Staro 20.11.2006., 15:57   #1
BananaSkin
od krvi i mesa
BananaSkin's Avatar
Postovi: 16
graficke-notebook
ATi x1600 256 VS NV Go7600 256MB ?
Svrha - igranje
To je moj osobni problem..
But mogli bi usporediti i ostale Notebook graficke..
Ako vec postoji takva tema, perfavor mi posaljite link.
..pozdrav iz pule..
BananaSkin je offline   Reply With Quote
Staro 20.11.2006., 17:11   #2
nino
nino's Avatar
Postovi: 12,613
PERFORMANCE GRAPHICS CARDS
ATI Mobility Radeon X1600
* Shader Model 3
* 12 Pipelines
* 128-bit Memory Bus
* Clocks: 470MHz Core, 470MHz Memory (940MHz DDR Effective)
The Mobility Radeon X1600 is one of the most desirable notebook parts on the market. It offers performance approaching last generation's top end, running many games at native, and frequently appears with a large amount of dedicated video memory. Most impressive about the X1600 is its appearance in mainstream and even 14" thin-and-light notebooks. If you're at least a semi-serious gamer, this part is easily recommended, and will play most if not all games at native with most details maxed out.
nVidia GeForce Go 7600
* Shader Model 3
* 8 Pipelines
* Clocks: 450MHz Core, 500MHz Memory (1GHz DDR Effective)
Comparable in performance to a desktop 7600GS, the Go 7600 is a little crippled next to its desktop cousin, which has a full 12 pipelines. Performance wise, it's slightly slower than the X1600 and thus not as desirable, but as I've stated before with nVidia parts, if your favorite games run off of the Doom 3 engine, this is going to be the better choice. This part is still a very strong performer, blowing away competitors in the lower classes, and can be found in the same notebook segments as the X1600. Thus, it remains easy to recommend.
Evo i link http://www.notebookreview.com/defaul...ard+Guide+2006
...pozz iz Umaga...
