Staro 11.10.2006., 12:17   #1
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
Creative Live 5.1 driveri
Imam Creative Labs Sound Blaster Live 5.1 Digital, Model SB0220 zvučnu karticu. Nemojte mi zamjeriti na dugačkom imenu, jer vidim da postoje iste zvučne creative različite za nijansu. Di da skinem i koje drivere za ovu zvučnu?!
Staro 11.10.2006., 12:37   #2
domy_os
domy_os's Avatar
Postovi: 18,847
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 11.10.2006., 13:32   #3
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Probaj, ali svaka ti cast ako ti driveri od creativa prorade kak spada. Imao sam istu karticu, isto model SB0220, niti jedne drivere mi nije instalirao kak spada. Srao je da nemam dobar hardware za te drivere.
Nakraju popi*dio i instalirao kX.
kX ti sigurno rade, i mislim da imaju vise mogucnosti od Creativovih, ali nemaju EAX. Nek me neko ispravi ak je netocno.
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 11.10.2006., 15:18   #4
domy_os
domy_os's Avatar
Postovi: 18,847
Ja sam uspio instalirati Creativeove drivere, al nisam nikako mogao dobit 5.1 zvuk...
Staro 11.10.2006., 15:43   #5
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Imam ja istu karticu,dat ču ti original CD.
Staro 24.04.2007., 11:13   #6
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
Zvučna počela praviti probleme, restartira mi se komp u codu s njom, drivere nekako na "pola obrisao", sad kad hoću instalirati neće, pa sam ni ja sam ne znam na koju foru uspio, uglavnom, strava softwerska podrška...
kX driveri, osim eaxa koji mi ne treba nedostaci?!
Staro 24.04.2007., 11:43   #7
Zmalamuth
Inquisitor DeathWatch
Zmalamuth's Avatar
Lokacija: Zagreb-Rijeka
Postovi: 918
http://blog.filefront.com/BadBoyforum
evo ti ISO image za sve creative zvucne, pa skini sta ti treba.
i7 4770K cooled by Noctua NH-D14
Asus Sabertooth Z87
Corsair Vengeance Pro 2x8Gb 1866Mhz
EVGA GTX 1080 - 8gb -FTW GAMING
Logitech G500 & G510 Keyboard
OCZ Vertex4 256gb/Samsung SSD 850 Evo 500G /640Gb WD Black/2TB WD Black/3x2TB WD in sharkoon docking station
LG GH22
Corsair HX620W
Corsair Carbide 678c
Arctic Bionix F140mm x3
Phillips Brilliance 240PW - 24'''
Zmalamuth je offline   Reply With Quote
Staro 25.04.2007., 09:36   #8
domy_os
domy_os's Avatar
Postovi: 18,847
Autor -POP- Pregled postova
Meni je bas bio nekako slab i neprirodan i kao da su ispuštali nekakvo krckanje...
Staro 25.04.2007., 09:57   #9
Foxman
localhost
Foxman's Avatar
Postovi: 711
ja sam bas preko tržnice uzeo jednu za frenda koja dolazi bez drivera, dakle zahebano , mislio sam samo skinut drivere i to je to... nego kako tocno znat koji je model? everest ili se vidi fizicki na njoj negdje...
Doticna je neki startiji model, ima onaj joistick port na sebi.
Foxman je offline   Reply With Quote
Staro 25.04.2007., 10:32   #10
domy_os
domy_os's Avatar
Postovi: 18,847
Piše na njoj sve...
Staro 25.04.2007., 12:51   #11
SPLiFF
SPLiFF's Avatar
Postovi: 2,076
Imam i ja Live Digital i original CD sa driverima, pa ako nekome zatreba mogu sprzit ili uploadat image
Staro 25.04.2007., 16:10   #12
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
Evo recimo da sam napravo "reinstall" od onda mi se komp ne restartira u codu2. Čudna zvučna definitivno. Kad se sjetim samo da su mi se jednom driveri obrisali sami od sebe...
Staro 25.04.2007., 20:27   #13
SPLiFF
SPLiFF's Avatar
Postovi: 2,076
Ma suxaju drajveri na veliko. Otkad sam uzeo ovaj komp slusam sve preko integruse, optickog kabla. Ne znam ni jel postoje drajveri za vistu? U biti ni ne zanima me bas previse :P
Staro 26.04.2007., 14:00   #14
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
Uglavnom, i dalje mi se COD2 restartira. Probao bih KX drivere, međutim imam problemčić... Ne mogu obrisati drivere...
Staro 27.04.2007., 08:08   #15
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
Vidim da imas XP SP2 ko i ja. Probaj genericke Windows drivere, s njima mi zasad ne radi nikakve probleme...
Staro 27.04.2007., 13:53   #16
mrga
all you need is freeware
mrga's Avatar
Lokacija: Stolica
Postovi: 897
a jel može meni netko pmoć - imao sam kx i sve je dobro radilo, onda se jednog dana dgodio BSOD i nakon toga se ko0mp uvijek zaledio nakon logiranja. nakon što sam disejblo autostartanje kx-a, sve radilo. i opet, kad god bih pokušao startati kx, komp se zaledi. reinstalacija ne pomaže. stavio sam stare drajvere od Creative-a, al zvuk je šrot kod gledanja filmova. kak složiti kx da rade?
Ovo je potpis.
mrga je offline   Reply With Quote
Staro 30.04.2007., 08:51   #17
Foxman
localhost
Foxman's Avatar
Postovi: 711
