Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Sound Blaster X-Fi series Vista Driver 2.13.0001 Beta
http://downloads.guru3d.com/download.php?det=1546 This download is a driver providing Microsoft® Windows® Vista™ 64-bit and Windows Vista 32-bit support for Creative Sound Blaster® X-Fi™ series of audio devices. For more details, read the rest of this web release note. Take note of the following: THIS IS AN UNSUPPORTED BETA DRIVER. There is no technical support for this driver. We recommend that only experienced users install this driver. Do not install this driver for critical tasks. This driver is for installation with official release versions of Windows Vista only. This download supports the following audio devices only: Creative Sound Blaster X-Fi XtremeMusic, Creative Sound Blaster X-Fi XtremeGamer Creative Sound Blaster X-Fi Platinum Creative Sound Blaster X-Fi Fatal1ty Creative Sound Blaster Elite Pro Current release features: X-Fi Crystalizer™ X-Fi CMSS®-3D MIDI Playback EAX® Effects PCM stereo output through optical out Line-in connectivity Recording capabilities. Known issues: This driver does not support the following: Decoding of Dolby® Digital and DTS™ signals DVD-Audio DirectSound®-based EAX games 6.1 speaker mode. SPDIF passthrough is supported on Vista 32-bit only. Applications from the original Sound Blaster X-Fi CD will not work with this download. Requirements: Windows Vista 64-bit or Windows Vista 32-bit Creative Sound Blaster X-Fi audio devices listed above. Notes: Do not install this driver for Sound Blaster X-Fi Xtreme Audio. To install the driver, do the following: Download the SBXF_PCDVTBETA_US_2_13_0001.exe file into your local hard disk. Double-click the downloaded file. Follow the instructions on the screen. To uninstall the driver, do the following: Click Start -> All Programs -> Control Panel. Double-click the Device Manager icon. Double-click the Sound, video and game controllers option. Right-click the Creative SB X-Fi option, and select Uninstall. The Confirm Device Uninstall dialog box appears. Select the Delete the driver software for this device option. Note: This check box must be selected to avoid reinstallation issues. Click the OK button. Restart your computer. To reinstall the driver, do the following: Double-click the downloaded file. When the message You must restart your computer to apply these changes appears, click the Restart Later button. Follow the instructions on the screen.
od LemilicE
Lokacija: Veli Lošinj
Postovi: 4,712
Mislio sam ga staviti, ali mi se release notes od prijašnjeg drivera više dopao... Barem ne piše ovo: Known issues: This driver does not support the following: Decoding of Dolby® Digital and DTS™ signals DVD-Audio DirectSound®-based EAX games 6.1 speaker mode.
#4 | |
music freak
Lokacija: Sibenik
Postovi: 3,315
..da bas,pa koji im je k**** da nemogu najbitnije stvari ispraviti,pa i nek kasne s driverima bolje bi bilo nego ovako ???
od LemilicE
Postovi: 4,712
Zato i je beta...
