Staro 14.11.2006., 21:48   #1
VoodooRain
VoodooRain's Avatar
Lokacija: Požega
Postovi: 706
Brzinski Review: Gigabyte 7900GS turboforce edition
Evo ljudi stigla nova kartica pa da malo vidite kako to radi ako je tko zainteresiran za doticnu.
Gigabyte 7900gs, 20 Pixel clock, GPU Clock: 525MHz/720 Mhz 256DDR, Infineon -1.4, Zalman VF700 fansink +igrica CALL OF JUAREZ dvd
nabrzaka sam odvrtio par igrica i ovako stvari stoje
CALL OF JUAREZ
resolution ---1024-768, 75Hz
shader model ---3.0
antialiasing ---off kada je shader na 2.0 mogu upaliti aa a inace ne naznam zasto
texture filetring ---anisotropic
shadows ---midium
shadows map size ---1024
depth of field ---on
quick bodi disappear ---off
material ql --- high
texture ql ---high
foliage ql ---high
min FPS-36
max FPS-70
prosijek FPS-50-60
CALL OF DUTY-2
1023-768 75hz
texture filter ---anisotropic
antialiasing ---4x
rendering m. p. ---directX9
sync every frame ---yes
shadows ---yes
number of dynamic lights ---high
soften smoke edges ---everything
number of corpses ---insane
texture resolution ---extra
normal map resolution ---extra
specular map resolution ---extra
min FPS-25 (tijekom 1sata nije mi palo ispod)
max FPS-95
prosijek 40-45
F.E.A.R.
1024-768x32
v sync ---on
sve namjesteno na max osim
FSAA ---2x
soft shadows ---off
anisotropic ---4x
dx8 shaders ---off
FPS minimum -34
average -55
max -75
0% -below 25 FPS
32% -between 25-400 FPS
68% -above 40 FPS
QUAKE-4
1024-768
video quality ---high quality
antialiasing ---4x
drugo sve upaljeno sto ima
koristeci Fraps konstantno mi je drzao 60-FPS
3Dmark03 -free version
1024-768
16756 3dmarks
eto toliko onako nabrzaka nesto malo vise imate o njoj na http://obengware.com/uji/gigabytegv-nx79g256dp-rh.htm testirano na konfi iz potpisa sve je na normalinim postavkama nista nije OC eto
VoodooRain je offline   Reply With Quote
Staro 15.11.2006., 00:15   #2
ComputerFreak
ComputerFreak's Avatar
Lokacija: Krizevci
Postovi: 199
E bas ju kupio prosli tjedan! Prezadovoljan!!!!
Just have a little faith.
ComputerFreak je offline   Reply With Quote
