rev1.3 (2-2-2-5-1T) --chip--> Winbond UTT ? XMS-PC3200C2 Rev1.4 (2-2-2-5-1T) --chip--> Mosel Vitelic 5ns ~ Brainpower PCB XMS-PC3200C2 Rev1.5 (2-2-2-5-1T) --chip--> Winbond New BH-5 ~ Brainpower PCB XMS-PC3200C2 Rev1.6 (2-2-2-5-1T) --chip--> Winbond UTT ~ Brainpower PCB XMS-PC3200C2 Rev1.7 (2-2-2-5-1T) --chip--> Winbond New BH-5\UTT ~ Brainpower PCB ? XMS-PC3200C2 Rev3.1 (2-3-3-6-1T) --chip--> Infineon B-5 XMS-PC3200C2 Rev4.1 (2-3-3-6-1T) --chip--> Samsung TCCD XMS-PC3200C2 Rev4.2 (2-3-3-6-1T) --chip--> Samsung TCCD & TCC5 XMS-PC3200C2 Rev4.3 (2-3-3-6-1T) --chip--> Samsung TCCD & TCC5 (Rev. F) ~ Brainpower PCB XMS-PC3200C2 Rev5.1/6.1 (2-3-3-6-1T) --chip--> Mosel Vitelic 5ns Šta veli naljepnica na Corsairu, koja je rev. ?
XMS-PC3000C2 Rev1.1 (2-3-3-6-1T) --chip--> Samsung TCB3/Micron (6ns rev B) and few Winbond BH-6 XMS-PC3000C2 Rev2.1 (2-3-3-6-1T) --chip--> should Winbond BH-6 XMS-PC3200C2 Rev1.0 (2-3-3-6-1T) --chip--> Winbond CH-5 XMS-PC3200C2 Rev1.1/2.1 (2-3-3-6-1T) --chip--> Winbond BH-6 XMS-PC3200C2 Rev1.2/2.2 (2-3-3-6-1T) --chip--> Winbond CH-6 XMS-PC3200C2 Rev1.3 (2-2-2-5-1T) --chip--> Winbond UTT ? XMS-PC3200C2 Rev1.4 (2-2-2-5-1T) --chip--> Mosel Vitelic 5ns ~ Brainpower PCB XMS-PC3200C2 Rev1.5 (2-2-2-5-1T) --chip--> Winbond New BH-5 ~ Brainpower PCB XMS-PC3200C2 Rev1.6 (2-2-2-5-1T) --chip--> Winbond UTT ~ Brainpower PCB XMS-PC3200C2 Rev1.7 (2-2-2-5-1T) --chip--> Winbond New BH-5\UTT ~ Brainpower PCB ? XMS-PC3200C2 Rev3.1 (2-3-3-6-1T) --chip--> Infineon B-5 XMS-PC3200C2 Rev4.1 (2-3-3-6-1T) --chip--> Samsung TCCD XMS-PC3200C2 Rev4.2 (2-3-3-6-1T) --chip--> Samsung TCCD & TCC5 XMS-PC3200C2 Rev4.3 (2-3-3-6-1T) --chip--> Samsung TCCD & TCC5 (Rev. F) ~ Brainpower PCB XMS-PC3200C2 Rev5.1/6.1 (2-3-3-6-1T) --chip--> Mosel Vitelic 5ns
Postovi: 368
Pise da je rev 5.2. Dali je to ok ili...? |
Postovi: 1,567
Winbond New BH5 ~ Brainpower PCB (na OCZu bi mogli biti Winbond chipovi, ako svaki chip ima na rubu 2 metalne točke - winbondi su) -->
XMS-PC3200C2PRO Rev5.2 (2.0-3-3-6-1T) ProMOS -5 Rev A (za ovaj chip neznam kakav je)
EL DDR PC3200 Gold --chip--> Winbond New BH5 ~ Brainpower PCB (na OCZu bi mogli biti Winbond chipovi, ako svaki chip ima na rubu 2 metalne točke - winbondi su)
Postovi: 368
Hmmm....ekipa dali ima mozda jos netko taj Corsair kao moj tako da znam....dali je onaj OCZ bolji ili su i ovi moji keksici ok. |
Postovi: 1,567
Na par mjesta na netu taj Corsair ide oko 520MHz 2.5-3-3-7 @2.8v. Bilo je par stickova sa TCC5 chipovima (slično TCCDu), pa možeš probat dali ti memorija radi na DDR400 2-2-2-5 sa 2.7v. Ako radi onda imaš TCC5 chipove koji teoretski mogu potegnut oko DDR600 2.5-4-3-7 @ 2.8-2.9v. OCZ ako ima winbond chipove vjerojatno ide na DDR500 2-2-2-5 @ 3.3v. Chipove možeš prepoznat jer imaju po dvije metalne točke na rubovima http://www.hluxx.de/Images/DDR/05310005.jpg http://static.hardwareluxx.de/hardwa...winmos1280.jpg Ima chipova koji imaju takve točke ali puno manje, to onda nije winbond. Možeš još probat dali radi na DDR400 2-2-2-5 @ 2.8v, ako radi winbond je.
bycod
Lokacija: Zagreb / Dubrava
Postovi: 6,699
XMS-PC3200C2PRO Rev5.2 (2.0-3-3-6-1T) ProMOS -5 Rev A imam ih ide na 235 sa defolt voltazom nisam probao dizati voltazu vjerovatno im je max nekih 245 250.
Postovi: 1,431
ne isplati ti se ulagat u brzu memoriju na s939, radje promjeni djelitelj i teraj proc asinkrono kolko ide ako bas zelis upgrade idi na 2x1GB ili x2 procesor ![]() ps. jel zna netko kako namjestit u firefoxu 2 kako da sa alt+s saljem post, ili postoji neki drugi shortcut meni nepoznat, pm me jer ko zna kad cu ovdje ponovno zalutat |
