Staro 19.12.2006., 20:02   #1
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Focal Chorus 726s
Kao prvo molim bez svađa kao na proslom topicu o subu...
Kao drugo molim moderatora da ne locka topic s obzirom na proslu
Kao trece ispricavam se zbog svađa na proslom topicu i obecavam da vise necu burno reagirati
a sad da krenemo...
Focal Jmlab Chorus 726s
http://images.cinenow.com/articles/2...l--736-460.jpg
Description
3-way bass reflex floor standing
Drivers
2x6-1/2" Polyglass woofer
6-1/2" Polyglass midrange
1" TNC inverted dome tweeter
Frequency response (+/- 3dB)
45Hz-28kHz
Sensibility (2,8 V/1 m)
91,5dB
Nominale impedance (EN 60065)
8 Ohms
Crossover
350Hz / 2400Hz
Power handling with musical program
150W
Dimensions (HxWxD)
1000 x 220 x 320mm
39.4x8.7x12.6inch
Weight
(44.7lbs) 20,3kg
Kao sto nekolicina zna dobio sam ponudu za 5000kn vjerovatno ide malo dolje.sad mene interesira misljenja konkretno o ovom zvucniku i ako ima usporedbi neka budu u istom cjenovnom rangu.
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
Staro 20.12.2006., 00:14   #2
syss
syss's Avatar
Postovi: 10,805
hmm... možda bi ti to uz sub bilo malo overkill.
da si ušparaš koju kunu i zemeš manje spikere iz iste serije (pošto sub već imaš), a ostatak ulupaš na kvalitetan izvor/ic/zvučnički etc.?
Staro 20.12.2006., 00:50   #3
Babaloo
In the lab...
Babaloo's Avatar
Postovi: 929
slušao ih (doduše dosta davno ali..), odlični su. ja bi ih uzeo bez razmišljanja na tvom mjestu.
** AMD FX-4300 @ 3.8 Ghz ** Asrock 990FX Deluxe 3 **16 GB G-Skill 1600Mhz ** Intel 545s 500 GB + 2xWD 1 TB ** MSI GTX 660 2GB ** DVD-RW LG H42N ** Corsair HX620 ** Logitech MX Master 2S ** Dell U2414 **SAMA Vulture
Babaloo je offline   Reply With Quote
Staro 20.12.2006., 13:29   #4
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
ma neznam ovo mi je super prilika ali opet nebih htio previse para ulupati u to..
Mozda bi uzeo 716s + 707s ali nema nigdje u ducanima..
Logitech MX500
DELL 2007FP
Abit AV8
Staro 20.12.2006., 13:31   #5
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Logitech MX500
DELL 2007FP
Abit AV8
Staro 20.12.2006., 13:33   #6
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
ma ja bih najradije uzeo 716 + 707 ali nema ih nigdje u nasim ducanima
Logitech MX500
DELL 2007FP
Abit AV8
Zadnje izmijenjeno od: micek_kc. 21.12.2006. u 19:53.
Staro 21.12.2006., 00:38   #7
newalss
Raindrops keep fallin'...
newalss's Avatar
Lokacija: Đakovo
Postovi: 826
Nisam čuo kako sviraju ali bi ipak prokomentirao...
Kada čovjek vidi da su ovi iz Jmlab-a ugurali 8 drajvera u ove škatule stvarno se s pravom može zapitati koliko su ti drajveri uopće kvalitetni?
Uvijek bi radije za iste novce uzeo par dvosistemaca s jednim mid-basom i jednim visokim. But that's just me.
Dobro kaže Syss, kad već imaš woffer nije ti sila kupovati samostojeće. Mogu proći i neki bookshelfi.
"I told my parents that when I grew up I wanted to be a musician.They said it had to be one or the other"
newalss je offline   Reply With Quote
Staro 21.12.2006., 12:28   #8
bobe
teta Mraz
Lokacija: hr
Postovi: 1,596
ne mogu ti reći ništa o tim zvučnicima iz svog iskustva, ali takvi se zvučnici ne kupuju bez probe, koja mora biti takva da se ponese svoje pojačalo i glazba te sluša koliko god treba, bar sam ja tako radio
što se tiće uzimanja bookshelf dvosistemaca ha, ja to nebi radio jer taj je sub dosta jak i ako se poželi slušat dosta glasnije, dvosistemci neće moći držat korak sa njim
Edit: vidim da te zanima i usporedba sa drugim zvučnicima, pa ti mogu reć da imam Jbl E90 koji su fenomenalni, zvuk im je genijalan, a sa tvojim Subom bi bio i još bolji jer ja imam Sony go*ance WM250
btw oko 4300kn koštaju
Zadnje izmijenjeno od: bobe. 21.12.2006. u 12:40.
bobe je offline   Reply With Quote
Staro 21.12.2006., 13:07   #9
technix
technix's Avatar
Lokacija: Svenska
Postovi: 591
na pogrešnom forumu si postavio pitanje, pokušaj ovdje:
http://www.audiofil.net/
technix je offline   Reply With Quote
Staro 21.12.2006., 19:52   #10
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Autor newalss Pregled postova
gdje ti vidis 8 drivera?
Pa u svakoj kutiji su 4... kako to uopce mozes zbrajat...
@technix
meni je draze tu pitati jer mi ta stranica bas i nije omiljena
Logitech MX500
DELL 2007FP
Abit AV8
Staro 21.12.2006., 23:37   #11
syss
syss's Avatar
Postovi: 10,805
koji ti je ostatak sistema?
Staro 22.12.2006., 04:33   #12
SeaMan
SeaMan's Avatar
Lokacija: Spalato
Postovi: 563
Poslušaj šta ti newalss kaže, čovjek zna
Bolje da u kutiji imaš 2 dobra drivera nego 4 osrednja.
S obzirom da imaš u planu potrošit pristojnu svotu na sistem, bilo bi poželjno da s njim budeš zadovoljan. Svoje zadovoljstvo sigurno nečeš ostvarit tako da kupiš zvučnike koje će izglasat ovde prisutna ekipa...
Audio sustav koji hi-fi zvuku nije sastavljane konfiguracije,pa da ti ekipa kaže na tu ploču ide taj proc i ta memorija....
Ovde su stvari malo subjektivnije. Doduše postoje kombinacije koje tradicionalno dobro zvuče, ali u finesama je razlika... Na kraju krajeva radi tih finesa se i troši toliko love
Samo ti znaš kakav zvuk preferiraš i kakvu glazbu planiraš slušat, i to je jedino mjerodavno. Prošeći malo po dučanima i nastoj "posudit" potencialne kandidate na slušanje u svojoj sobi,na svom pojačalu i kabelima slušajući glazbu koju dobro poznaješ.
Bitno je da ti se zvučnici po karakteru slažu sa amplifikacijom, i da imaš adekvatne kabele.
S obzirom da si več kupio woofer, ne bi bilo loše da uzmeš u obzir neke zvučnike svijetlog karaktera. Tako bi ja razmišljao.
Nego kakav je ostatak sistema? O kojem je pojačalu riječ?
Možda ne bi bilo loše da se raspitaš na nekom forumu koji je primjereniji po tematici.
I na kraju te moram pitat želiš li ti stvarno imat jedan sustav koji je doživljaj slušat ili ti je jedino bitno da da se radi o focalu?
Pozdrav
faster....faster.....faster..... until you reach the thrill
SeaMan je offline   Reply With Quote
Staro 22.12.2006., 20:57   #13
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Autor SeaMan Pregled postova
Pozdrav
ma koja 4 osrednja ? novi dođu skoro 8 somova kn i imaju 60mj garancije pa mislim da ti samo to govori da to nije osrednje
a ja zelim imati sustav koji je i dozivljaj za slusati i focal
pojacalo ce biti ili sony da5000es ili kenwood neki high end class tako da snage nece faliti : goood :
Logitech MX500
DELL 2007FP
Abit AV8
Staro 22.12.2006., 22:20   #14
syss
syss's Avatar
Postovi: 10,805
ajoj... iskreno, tebi je svejedno kaj buš kupio jer ti hoćeš loud show doma.
nhf naravno, samo ti kažem da si krenuo malo krivim putem sa popriličnim ulaganjima.
Staro 23.12.2006., 23:59   #15
Babaloo
In the lab...
Babaloo's Avatar
Postovi: 929
takvi zvučnici IMHO definitivno ne idu na pojačalo tipa sony ili kenwood...
Staro 24.12.2006., 01:24   #16
SeaMan
SeaMan's Avatar
Lokacija: Spalato
Postovi: 563
Naravno da se ovakvi zvučnici ne spajaju na nekakav 7 kanalni sony koji po navodima ima 170W po kanalu D:
Kupi jedne solidne zvučnike (chorus 706v ), spoji ih na pošteni dvokanalac (rotel,nad,marantz,...), uloži koju kunu u kabele i uživaj u zvuku
Staro 27.12.2006., 15:33   #17
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Autor syss Pregled postova
mislis zbog ovog sto sam napisao da snage nece faliti? ma ne samo sam htio reci da ti zvucnici nece biti opterecenje za takav receiver...sorry ako sam se krivo izrazio
Autor Babaloo Pregled postova
imam jedno pitanje...jer ti uopce znas kakav je to receiver? ako neznas raspitaj se malo pa ces cuti puno lijepih stvari,npr. s master digitalno pojacala su unutra.Također je dobilo mnoge nagrade...a ja sam to predlozio zato jer ga mogu dobiti u pola cijene tako da mi se cini dobra investicija...
ajd sad recite sto mislite na ovu kombinaciju:
prednji 726s
centralni cc700s
straznji 706s
woofer sw700s
sony str-da5000 (boja sampanjca )
za dvd player jos neznam al vjerovatno denon
napisite misljenje a ja se budem javio za par dana jer nemam trenutno net u kuci pa ne mogu stalno kod prijatelja samo zbog neta
pozdrav
Logitech MX500
DELL 2007FP
Abit AV8
Staro 27.12.2006., 22:41   #18
syss
syss's Avatar
Postovi: 10,805
ma sve je to super u domeni elektroničke/pop/rnb glazbe i glasne tutanjave.
p.s. znam da postoje kvalitetni radovi gore navedenih žanrova, ali mislim na britni spirs type muziku koja zvuči isto na šaflu u 13-ici dok ideš na posao i na rotelovim ampovima.
