Staro 03.01.2007., 10:54   #1
tuna 1980
tuna 1980's Avatar
Postovi: 10
KONFIGURACIJA ZA 6000-7000KN
DRAGI MOJI FORUMAŠI ODLUČIH SE SAVJETOVATI S PRAVIM STRUČNJACIMA POPUT VAS JEL VI OTPRILIKE ZNATE SVAKI PROFIL KORISNIKA KOPOVA! DAKLE IMAM OTPRILIKE 6000 KN NA TO RAČUNAM ALI MOGAO BI NATEGNUTI 7000 KN KAO PLAN B! : wtf :
KAKO BI OPISAO ŠTO TRAŽIM OD VAS DOBRIH LJUDI OTPRILIKE SAM KORISNIK KOJI NE IGRA BAŠ PREVIŠE IGARA ALI VOLI PLJUSNUT KOJU IGRU KAD KAD (JEDNU GODIŠNJE) HTIO BI KOMP KOJI NEBI BIO SMEĆE ZA GODINU I PO A DA OPET MOGU NADOGRAĐIVATI ZNAČI NEKA SREDINA CIJENE I NOVITETA DOBAR PROCESOR I DOBRA MATIČNA SU IMPERATIV!
MOLIM VAS VAŠE PRIJEDLOGE JA I MOJ BUDUĆI KOMP BIT ĆEMO VIJEČNO ZAHVALNI!!!!!!: cheers2 : cheers2
tuna 1980 je offline   Reply With Quote
Staro 03.01.2007., 12:21   #2
aski
Je suis Schumi
aski's Avatar
Postovi: 1,524
MBO ASUS P5B Deluxe WiFi-AP, i965, DDR2, zvuk, 2xG-LAN, S-ATA, FW, PCI-E, s. 775
CPU INTEL Core 2 Duo E6300 1860MHz BOX, socket 775, 2Mb c., FSB 1066MHz, 64 bit, DualCore
RAM PC-5300, 1024MB, DDR2, KINGMAX, 667 MHz
HDD 250.0 GB SEAGATE, 7200.9, Serial ATA II, NCQ, 8MB cache, 7200 okr/min
Floppy drive 3.5'', 1,44MB, crni
Napajanje SEASONIC 380W, S12-380, Super Silent, 12cm vent., ATX2 ver 2.0
Kućište SHARKOON Rebel9 Value-Edition, MIDI, crno, bez PS
DVD±RW LG H12, 18x, crni, Dual layer, DVD+-R/RW/R9/RAM, bulk
VGA PCI-E ASUS Extreme N7600GT/2DHTV, GeForce 7600GT, 256MB DDR3, dual DVI, TV
6.883,19 - LINKS
Di sam stao?
Staro 03.01.2007., 13:34   #3
tuna 1980
tuna 1980's Avatar
Postovi: 10
MAJSTORE HVALA TI LIJEPO ALI MISLIO SAM DA U UKUPNU CIJENU UĐE I MONITOR PA AKO NALETIŠ PONOVO AKO BI MOGAO MALO DRUGAČIJU KONFIG. SLOŽIT ILI BILO KO NALETI!
JER IPAK NE ŽELIM NA MONITORU ŠTEDIT KAD BI IMAO JOŠ PAR TISUĆA KUNA RADO BI UZEO OVU KONFIGURACIJU ALI ZBOG FINANCIJA MORAM MALO UŠPARAT TJ. DOSTA UŠPARAT! ZNAČI NAJVIŠE BI DAO 2000 KN NA NEKI 19" MONITOR NAŠAO SAM JEDAN PA AKO GA MOŽE NEKO PROKOMENTIRAT "LG FLATRON L194 WT"!
HVALA UNAPRIJED!
Staro 03.01.2007., 13:42   #4
Wolverine
Wolverine's Avatar
Postovi: 12,431
A zakaj se ti dereš?
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 03.01.2007., 13:44   #5
tuna 1980
tuna 1980's Avatar
Postovi: 10
uf sori da me se bolje čuje panika mi je za komp
Staro 03.01.2007., 14:06   #6
aski
Je suis Schumi
aski's Avatar
Postovi: 1,524
Monitor 19'' LCD SAMSUNG SM 940BW, Wide, srebrno crni, 4ms, DVI, 300cd/m2, 500:1, pivot
Napajanje FORTRON 350W, FSP-60THNP, Super Silent, 12cm vent., ATX2 ver 2.0
VGA PCI-E GAINWARD Bliss 7600GT, Golden Sample, GeForce 7600GT, 256MB DDR3, 2xDVI, TV
Kućište SHARKOON Rebel9 Economy-Edition, MIDI, crno, bez PS
CPU AMD Athlon64 3000+ BOX, socket AM2, Orleans, 1800MHz, 512kb c., HTT 1000MHz
MBO ASUS M2N-E, nForce 570 Ultra MCP, DDR2, zvuk, S-ATA, G-LAN, PCI-E, s. AM2
Ukupno: 6.982,36 KN - plaćanje u gotovini (da ne bude zabune)
Nadam se da će ova konfa valjati, jedino neka se ekipa oglasi na monitor i majku, a miš, tipkovnica i zvučnici - pa to valjda imaš
Di sam stao?
Staro 04.01.2007., 12:28   #7
tuna 1980
tuna 1980's Avatar
Postovi: 10
OVAKO!!!
JEDINO KAJ JE SIGURNO JE MONITOR:
ŽLG LCD L194WT - 1911 KN
KUČIŠTE:
BILO KOJE DO 350 KN
NAPAJANJE:
CIEFTEC POWER SUPPLY 450W ATX 2.0, 2X12V - 380 KN
HARD:
BILO KOJI SATA DISK MORA IMATI 250 DO 350 KN
GRAFIČKA:
RADEON X 800GTO PCIE - 805 KN
ILI
GAINWARD BLISS 800GS, 512MB DDR3 - 833 KN
RAMI:
DO 1000KN ZA GIGU MORAJU BIT DDR2 800MHZ
PROC:
ATHLON64 X2 4200 AM2 -1376 KN
MATIČNA:
MB GIGABYTE M59SL-94, SAM 2 - 1072 KN
ILI
MB GIGABYTE M55SLI-S4, SAM 2 - 671 KN
LJUDI PRISKOČITE SA PRIJEDLOZIMA BITI ĆU VRLO ZAHVALAN
Staro 04.01.2007., 13:03   #8
jonyb
jonyb's Avatar
Datum registracije: Apr 2004
Postovi: 887
CPU Amd Athlon64 X2 3800+, Fsb 1000MHz, Socket AM2 1006 kn
MBO Gigabyte M55plus-S3G, sAM2 563,27 kn
Cooler COOLERMASTER HyperTX AMD 202,77 kn
RAM DDR2 1GB PC5300 (667MHz) Kingmax, 818 kn
HDD 250.0 GB SEAGATE, 7200.10, Serial ATA II, NCQ, 16MB cache, 643,96 kn
VGA Gigabyte GF 7600GT PCIE , 256MB 1.088,30 kn
DVD±RW NEC AD-7170A, 18x, crno 258,16 kn
Napajanje FORTRON 350W, ATX 2.0 232,79
Kučište:
Chieftec midi tower DG-01B-D-U 326,42 kn
ili
SHARKOON Rebel9 Economy-Edition 320,94 kn
Sve zajedno oko nekih 5130kn
Za kučište možeš odabrati jedno od ova dva, chieftec je nešto čvršči i robusniji,
a sharkoon prostraniji i nešto boljeg dizajna.
Navedena matična odličan izbor naspram ASUS M2N-E i DFI Infinitiy, odlično se kloka, vrlo je stabilna,
chipset se vrlo malo zagrijava tak da netreba neko dodatno hlađenje.
Hard je Seagate 10, vrlo brz, hladan i tih ali ako uzmeš Hitachija ili Samsunga nečeš pogriješiti.
Za ovakvu konfu ti netreba chieftec od 450w, fortron od 350w je uvrh glave, i sa time da je puno tiši od chiefteca.
HyperTX je odličan cooler, vrti se na nekih 300-1000 okretaja, pa je praktički nečujan a hladi odlično.
Generalno ovako posložen komp je vrlo tih, samo 2 venta (CPU i napajanje).
jonyb je offline   Reply With Quote
Staro 04.01.2007., 13:13   #9
gorluk
Čovjek
gorluk's Avatar
Postovi: 1,166
Ajde se pliz prestani derat, iritantno je.
Prvo, bolje ti je uzeti Fortron 350W ili 400W. Drugo, tvarno ti ne treba 800MHz ram, uzmi Kingmax 667Mhz i digni ga na 800MHz i imaš istu stvar za manje love. Kao što sam rekao, ako već daješ 2400-2500kn za matičnu i procesor onda ti je bolje uzeti Intel Core 2 Duo.
I ne isplatit ti se uzeti SATA disk za 250-350kn. Cijena po GB je preskupa kod takvih modela, uzmi barem Seagate Barracuda 160GB za 450kn.
gorluk je offline   Reply With Quote
Staro 04.01.2007., 13:20   #10
jonyb
jonyb's Avatar
Postovi: 887
C2D konfa:
CPU Intel E6300 Core 2 Duo - 1.86GHz, socket 775 1308,00 kn
MB Gigabyte 965P-S3, s775, i965 833,32 kn
Cooler COOLERMASTER HyperTX Intel 202,77 kn
Kučište:
ili
Ukupno oko 5700kn
Ovo ti je skuplji ali bolji izbor, pogotovo ak misliš klokati...
Ako ti netreba 250GB i jača grafa (7600GT), možeš uzeti nešto jeftinije komponente,
te umjesto fortrona 350W staviš Seasonic 380W
