Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Rivatuner Core 2 Duo Temperature Monitor Plugin
This is a handly small RivaTuner plugin to help you monitoring your Core2Duo processor temperatures. Just open the file you just downloaded with Explorer, open it and RT will install it automatically then do the following: Go to Monitoring -> Setup -> Plugins and tick C2DTemp.dll plugin. CPU temperatures (for both cores) will appear on RT's graphs after that. Opširne upute (sa sljikicama ) :http://forums.guru3d.com/showthread....36#post2078336
