Staro 04.12.2006., 19:46   #1
Juicy
Lokacija: Autocesta A1
Postovi: 251
7600GT TDH temp?
U zadnje vrijeme su mi dosta velike temperature i IDLEU, grafa nije overclokana trenutno, radi na stock 560/1400 a imam jako veliku temperaturu u IDE-u zasto?Ne kuzim? imao sam u idleu prije sa stock hladnjakom 40 stupnjeva 1-2 manje vise....?
http://i12.photobucket.com/albums/a2...e_st/asa-5.jpg
Juicy je offline   Reply With Quote
Staro 04.12.2006., 19:54   #2
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Autor Juicy Pregled postova
Driveri?
Mozda ti je i vent coolera poceo kenjat...
69C u idle-u je fakat puno.
Staro 04.12.2006., 20:19   #3
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Mozda everest zeza. Pogledaj u Control Panelu od grafe kolka je temp.
Definitivno previse za idle, tolko nije ni load...
Jos jedna stvar, ako si vadio grafu ili prckao po njoj pogledaj jel lezi hladnjak dobro, moguce da se malo pomaknuo. (na mojoj leadtekici je bio malcice labav)
Cheers : cheers2
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 04.12.2006., 20:23   #4
GLUPAN
Datum registracije: Sep 2004
Postovi: 237
Odi u control panel i otvori ''nvidia control panel'' pa vidi da li je i tamo tako visoka temperatura....
ako vec nisi probao do sada...
edit: panzer je to vec preporucio... moja greska..
jesi ga poslusao?
Nikola
GLUPAN je offline   Reply With Quote
Staro 04.12.2006., 22:22   #5
Juicy
Postovi: 251
Iste su temp svugdje, nesto mi ne stima, ni zalman nije hladio kako treba, tj bio je 60 idle...mislin ono..
Staro 04.12.2006., 22:54   #6
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Probaj par drivera drugih.
Ako nije ni to, makni cooler i ponovno ga stavi i pazi da ga dobro staviš.
Staro 09.12.2006., 16:12   #7
smoks1
smoks1's Avatar
Postovi: 343
69?!
to je malo previse...
meni Leadtek 7600GT TDH Extreme na 590/1600 radi na 42-44 stupnja sa VF700 na 5 V
smoks1 je offline   Reply With Quote
Staro 09.12.2006., 16:36   #8
Fleks
JDM
Fleks's Avatar
Postovi: 6,137
Driveri....
Staro 09.12.2006., 18:54   #9
Juicy
Postovi: 251
A koje da stavim?, trenutno su mi originalni sa CD-a stavljeni...
Staro 10.12.2006., 19:36   #10
Ph03n1x
Ph03n1x's Avatar
Lokacija: Varaždin/Zagreb
Postovi: 1,846
ufff...NE KORISTITI drivere s CD-a kad su grafe u pitanju...
ovo je zadnja WHQL verzija
http://www.nvidia.com/object/winxp_2k_93.71.html
Ph03n1x je offline   Reply With Quote
Staro 10.12.2006., 19:54   #11
Fleks
JDM
Fleks's Avatar
Postovi: 6,137
bilo koje. Te koje si dobio sa CDom ti i rade te probleme. Znam jer sam i ja probao
Staro 12.12.2006., 01:06   #12
Juicy
Postovi: 251
Problem je ipak bio u driverima, sad je idle 41, load 47-50, thx
Staro 12.12.2006., 03:10   #13
Fleks
JDM
Fleks's Avatar
Postovi: 6,137
I to smo ti rekli odma, neki cak i dvaput, a tebi je trebalo 8 dana
Staro 12.12.2006., 13:52   #14
Juicy
Postovi: 251
Nisam pratio ovo bio imo sam posla, bia sam sudac na Clanbaseu
Staro 12.12.2006., 14:23   #15
maX
maX's Avatar
Postovi: 7,326
Aj sad jos reci da znas i kako se igra CoD2? Dosta preseravanja...
Staro 12.12.2006., 15:06   #16
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Autor Fleks Pregled postova
Ja sam prvi rekao.
I tebi sam prvi rekao kad ti je bila viskoka temp
Staro 15.12.2006., 01:13   #17
hatebreeder666
hatebreeder666's Avatar
Postovi: 84
Meni je temp. u IDLE-u 49°. Svi pišu da im je oko 40 stupnjeva pa me zanima jel to ima veze s mojim napajanjem koje je dolje u sigu jer otkad sam stavio 7600GT grije se puno jače i nek neko kaže ak ima prijedlog koje da uzmem za manje novaca a da je bolje???
AMD Phenom II X4 925 (4x2.8 Ghz)
Asus M4A79XTD Evo
KINGMAX 4GB DDR3 (1600MHz)
Nvidia GeForce 9800GT
WD Caviar Black 500 GB
LG
DVDRAM GSA-H66N
Chieftec 450W
hatebreeder666 je offline   Reply With Quote
Staro 15.12.2006., 01:28   #18
Panzer
Panzer's Avatar
Postovi: 1,814
Autor hatebreeder666 Pregled postova
Meni je radila 45 idle / 65 load sa stock coolerom, sa zalmanom je na 35 idle/ 45 max load
UPGRADED...
Staro 15.12.2006., 11:32   #19
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,875
da ne otvaram novu temu ova vs ova
kolko je brža bliss gainwaard gs od obične gs,tj,kolko će se moći naklokati 1,2 ns mema u odnosu na 1,4 ns??
planiram si za novu uzeti 7600 gt,čini se to će biti zadnja investicija u sig konfu,možda izađe 8600 gt za agp.,ako ne prelazimo na pci-e konfu.
Staro 15.12.2006., 14:42   #20
Ph03n1x
Ph03n1x's Avatar
Postovi: 1,846
Autor demetrius Pregled postova
trebala bi ici nesto bolje, ali opet to ovisi i o latencijama i naponu meme...tak da je tesko tocno reci...trebala bi ici bar 100 Mhz vise
Staro 15.12.2006., 15:36   #21
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
I ja imam u idle-u 49-52C. To ti je normalna temp ako koristis stock cooler.
Staro 15.12.2006., 16:51   #22
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,875
Autor Ph03n1x Pregled postova
znači na oko 600/1700.
Staro 15.12.2006., 17:01   #23
Ph03n1x
Ph03n1x's Avatar
Postovi: 1,846
moguce...al nikad neznas...recimo na mojoj kartici 1.4ns mema ide na 1800Mhz bez problema...a imao sam i 6800GS na kojoj 1.4ns mema nije isla preko 1380Mhz
ali mislim da ce na toj gainwardici ici preko 1700Mhz...uglavnom neces fulat s njom
