Staro 16.06.2003., 10:51   #1
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
LG 774FT 17" Flatron
Jel valja što ovaj monitor?
Picture Tube: 17 inch (16.0 inches viewable). 90 degree deflection. 0.24mm Slot pitch. W-ARAS (Wide Anti-Reflective Anti-Static) coating.
Rezolucija (max.): 1280x1024@60Hz
Sync. Input: Horizontal freq.: 30-70kHz (automatic). Vertical freq.: 50-160Hz (automatic). Input Form: Separate TTL, Positive/Negative. Signal Input: 15 pin D-Sub Connector.
Video Input: Input Form: Separate, RGB Analog, 0.7Vp-p/75ohm, positive.
Enviromental Conditions: Operating Condition: temp. 10C to 35C, humidity 10% to 90% non-Condensing. Storage Condition: temp. 0C to 60C, humidity 5% to 90% non-Condensing.
Power Input: AC 100-240V 50/60Hz 2.0A.
Dimensions (WxHxD): 42x46.6x44.3cm
Weight: 20 kg.
Staro 16.06.2003., 11:45   #2
dario-RUS
I Love AMD and nVida
dario-RUS's Avatar
Datum registracije: Feb 2003
Postovi: 410
Re: LG 774FT 17" Flatron
Weight: 20 kg.
Sve to jako lijepo zvuči, a ako se ne varam u njega je ugrađena samsumgova cijev, ali max rez. je pomalo razočaravajuća i to pri 60Hz, jako slabo
Moj ADI trinitron 17" koji sam kupio prije 3-4god max 1600x1280/75Mz, dok 1280x1024 vrti i na 90Mz, a sve ispod na 100mz!!!
Nekako mi je to preslabo za monitore koji se danas proizvode
Intel CoreDuo neki Quad I
GIGABYTE GA-P35-DS3L
4x2048 Corsair
Ati nešto
1x 36Gb WD Raptor, 2x750Gb Samsung (raid 0)
dario-RUS je offline   Reply With Quote
Staro 16.06.2003., 12:13   #3
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Re: Re: LG 774FT 17" Flatron
Da je jednom, bila bi greška pri tipkanju...
Staro 16.06.2003., 13:17   #4
dario-RUS
dario-RUS's Avatar
Postovi: 410
Re: Re: Re: LG 774FT 17" Flatron
????????????:confused: ????????????
Kakva greška?
4x2048 Corsair
Ati nešto
Staro 16.06.2003., 14:38   #5
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Re: Re: Re: Re: LG 774FT 17" Flatron
Kakva greška?
Što znači Mz? Milizerg? Mikrozlot?
Staro 16.06.2003., 14:57   #6
msvrtan
Datum registracije: Oct 2001
Postovi: 2,735
ajmo lijepo zaboraviti moj glupi komentar
moze???
Zadnje izmijenjeno od: msvrtan. 16.06.2003. u 16:54.
msvrtan je offline   Reply With Quote
Staro 16.06.2003., 15:40   #7
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Originally posted by msvrtan
MOLIM???????????????????
KOJI TO LCD IMA NA 100HZ..njemu je default 50-60Hz..misli mda ni nemogu vise...drugo
15" LCD =1024*800
17" LCD 1280*1024
i to su im najvise reze...drukcija je tehnologija izmedju tvog monitora i lcd-a..odi malo i uci o tome...
Zar je LG 774FT 17" Flatron LCD?
To je cjevni monitor.
Staro 16.06.2003., 15:40   #8
dario-RUS
dario-RUS's Avatar
Postovi: 410
Re: Re: Re: Re: Re: LG 774FT 17" Flatron
ups
4x2048 Corsair
Ati nešto
Staro 16.06.2003., 15:44   #9
dario-RUS
dario-RUS's Avatar
Postovi: 410
15" LCD =1024*800
17" LCD 1280*1024
Pa kolko ja znam to nije LCD!!!
Ali ne bum tvrdio idem provjetiri !!!
Provjereno, NIJE !!!
4x2048 Corsair
Ati nešto
Staro 16.06.2003., 15:46   #10
dario-RUS
dario-RUS's Avatar
Postovi: 410
Edit:Provjereno, NIJE !!!
Edit 2: Da nadodam kakav bi to bio LCD od 20kg
4x2048 Corsair
Ati nešto
Staro 16.06.2003., 16:52   #11
msvrtan
Postovi: 2,735
MOJA NAJDUBLJA ISPRIKA...
JA SAM SKUZIO DA JE LCD...
naime ovo je normalna rezoulcija za LCD..
nayalost dimenzije i klile nisam gledao...a niti bi po kilama znao...po dimenzijama da
dario jos jednom moja isprika
Staro 16.06.2003., 19:36   #12
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Zabrijali ste. Zabunia se čovik, pa što sad...
Mene i dalje zanima jel valja što taj monitor. Dođe oko 1750 kn i izgleda mrak. Znam da Samsung NF dođe iste pare i najvjerojatnije ču njega uzeti ali mislim da ako nije neka ogromna razlika između njih dva ovaj LG je PUNO ljepši.
Mislim, sad bu došo RAK i zavrištao uzmi SAMSUNGA
BTW, nije za mene za buraza je a on pati i malo na izgled pa ono...
Ja sam danas uzeo ono B30 kučište koje je nedavno bilo na recenziji- mrak. Ono iznutra treba stvarno vidjeti...
Staro 16.06.2003., 19:48   #13
msvrtan
Postovi: 2,735
za 1750kn NE!!
monitor iz potpisa je sad oko 1200-1400kn...pogledaj u nobilisu...a na 1280*1025 ide na 85Hz..
sto se tice dizajna ok je...
sori na offtopicu ali kaj je bilo s kucistem? zakaj si mjenjao?
Staro 17.06.2003., 10:02   #14
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
za 1750kn NE!!
Paaaaaaaaaaaaaaaaaa baš ništa, došo buraz i zapeo da ga oče, ja vidio ovo i jebiga
Staro 17.06.2003., 10:33   #15
numa
I feel devilish today ...
numa's Avatar
Postovi: 423
Gle, tor za 1800 kn dobijes samsunga 757NF sa trintron cijevi. Jedini eventualni argument zasto NE uzeti trinitron cijev je sto je dosta velika a ti nemas mjesta na stolu. AKo ga kupis, a mozrs si priustiti gubitak 50cm dubine stola, neces pozaliti kvalitetu boja i rezoluciju. Ja ga vrtim na 1280x960 na 85Hz i jos nisam vidio neki drugi monitor sa drugom cijevi koji ima tako dobru sliku...
Ja sam predlozio samsung jer ga imam i dobro ga poznajem, ali ako ti se estetski ne svidja, neces pogrijesiti da uzmes i LGov monitor, ali uzmi si model sa trinitron cijevi i specifikacijom "1600x1200@75Hz, 96kHz".
Athlon 64 X2 4400+; Gigabyte GA-M57SLI-S4 nForce 570 SLI MBO; 2x1 GB DDR800 AData; Gigabyte 8600GTS Silent; Antec P180; Tagan 380W SuperSilent; 3x120mm FAN; 3x320 GB Seagate 7200.10; Samsung 226BW 22" LCD
numa je offline   Reply With Quote
Staro 17.06.2003., 11:22   #16
dario-RUS
dario-RUS's Avatar
Postovi: 410
Thumbs up
4x2048 Corsair
Ati nešto
Staro 17.06.2003., 20:11   #17
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Ma cijelo vrijeme sam i pikirao na Samsunga i evo danas ga ubo u Linksu za 1726 kunića.... Znam da je on najbolji izbor do 2000 kn ali sam htio vidjeti što drugi kažu za ovog LG, stvarno mi je zgođušan. Uostalom nije za mene nego za buraza. Ja gledam u Fujitsua s trinitron cjevi, tek da vidiš koliki je on.... Čekam da padnu cijene onih malo boljih LCD pa onda leti i jedan na moj stolić negdje na jesen zimu.
