Staro 03.10.2006., 09:58   #1
SLOW DEATH
SLOW DEATH's Avatar
Lokacija: UNDERGROUND
Postovi: 11
GODFATHER PROBLEM
nakon što sam instaliro igru po imenu Godfather(naravno legalno kupljenu)
probao sam ju pokrenuti ali nakon klikanja na godfather.exe javi mi se poruka
"This aplication has failed to start beacuse D3DX8_27.DLL was not found.reinstaling this application may fix the problem"
što da napravim ostao sam bez ideja probao sam reinstalirat igricu pa javlja istu opomenu prema ovom DX9 zaključujem da je problem u Dx-u ali imam najnoviji DX9.0c
molim pomagajte. :-)
SLOW DEATH je offline   Reply With Quote
Staro 03.10.2006., 10:20   #2
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
pokusaj instalirat DX8...
edit: potrazhi (F3) imas li uopce taj trazeni file na kompu? u google upishi tocno ime filea "D3DX8_27.DLL" i potrazhi... sam neznam sad gdje bi taj file trebao stajati...
Staro 03.10.2006., 12:17   #3
SLOW DEATH
SLOW DEATH's Avatar
Postovi: 11
gledo sam u search i nema ništa :-( već mi ide na živce lagano...: hitthewa
Staro 03.10.2006., 13:02   #4
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Probaj reinstalirat DirectX, ako vec nisi.
Neznam, gledao sam na netu, ali nisam nista pronasao za to.
Inace, ako ti je godfather dobar, probaj mafiu koja je IMO punoo bolja.
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 03.10.2006., 13:43   #5
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Da, mafija je jako dobra igra...jako!
Staro 03.10.2006., 15:08   #6
tutix
tutix's Avatar
Postovi: 4,069
Kad te pita, ako te uopće pita na kraju da li da instalira DirectX ti sam reci yes mada već imaš DirectX pa neka ga instalira, probaj to.
Staro 03.10.2006., 19:48   #7
SLOW DEATH
SLOW DEATH's Avatar
Postovi: 11
Jesam i sada kada je taj problem napokon prošo a ja se već razveselio kako ću igrat nakon uvoda me izbaci : quake2 : :-(
koma nadam se da nije do igrice... nego samo do windowsa...
