Datum registracije: Nov 2002
Postovi: 1,950
Novi Epox biosi
Gro novih biosa ![]() http://www.epox.org/main1.shtml#news...2663641,48299, Model: EP-8KRA2+ BIOS: KRA23828.BIN (A100) Date: 08/28/2003 Fixed: 1) Add to show AppleBred CPU information at screen. 2) Add "Power_On by on Board LAN" control in menu item. 3) Patch some RAMs hang at POST 29H when Load Fail-Safe Default in the BIOS Setup. 4) Enhance the function of pressing Insert key to safe boot, set memory timing by SPD. 6) Always enable VT6420 device if the CMOS checksum error. 7) Fixed install SATA driver on Windows ME, blue screen after reset. Model: EP-8RDA3+ BIOS: 8RD33827.BIN (1300) Date: 08/27/2003 Fixed: 1) Add "Auto_Precharge_Selectable" option to patch some DDR unstable issue. (i.e. A-DATA DDR400 / TwinMOS DDR 400) 2) Add support MagicScreen utility function. 3) Reduce code size for aggressive ROMSIP table. Enabled CPU Interface item. 4) Remove Reset Configuration Data item, because the BIOS doesn’t support ESCD. 5) Added to show AppleBred CPU information at screen. 6) Solved CPU warning temperature/Shutdown temperature function fail. 7) Show help message for VDD Voltage Regulator item. 8) Remove some items: -OS Select For DRAM > 64MB -Typematic Rate Setting -Typematic Rate (Chars/Sec) -Typematic Delay (Msec) Model: EP-8RDA3G BIOS: 8RD33827.BIN (1300) Date: 08/27/2003 Fixed: 1) Add "Auto_Precharge_Selectable" option to patch some DDR unstable issue. (i.e. A-DATA DDR400 / TwinMOS DDR 400) 2) Add support MagicScreen utility function. 3) Reduce code size for aggressive ROMSIP table. Enabled CPU Interface item. 4) Remove Reset Configuration Data item, because the BIOS doesn’t support ESCD. 5) Added to show AppleBred CPU information at screen. 6) Solved CPU warning temperature/Shutdown temperature function fail. 7) Show help message for VDD Voltage Regulator item. 8) Remove some items: -OS Select For DRAM > 64MB -Typematic Rate Setting -Typematic Rate (Chars/Sec) -Typematic Delay (Msec) Model: EP-8RDA BIOS: 8RD13827.BIN (4700) Date: 08/27/2003 Fixed: 1) Add "Auto_Precharge_Selectable" option to patch some DDR unstable issue. (i.e. A-DATA DDR400 / TwinMOS DDR 400) 2) Add support MagicScreen utility function. 3) Reduce code size for aggressive ROMSIP table. Enabled CPU Interface item. 4) Solved CPU warning temperature/Shutdown temperature function fail. 5) Show help message for VDD Voltage Regulator item. 6) Update awdflash.exe utility version of 8.23F to 8.24V. 7) Remove some items: -OS Select For DRAM > 64MB -Typematic Rate Setting -Typematic Rate (Chars/Sec) -Typematic Delay (Msec) Model: EP-8RDA+ BIOS: 8RDA3827.BIN (5700) Date: 08/27/2003 Fixed: 1) Add "Auto_Precharge_Selectable" option to patch some DDR unstable issue. (i.e. A-DATA DDR400 / TwinMOS DDR 400) 2) Add support MagicScreen utility function. 3) Reduce code size for aggressive ROMSIP table. Enabled CPU Interface item. 4) Solved CPU warning temperature/Shutdown temperature function fail. 5) Show help message for VDD Voltage Regulator item. 6) Update awdflash.exe utility version of 8.23F to 8.24V. 7) Remove some items: -OS Select For DRAM > 64MB -Typematic Rate Setting -Typematic Rate (Chars/Sec) -Typematic Delay (Msec) Download Preporucam da flashnete jer ovi biosi konacno nesto valjaju nakon 3609 za 8rda+ i 3625 za 8rda3+. ![]() Recimo ja sad vrtim na 227 fsb, prije 224 max stabilan.
#2 | |
Datum registracije: Jan 2002
Lokacija: ?
Postovi: 2,274
Re: Novi Epox biosi
#3 | |
Datum registracije: Sep 2002
Lokacija: kuca
Postovi: 1,567
Re: Re: Novi Epox biosi
Caught Somewhere In Time
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
Re: Novi Epox biosi
Recimo ja sad vrtim na 227 fsb, prije 224 max stabilan. [/B][/QUOTE] U jebote koji fenomenalan bajos dobio si tri fsb-a više stvarno se isplatilo flešat |
#5 | |
Postovi: 1,950
ma joj i sitno je bitno. zajebancije radi. ![]() |
#6 | |
Postovi: 1,860
Re: Re: Re: Novi Epox biosi
[/B][/QUOTE] ma u pravu si nema kaj ![]() |
