Povratak   PC Ekspert Forum > Računala > Software > Web dizajn, programiranje i ostalo
Staro 02.12.2006., 16:02   #1
andjelina1
andjelina1's Avatar
Lokacija: ah...zgb
Postovi: 71
ipb forum..jel kužite ovo
ovak...ja bi vas molila da mi to malo pojasnite ak kužite
naime htjela bih backup baze foruma sa korisnicima prebaciti na drugu domenu i hosting...
i jedva sam našla neke informacije, između toga je i ovo koje mi se čini najprikladnije..ali nisam sigurna da nešto neću zaznuti,pa vas molim da mi malo to pojasnite
> create a new database and import a fairly new / working backup of your board
> complete a new install for invision power board, uploading all files as you would a fresh install, (make sure that the verision your installing is the same as the database backup that you have)
> edit conf_global.php with the database name, username and password of your backed up database, or replace the conf_global.php with your backed up, working copy of the file
> point your browser at your forums folder, you will probably be presented with an error that the board is missing skin files in cacheid_2 etc and something mentioning ipsclass
> login to ftp and navigation to cache/skin_cache/ and find what folder is already there and rename it to whatever the error you are receiving, for example: cacheid_2 to cacheid_11
> now enter cahceid_x and download all skin_ files within this folder, edit the first bit of code where it says skin_global_2, skin_board_2 etc and change it to whatever you renamed the cacheid_ folder to, e.g. cacheid_11
> enter your forums admin cp and install a new skin
> if you wish to restore all posts, topics and polls from the old board the tables you need are: ibf_polls, ibf_posts and ibf_topics
> because you have the same structure of categories and forums from your previous backup, the posts and topics etc are restore automatically into the forums you have previously
> now your board is working, upgrade the board if necesary, backup the database and backup the ftp files
andjelina1 je offline   Reply With Quote
Staro 05.12.2006., 14:32   #2
horza
ono ispred konpjuktora
horza's Avatar
Datum registracije: Apr 2003
Postovi: 3,659
okej... iiii...
u čem je problem?
instaliraš forum kao potpuno novi, napraviš import baze i promjeniš conf_global.php
i forum radi
Horza (death dwarf)
birthsign: rebel
character perks
major skills
greater powers
artifacts of choice
Staro 05.12.2006., 19:56   #3
andjelina1
andjelina1's Avatar
Lokacija: ah...zgb
Postovi: 71
ah....problem je u tome što il sam ja totalno glupa ili neznam više šta bih rekla...
ne znam GDJE da uploadiram ili napravim import baze.
imam sejvan na pc-u backup starog foruma i instaliran novi. ali u admin panelu ne mogu naći opciju gdje da taj glupi backup importam
postoji mi samo export opcija,ali ne i import
poblesavit ću s tim forumom
Staro 06.12.2006., 09:36   #4
horza
horza's Avatar
Postovi: 3,659
import se ne radi iz sučelja foruma, nego u bazu. za to je potreban neki alat (najprikladniji za ovu namjenu je phpmyadmin)
Horza (death dwarf)
birthsign: rebel
character perks
major skills
greater powers
artifacts of choice
Staro 06.12.2006., 19:54   #5
andjelina1
andjelina1's Avatar
Lokacija: ah...zgb
Postovi: 71
ajd napokon korisna informacija
a reci jel ja mogu onda sa ftp-om to napraviti ili mogu li iz cpanela to napraviti
i daj mi još molim te reci da li ima neko posebno mjesto gdje to uploadam ili samo u bazu foruma
(jer recimo kad sam mjenjala nešto u templateima na joomli, nisam mogla samo uploadati taj dio,nego sve zipati pa tek onda je prihvatio promjene i baš sam morala u template fajl...)
pa jel slično tako i sa tim backupom?
Staro 06.12.2006., 20:49   #6
horza
horza's Avatar
Postovi: 3,659
držiš backup baze na svojem kompu. odeš u cpanelu pod databases i tamo negdje nađeš phpmyadmin. u njemu idesh na import i importaš bazu. phpmyadmin ima dosta iscrpan help file i siguran sam da ćeš u njemu bez problema naći kako napraviti import.
Horza (death dwarf)
birthsign: rebel
character perks
major skills
greater powers
artifacts of choice
Staro 06.12.2006., 21:51   #7
andjelina1
andjelina1's Avatar
Lokacija: ah...zgb
Postovi: 71
e fakat ti hvala na odgovoru,nitko da mi kaže do sad ono što je bitno, a to je da ne radim upload backupa iz adminpanela nego iz cpanela
hvala puno, i eto nisam znala da iam help file : nuts :
: hello2 :
