Staro 30.01.2007., 03:26   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Catalyst 7.1 for Windows Vista
Novo je:
Blu-ray and HD-DVD playback
Catalyst 7.1 introduces the ability to playback Blu-ray and HD DVD protected high definition content under Windows Vista 32-bit edition (support for Windows Vista 64-bit edition will be available in a future Catalys release), when used in combination with a software content player from vendors such as Cyberlink or Intervideo and an ATI Radeon X1000 series graphics accelerator (with HDCP support).
CrossFire support under Vista
Catalyst 7.1 introduces CrossFire support for the entire ATI Radeon X1000 product series under Microsoft Vista. Users will see significant performance gains in a number of applications when running in CrossFire mode under Windows Vista. (Initially available for Direct3D only, coming soon in a future Catalyst release for OpenGL)
Native OpenGL Vista support (fala ku*cu )
Catalyst 7.1 introduces native support for OpenGL, delivering a number of OpenGL application performance gains over the previously released AMD Vista RTM driver (8.31.100.3.2.1). Future Catalyst releases will include further OpenGL optimizations to further enhance performance of Vista OpenGL applications
Catalyst Install Manager for Vista
Catalyst 7.1 provides Microsoft Vista users with a new ATI Radeon graphics installer that will help users more easily update and install ATI Catalyst software. Users will also experience a significant improvement in install and un-install Verdana of ATI Catalyst software components.
New Catalyst Control Center
Catalyst 7.1 introduces a brand new version of the Catalyst Control Center for Windows Vista, which delivers a number of significant enhancements:
Significant performance gains; Catalyst Control Center start-up time has been substantially reduced, and overall responsiveness has improved.
Reduced system resource usage
New 3D preview - significantly improves the ability for users to understand the benefits of enabling the many Catalyst features of their ATI Radeon graphics accelerator
Increased stability
Native Windows Vista 32-bit and 64-bit support
Resolved Issues
This section provides information on resolved issues in this release of the ATI Catalyst Vista driver. These include:
Ghost Recon: Advance Warfighter: Intermittent Display corruption is no longer noticed within the game when setting the in game display option to high texture quality an the display resolution to 1280x1024 70Hz. Further details can be found in topic number 737-25549
The Catalyst Control Center no longer takes a longer than expected amount of time to launch under the 64 bit version of the Windows Vista operating system. Further details can be found in topic number 737-23541
Attempting to un-install the graphics driver no longer results in the Vista operating system failing to respond requiring a reboot before the driver successfully un-installs. Further details can be found in topic number 737-24463
Catalyst Control Center->Avivo Video->Deinterlacing: The Pulldown Detection option is no longer available on products that do not support the function. Further details can be found in topic number 737-24464
Connecting a CRT to a system containing an ATI Mobility product no longer results in the hot key function to toggle between the display devices not functioning properly. Further details can be found in topic number 737-24465
Setting the Vista Power Option to Balanced mode no longer results in an audio pop being heard when playing an audio file. Further details can be found in topic number 737-24466
Installing the graphics driver and rebooting the Vista operating system as required no longer results in the display resolution of 1280x800 not being available. Further details can be found in topic number 737-24468
Catalyst Control Center->Display Manager: Connecting a display device using the DVI connector no longer results in the display device failing to be recognized in the Catalyst Control Center. Further details can be found in topic number 737-24469
Disconnecting the primary display device when the Windows Vista operating system is in a standby state no longer results in the log-in screen failing to appear when resuming. Further details can be found in topic number 737-24470
Installing the graphics driver on a system containing an ATI Radeon Xpress 1100 or 1150 product no longer results in the native resolution of 1280x1024 failing to be applied. Further details can be found in topic number 737-24471
Connecting a secondary (CRT) display device to a system containing an ATI Radeon Xpress 200 series product no longer results in the inability to set the secondary display device as the primary. Further details can be found in topic number 737-24473
Enabling closed captioning when using WinDVD8 to play a DVD title no longer results in the closed captioning failing to be shown. Further details can be found in topic number 737-24474
Enabling the 3D Only option in the Catalyst Control Center no longer results in the checkbox becoming un-checked when clicking the Apply button. Further details can be found in topic number 737-24475
Enabling extended desktop and rotating either one or both of the displays no longer results in the secondary display device becoming disabled when selecting to swap the display devices within the Catalyst Control Center. Further details can be found in topic number 737-23548
The device profile is now retained when switching back and forth to various display configurations. Further details can be found in topic number 737-25504
32-bitna verzija
http://ati.amd.com/support/drivers/v...n-vista32.html
64-bitna
http://ati.amd.com/support/drivers/v...n-vista64.html
Staro 30.01.2007., 16:34   #2
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,962
Baš skidam...
Staro 30.01.2007., 16:40   #3
domy_os
domy_os's Avatar
Postovi: 18,791
Ne znam šta čekaju s WDM driverima...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 30.01.2007., 16:56   #4
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,962
Da, ne kužim u čemu je stvar...
I da, ovaj Instal Manager je prilično dobra stvar. Baš ono, za lijenčine. Kljik, kljik i gotovo
Staro 30.01.2007., 17:38   #5
pinsla
Caught Somewhere In Time
pinsla's Avatar
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
u svakom slučaju najznačajniji driveri koje je ATI predstavio u posljednje vreme
idem detaljnije isprobat
pinsla je offline   Reply With Quote
Staro 30.01.2007., 18:20   #6
Mailman
Mailman's Avatar
Postovi: 1,606
hmm... -30%?
jest da je preko 150fps-a ali ipak....
http://www.tomshardware.com/2007/01/...sta/index.html
Mailman je offline   Reply With Quote
Staro 30.01.2007., 18:34   #7
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,962
Staro 30.01.2007., 18:45   #8
Hrconja
Hrconja's Avatar
Postovi: 1,611
edit:lol kako je moguce imat bolje performanse u visti nego u winxp?
Hrconja je offline   Reply With Quote
Staro 30.01.2007., 18:57   #9
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Zanimljivi linkovi i recenzije. Čini se kako obe viste stoje uz rame XP-u kad je COD2 i Company of Heroes u pitanju! Ljepo moram priznat. Svakako dobar pomak s obzirom da je ovo novi početak.
Šta se tiče OpenGL, nađeni su neki tragovi i u drajverima za XP (7.1), nisu još u funkciji ali je JAKO moguće da ATI pritisne performanse (Nvidiu) i na tom polju! : goood :
G0RKI je offline   Reply With Quote
Staro 02.02.2007., 12:20   #10
domy_os
domy_os's Avatar
Postovi: 18,791
Da li se nekome neće pokrenut ovaj Control Center? Kliknem na njega, u procesima se pojavi CLI.exe i nakon sekundu zatvori.
Staro 02.02.2007., 12:37   #11
Jelc
Super Moderators
Postovi: 17,485
Autor domy_os Pregled postova
Valjda se kolje sa frameworkom...čuo sam da je nekima prošljakalo tek kad su imali sve sve verzije instalirane na računalu
Staro 02.02.2007., 12:51   #12
domy_os
domy_os's Avatar
Postovi: 18,791
A da sad, taman posla...
Staro 02.02.2007., 13:06   #13
Jelc
Super Moderators
Postovi: 17,485
Pa velim ti-jedan nesretnik sa rage3d se pohvalio da je tako rješio problem
