Staro 14.10.2006., 01:07   #1
prasak
You'll never walk alone
prasak's Avatar
Postovi: 324
Geforce 6200/6600 u agp 4x
Imama staru maticnu plocu koja podrzava agp4x i trenutno u njoj geforce2 mx400 32mb (athlon 900mhz, 512mb sdram). Htio bih si staviti neku jacu graficku pa sam bacio oko na 6200 ili 6600 128mb. Sad, zanima me koliko cu imati slabije performanse zbog toga sto imam samo agp4x? Ako 4x predstavlja usko grlo, onda nema smisla uzimati karticu koja ne bi bila u potpunosti iskoristena pa cu uzeti neku slabiju (5200?). Pokusao sam naci na internetu usporedbu performansi neke kartice kad je spojena na 8x i kad je spojena na 4x ali nisam nista pronasao. Molim pomoc
prasak je offline   Reply With Quote
Staro 14.10.2006., 02:05   #2
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Autor prasak Pregled postova
Razlika izmedu AGP 4x i AGP 8x je relativno mala. Nekih 4-5%. Usko grlo ti moze bit procesor i SD-RAM. Neznam kaj da uzmes, FX5200 nikako jer je to najvece smece ikad izaslo od nVidie. Radije neku Radeon 9550/9600. Mozda od jacih kartica ili 6600 ili Radeka 9800Pro (Ve-Mil 600kn) samo neznam kolko ce ti proc bit usko grlo.
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 20.10.2006., 20:03   #3
tamara55
tamara55's Avatar
Postovi: 97
Tu ti nije toliki problem AGP4X koliko je procesor. Jednostavno je slab, probaj nabavit jačeg, nisu skupi. Što se tiče grafičkih, 6200 je okrljaštena verzija 6600 samo s podrškom za DirectX9 i shaderima 3.0. No ona se da softmodat, tj. da otključaš mogućnosti da ju pretvoriš u slabiju verziju 6600 (no za to moraš imati sreće da dobiješ 6200 koja je proizvedena sa što manje grešaka u toku proizvodnje). Koju god da uzmeš, tvoj komp će iskorištavat 50% potencijala ovih grafičkih, a ako ne zamijeniš procesor nekim jačim, neće ni toliko. O nadogradnji grafičke nemoj uopće razmišljat dok ne nabaviš najjači mogući procesor za svoju matičnu.
tamara55 je offline   Reply With Quote
