Staro 17.10.2006., 21:59   #1
Prince-Artas
Prince-Artas's Avatar
Postovi: 244
yahoo i gmail namještanje
kako da namjestim da vidim poštu yahoo-a i gmail-a u thunderbirdu i outlook expressu
Prince-Artas je offline   Reply With Quote
Staro 17.10.2006., 22:10   #2
trpi
Staro 18.10.2006., 00:35   #3
domy_os
domy_os's Avatar
Postovi: 18,928
Skini YPOPs! i postupi ovako:
Install and open Thunderbird.
Click Tools-> Account Settings
Click Add Account button.
Choose Email account. Click Next
Type name and email address in the boxes. Click Next
Choose POP and type 'localhost' as the incoming server.
Depending on your preferences check or uncheck Use Global Inbox
Click Next. If your username is not already there by default, add it.
Click Next. Add the way you want your Account Name to look in Thunderbird.
Click Finish.
Now scroll down to the bottom of the Account Settings pane and click on Outgoing server (SMTP).
Click on Advanced. Click on Add.
Type 127.0.0.1 as the outgoing mail server. Port default is 25.
Check Use name and password. This is Thunderbird’s way of enabling authentication.
Type your Yahoo user name as username@yahoo.com.
Click No to Use secure connection and then OK twice.
Click OK to the Server Settings window.
Now get back into Account Settings
Go back to the Server Settings of you Yahoo Account in the Account Settings pane.
Do not check Use secure connection (SSL) or Use secure authentication.
Click on Advanced.
Choose where you want your emails to go in the POP tab.
Click on the SMTP tab and click on the drop down menu and select 127.0.0.1:25
Continue modifying any of your preferences in the account and then click on OK.
The first time you try to access the account, Mozilla will ask for a password and if you want Mozilla to remember the password.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 20.10.2006., 18:44   #4
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
zar nije za gmail postojao neki plugin z aFirefox,, ja to tražim, ali baš ne nalazim...
Staro 20.10.2006., 18:57   #5
domy_os
domy_os's Avatar
Postovi: 18,928
