Staro 06.11.2006., 20:33   #1
Mailman
Mailman's Avatar
Postovi: 1,606
ATI Tray Tools 1.2.6.955
[+] Added new overclocking method for X1xxx boards with Overdrive support. "Driver Level overclocking".
Near the same method first was introduced in RivaTuner and then in ATITool.
What will do this method?
1. Overclocking will be done by Catalyst itself like Overdrive
2. Voltage will be applied by driver for GPU and by ATT for memory. Only for hardware with voltage regulator
3. ATT will emulate Overdrive job, but will allow to set clocks when you want it instead of when you
run full screen 3D application.
4. This should work even if you didn't disable ATI HotKey poller! And clocks will not reset by that service in 3D games
5. With this method clocks shouldn't not resets when you play any video files (tested on my 1800XT)
6. More stable overclocking.
7. You can create full featured overclocking profiles in ATT and use them in game profiles.
8. For Video board without OverDrive support ATT will use alternative method for overclocking like used in ATI WinClk and also
in last release of RivaTuner.
But this method has some disadvantages:
1. Big steps for clock regulators. For GPU about 6Mhz and about 9Mhz for Memory.
2. Not all voltages can be applied. Try not to set voltage less than 1.1000 and voltage can not be applied if video
doesn't support voltage control.
[*] Improved Overdrive 3 support. Now ATT will calculate nearest possible clocks before applying.
[+] Added Japenese, Finnish translations
[+] Added option to include clocks in Overclocking Profile. Now you can create profile just for FAN or for Voltage control
without GPU and Memory clocks. "C" means that profile has Clocks included.[*] Updated user interface in some dialog windows.[*] Updated "New AA & AF Methods" database. Added a lot of experimental options to improve antialiasing methods
like SAAOM, EATM.
http://www.majorgeeks.com/ATI_Tray_Tools_d4569.html
Mailman je offline   Reply With Quote
Staro 06.11.2006., 22:48   #2
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Mislim da budem po običaju prvo par dana pričekao-da vidimo na kaj se sve žale nesretni korisnici :-)
Staro 06.11.2006., 23:23   #3
Mailman
Mailman's Avatar
Postovi: 1,606
Izgleda da se za r4xx usere ništa značajno nije promijenilo....malo redizajniran GUI i drukčija tray ikonica
u 2D-u nema problema, 3D nisam probao
Staro 07.11.2006., 00:05   #4
Jelc
Super Moderators
Postovi: 17,485
Nema više ATI kockice u trayu???
Staro 07.11.2006., 00:57   #5
OveRkiLL
Registered Abuser
OveRkiLL's Avatar
Postovi: 590
ne radi mi ono Show memory as DDR u Overclocku, kad na to prebacim poludi onaj slider i bilo kakva promjena frekvencije memorije mi izbaci artefakte po cijelom ekranu, niš strašno al da napomenem. možda je problem u mom kompu.
Autor Jelc Pregled postova
ne, i jadna je ova nova, bolja mi je bila "kockica"
AMD Ryzen 7700X + Noctua NH-D15
Asus X670 Prime
2x8GB Kingston Fury Beast 6000MHz CL40
XFX RX6800 16GB Qick 319
Kingston NV2 250GB + Crucial P5+ 1TB + Seagate 2TB HDD
EVGA 650W SuperNOVA GQ, 80+ Gold
Fractal Design 7 Compact
23.8" AOC 24G2SPU 165Hz
Windows 10 x64
Logitech G402
Razer Cynosa V2
OveRkiLL je offline   Reply With Quote
Staro 07.11.2006., 01:36   #6
Jelc
Super Moderators
Postovi: 17,485
Ja sam još na 940 verziji.
Bar ima kockicu u trayu
Ovo da pokazuje DDR brzine nisam valjda upalio ni jednom.
Staro 07.11.2006., 09:21   #7
Mailman
Mailman's Avatar
Postovi: 1,606
ova nova je, blago rečeno, loša....
Staro 07.11.2006., 13:33   #8
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
hhehee i ja još na 940,kockica rulez
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 08.11.2006., 14:03   #9
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
ja sam jos uvjek na 930 i nema problema, a sta radi to ne diram
jedino me zeza malo tvout, ali nije da sam se previse oko toga zezao da nastimam.
Staro 08.11.2006., 17:34   #10
Foxman
localhost
Foxman's Avatar
Postovi: 711
Stavio, maknuo i vratio 940. Ali od tad shit. Svaki puta kad upalim komp taži me file "atinav2.sys" za što služi taj file mi zašto me stalno traži. Uglavnom buraz mi ima taj file u win/system32 folderu a ja nemam pa sam mislio prekopirati ali ja imam drivere 6.10 a on neke 6.7 i nece ih mjenjat jer mu ti najbolje rade s igrama koje igra pa ne mogu uzet od njega i zato imam molbu za dobru dušu da mi pošalje na mail taj file (raran) od verzije 6.10. mail: foxman.zgMAKNI@gmail.com
Foxman je offline   Reply With Quote
Staro 08.11.2006., 17:56   #11
domy_os
domy_os's Avatar
Postovi: 18,946
Ja ni nemam taj file kod sebe, a koristim Catalyste 6.10. :confused:
EDIT: A ni Google pojma nema o njemu...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Zadnje izmijenjeno od: domy_os. 08.11.2006. u 18:15.
Staro 08.11.2006., 18:01   #12
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 894
JA imam 6.10 i novi ATT ali u system32 nemam taj file ???
i sve mi radi ok!
edit: Domy brži si za dlaku
MSI B450M pro-m2 max-ryzen 7 5800xt-nvidia 5060 ti - Asus rog swift PG278Q
damir1 je offline   Reply With Quote
Staro 08.11.2006., 18:17   #13
Foxman
localhost
Foxman's Avatar
Postovi: 711
hm zanimljivo...
Buraz mi ga ima i mene ga traži... baš cudno....
EDIT:
Da ni meni ga nema buraz u sys32. Zabrijao sam ga. Naime on ga ima u onom ATI folderu di ga instaler stavi kod instalacije kad raspakirava instalaciju.
Ovo piše na netu da je to: ATI T200 Unified AVStream Driver
Što je to?
Staro 08.11.2006., 19:04   #14
domy_os
domy_os's Avatar
Postovi: 18,946
Za VIVO, al kažem ti da kod mene nema toga iako imam uredno instaliran VIVO.
Staro 08.11.2006., 20:14   #15
Gumby
Gumby's Avatar
Datum registracije: Feb 2003
Lokacija: Velika Gorica
Postovi: 499
Autor domy_os Pregled postova
Vidis, vidis. Kad smo kod toga imam jedno pitanje...
Imam x1800XT (nema VIVO koliko je meni poznato), a kod instalacije XPi su mi nasli "novi hardver" i instalirali bas ATI T200 Unified AV Stream driver sa CDa od grafulje. Nakon instalacije hardver mi ne radi (logicno). U cemu je fora?
Doctor!!!...
Doctor!!!...
MY BRAIN HURTS...
Gumby je offline   Reply With Quote
Staro 08.11.2006., 22:53   #16
Jelc
Super Moderators
Postovi: 17,485
Ja sam našao u 6.9 atinavt2.SYS
Staro 09.11.2006., 09:37   #17
choby
Postovi: 1,178
da ne lupam negdje drugdje:
kartuša je x1300 sapphire...igranje sa clockom gpu-a ide ok, ali memorija ne želi bivati pomaknuta niti malo...dakle, slider se pomakne, ali kad zvizneš apply -> vrati na default postavku
gledao sam po svim živim opcijama, nigdje nisam našao nešto što bi željelo bit kliknuto
neka ideja?
choby je offline   Reply With Quote
Staro 09.11.2006., 12:23   #18
Jelc
Super Moderators
Postovi: 17,485
Autor choby Pregled postova
neka ideja?
Koja verzija ATT-a i koja mema je gore?
Staro 09.11.2006., 16:29   #19
choby
Postovi: 1,178
att je valjda predzadnji, ne ovaj koji se tu spominje
kaj ja znam koja je mema gore : wtf : kaj te zanima, proizvođač, brzina, količina...?
Staro 09.11.2006., 16:49   #20
Jelc
Super Moderators
Postovi: 17,485
U nekom ranijim verzijama drivera je bila uključena overclock zaštita za GDDR2.
Skini zadnji pa probaj.
