Staro 22.09.2006., 15:02   #1
Haba
AMD user
Haba's Avatar
Postovi: 165
Jel probao netko Vistu RC1??
Jel ju isprobao netko?? kakva su iskustva??
Haba je offline   Reply With Quote
Staro 22.09.2006., 15:06   #2
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Ja sam je probao, ljepo izgleda, puno problema s driverima, nemogu nac za pola stvari. +enormna zahtjevnost za normalan rad sa svim eye candy... Mislim meni ide normalno na mojoj konfi, ali netko sa dosta slabijom konfom ce imat problema...
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 22.09.2006., 19:55   #3
sick_boy
sick_boy's Avatar
Postovi: 680
Probao i još uvijek sam na njoj. Iz čiste lijenosti (ne da mi se restore-ati XP s image-a).
Lijepo, ali ne kao Xgl/Compiz kombinacija s Linux-a. Nikakva bitnija novost (nazovimo to jedan napredniji skin za XP). No, iznenađujuće stabilno za jednu RC verziju.
iBase MI980VF-4700EQ Motherboard
Intel Core I7-4700EQ (2.4-3.4Ghz, 4 cores, 8 threads)
16GB DDR3L RAM 1600 MHz
250 GB Samsung 860 Evo mSATA SSD
1TB Seagate Barracuda 7200 2.5" HDD
ATI RX550 4GB
Kolink Satellite mATX Cube Case
Delta Electronics GPS-350EB-200 A ATX 350W PSU
Acer 27" 1440p 75Hz Freesync IPS monitor
Cherry MX Board 1.0 keyboard, brown switches
LOGITECH G305 Lightspeed mouse
Arch Linux/Win 10
Lenovo Idepad 5 pro:
AMD Ryzen 7 6800HS
16GB DDR5 RAM 5600 MHz
1TB Micron nVme HDD
16" 2160x1600 16:10 IPS Display
Windows 11
Fujitsu Esprimo:
Intel(R) Core(TM)2 Duo CPU E7500
4GB DDR2 RAM
WDC WD1600AAJS-0 160GB
Seagate ST4000DM000 4TB
openmediavault 4.1.17
Philips 55PUS7373/12 55" 4K HDR VA Direct LED TV
Toshiba 50" QLED 4K Dolby Vision/Dolby Atmos TV
TCL 40ES560 40" FullHD TV
Pioneer BDP-160 BD player
Maxell SB-3000 soundbar
Onkyo TX-SV444 AV Receiver
Onkyo DX-7333 CD Player
Audio-Technica AT-LP2XGY gramofon
Mirage 290is bookshelf speakers
sick_boy je offline   Reply With Quote
Staro 22.09.2006., 23:22   #4
Haba
AMD user
Haba's Avatar
Postovi: 165
evo, ja iz zawebancije instalirao na jedan laptop i sve radi bez greske, uspio instalirati sve drivere... samo me jako zivcira sto mi firewire sad ne vidi kao net adapter.....
odnosno, vidi on firewire OHCI ali ga ne mogu koristit vise za lan.....
Staro 23.09.2006., 08:45   #5
tome_zd
tome_zd's Avatar
Postovi: 10
danas je microsoft izbacio novi build viste rc1 (5728)
upravo je skidam
evo direktni linkovi za download
32-bitna verzija
http://download.windowsvista.com/dl/...FRE_EN_DVD.iso
64-bitna verzija
tome_zd je offline   Reply With Quote
Staro 23.09.2006., 14:44   #6
BrunoZG
Junior Member
BrunoZG's Avatar
Datum registracije: May 2003
Postovi: 3,205
Ima koji setting u xgl-u da dobijes da se prozori isto vrte u 3d?
Jesi se igral s tim?
Autor sick_boy Pregled postova
AMD 3800+x2@2500, 1,375V
MB-ASROCK DUAL SATA(bios 2.2) 2+ENERMAX485W
2x512 Supertalent CL2
HDD-Hitachi 160GB, WD 800JB
ELSA 7600GT
Leadtek-2000XP expert
DVDROM-LITEON-167T ,DVDRW BENQ 1650,DVDRW NEC ND2500A@2510_fw205C
Monitor: Samsung 997MB (19')
Terratec Sky 5.1,EPSON-C42
BrunoZG je offline   Reply With Quote
Staro 24.09.2006., 13:32   #7
sick_boy
sick_boy's Avatar
Postovi: 680
Ne razumijem do kraja pitanje? Kako misliš da se vrte u 3D. Xgl je openGL akceleracija za xorg, a compiz composition manager koji koristi tu akceleraciju kako bi postigao efekte u normalnom radu sa sučeljem kao što su fade in, fade out, wobbly windows ...
Evo ti kratka demonstacija kako to izgleda: xgl/compiz
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 24.09.2006., 13:41   #8
BrunoZG
Junior Member
BrunoZG's Avatar
Postovi: 3,205
Znam kak izgleda imal sam instalirano na suse. Al sam vidio u dnevniku HTV-a kak izgleda vista, ima poslagane prozore od windowsa u 3D.
E ja se nisam puno igro sa XGL ili compiz setinzima koji god da jesu, Dobio sam transparency, pa se cjeli desktop okrene kao kocka kad povuces misa, razne efekte tipa padanja kiše.. itd.
Trenutno nemam instalirano, pa eto pitah, reko si da izgleda bolje....
ELSA 7600GT
Zadnje izmijenjeno od: BrunoZG. 08.10.2006. u 22:14.
Staro 24.09.2006., 14:27   #9
sick_boy
sick_boy's Avatar
Postovi: 680
Vista ima prozore poslagane u 3D jedino kad se switch-aš sa alt-tab. Inače, efekt "wobbly windows" mi izgleda daleko efektnije nego bilo što u Visti. I kompletan dojam mi je efektniji, a da ne pričamo o brzini - xgl/compiz radi efektno i na Intel integriranoj grafici, starom low-cost Radeon-u (9200, npr), ili nVidiji, dok Vista za Aero sučelje zahtjeva DirectX 9 kompatibilan hardware, a preporučeno je imati barem mainstream karticu.
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 08.10.2006., 22:11   #10
kaiserrex
kaiserrex's Avatar
Lokacija: TERRA INKOGNITO
Postovi: 208
Evo ja koristim VistuRC1x86 i mogu reci samo da je izrazito stabilna za predprodukcijski primjerak, svi driveri rade bez problema(barem meni),( naravno neki kao sto su VGA driveri sa smanjenom konfigurabilnoscu(Nvidia),kao i Nforce drivere generickog obiljezja,zvuk radi bez problema na realtekovom chipu...), a i odaziv prigrama je zadovoljavajuci, eye candy efekti i tranzicije izmedju dijelova sustava izgledaju poprilicno dobro,otvaranje dijelova sustava vrsi se adekvatnom brzinom, funkcionalnost je na razini no potrebito je navikavanje na sustav manipulacije rada ( nije preveliki odmak od Win XP-a ),IE7 radi zadovoljavajuce ( dovoljne je brzine i stabilnosti, s dovoljno bitnih sigurnosnih opcija da ga se moze smatrati vecim odmakom od IE6 ), WMP11 i nije neka novina vec logicna nadogradnja postojeceg za Win XP,nove igre implementirane u sustav koje koriste graficki procesor,WMC u obliku svojstvene ljuske za multimediju i manipulaciju istih ( izgleda poprilicno mocno i prelijepo no svakako ga treba vise istraziti za zadovoljavanje svih mogucnosti )...,flip 3d(win switcher) sa antialising-om... . Sigurnost je Viste na prvom mjestu kada govorimo o novom OS-u pa tako imamo integriran Firewall i Win Defender, Parental Controls...Side bar s gadgets-ima djeluje u najmanju ruku fancy a konfigurabilnost mu nije jaca strana, no niti treba biti za ono sto ga mislimo koristiti, na netu se moze pronaci odredjeni broj novih gadgets-sa sa nekim zanimljivim mogucnostima( RSS feed-er, Video feed-er,G-mail notifier,Whether...). Sve u svemu fancy i eye candy look Viste samo pridonosi +(pluseve) za "next-gen" OS, dok s druge strane barem zasada igre nisu nesto podrzane ali i programi, ovo je 32 bit-na inacica i tek se navikavam na funkcionalnost i izgled novog OS-a, nadamo se dobrom proizvodu u svojoj konacnici, a zasada ja sam zadovoljan prikazanim... btw konfig. je 3200+,1Gb DDR,7600GT,160Gb SATA te s navedenom konfig. Vista pri pocetnom skeniranju PC-a poslije instal. kaze da ce omoguciti koristenje Ultimativne verzije novog OS-a, znaci najjace verzije, sto u konacnici i koristim,pozz
Zadnje izmijenjeno od: kaiserrex. 09.10.2006. u 04:04.
kaiserrex je offline   Reply With Quote
Staro 11.10.2006., 16:15   #11
paklenik
Lokacija: vodice
Postovi: 42
ajde mi u kratkim crtma objasni instalaciju meni prve tri stavke odradi i prođe 100%,a kada restarta neće dalje.
Autor kaiserrex Pregled postova
paklenik je offline   Reply With Quote
Staro 11.10.2006., 21:22   #12
kaiserrex
kaiserrex's Avatar
Postovi: 208
Lightbulb VISTA RC1 instal....
Autor paklenik Pregled postova
Pa neznam koja je problematika vezana uz tvoj pokusaj instala. Viste RC1 no meni je bez problema izvrsena instal. iste. Ono sto ti mogu reci da sam ja svoju kopiju instalirao na zasebnu particiju pripremljenju namjenski samo za nju ( na drugoj imam instal. Win XP).Poslije bootanja DVD-a pokrece se instal. postupak gdje se dosta dugo ceka na odgovor instalacije, tada je potrebno izabrati opce postavke, cd key te nakon toga izabrati particiju ili disk a moze se ista(i) formatirati i tako pripremiti za instal., te zapocinje instal. kopiranja fajlova te restart i nakon toga se nastavlja instal.,nakon cega se ulazi u predesktop gdje se skenira komp s ciljem aktiviranja odredljene verzije Viste posto sve verzije dolaze na DVD-u, te nakon toga pristupa se desktop-u i funkcionalnosti Viste(uz obaveznu aktivaciju unutar 3 dana)-postupak traje oko 40min.. Ako sam nesto propusto neka netko drugi pomogne.
Staro 11.10.2006., 21:54   #13
kaiserrex
kaiserrex's Avatar
Postovi: 208
Lightbulb
Eto sto je izbacio dxdiag naravno pod VISTOM RC1
Staro 11.10.2006., 22:07   #14
bobe
teta Mraz
Lokacija: hr
Postovi: 1,596
evo ja je skidam, trenutno mi je na 1550mb, baš sam znatiželjan: evil :
bobe je offline   Reply With Quote
Staro 11.10.2006., 22:13   #15
Roberto
Roberto's Avatar
Postovi: 2,635
Dečki kasnite, već je i RC2 zatvoren za download na MS-u
Roberto je online   Reply With Quote
Staro 11.10.2006., 22:19   #16
paklenik
Lokacija: vodice
Postovi: 42
kod prvog restartanja pokaže se crni ekran i ono kao kod instalacije xp_ea CD... koje treperi jako dugo i dalje se ništa ne dešava, kad ponovno odem na win xp i pogledam na d: vidim da je zauzet preko 10 gb što znači da je ipak instalirao jedan dio viste, probao sam nekoliko puta i poslije restarta uvijek isto CD.... treperi dugo
Staro 11.10.2006., 22:22   #17
bobe
teta Mraz
Lokacija: hr
Postovi: 1,596
tek jućer došao adsl
Staro 13.10.2006., 15:08   #18
mlajo
mlajo's Avatar
Lokacija: Zemlja
Postovi: 156
Napravio sam čistu instalaciju na drugi HDD.
Microsoft Windows Vista RC1 Build 5600.16384 32Bit
Microsoft Office 2007 system Beta 2
Moja konfiguracija:
AMD Athlon XP-A, 1822 MHz (11 x 166) ,
Asus A7V600 SE (6 PCI, 1 AGP, 1 WiFi, 3 DDR DIMM, Audio, Gigabit LAN) , TwinMOS 1280MB DDR 400MHz PC3200 ,
ATI Radeon 9200 128MB ,Creative Audigy / Audigy 2 Audio Processor ,
WDC WD16 00JD-00GBB0 SCSI Disk Device (149 GB) ,
WDC WD20 00JS-22MHB0 SCSI Disk Device (186 GB),
Marvell Yukon 88E8001/8003/8010 PCI Gigabit Ethernet Controller .itd
Vista ne dozvoljava instalaciju nijednog Antvirusnog softwera pa ni
Norton 2007 koji je to k..... , driveri za VGA,ZVUČNA,TV CARD i sve ostalo kao da nije kompatabilno sa Vistom. A sav Hardware koji imam je prilično nov , je netko ima ovakvih problema možda su napravili novi OS pa da svi kupujemo po njemu potpuno novi stroj.Iako nisam imao vremena pokušati instalirati sav software koji mi odlično radi na XP Prof. drugi HDD ali
ako ovako ostane sa driverima i drugim softwerom koji se ne da instalirati
i u Finalnoj verziji ne bih je instalirao više ni da mi je [VISTU] BILL.G. pokloni.
Moja trenutna ocjena: tresla se brda a rodio se miš , samo puno više šminke u odnosu na XP a neznatni boljitak uz mnogo veću cijenu. Nastavljam testiranje.
Mlajo
mlajo je offline   Reply With Quote
Staro 13.10.2006., 18:02   #19
kaiserrex
kaiserrex's Avatar
Postovi: 208
Avast Home Edition 4.7 radi bez problema barem meni, Office Xp & 2003, Azeurus 2.5.0.0., CCleaner 1.33.382, Adobe 7.0 reader, Deep Burner 1.8.0.224, ICQ 5.04, Skype 2.5.0.141, Everest Home Edition, VLC Media player 0.8.5, IrfanView 3.98, DVD Shrink 3.2.0.15, LeechFTP 1.3, Mozilla Firefox 2.0 RC1, Cpuz 1.37, UltraMon 2.6, Smart FTP 2.0.999, Total Commander 6.54, MIrc 6.2, Foobar2000 0.9.4.1., F.E.A.R Combat, Undisker 1.5, ccXgui 1.41, 7zip 4.42... rade bez problema
Zadnje izmijenjeno od: kaiserrex. 23.10.2006. u 02:40.
Staro 13.10.2006., 18:32   #20
The Satara
The Satara's Avatar
Postovi: 417
Page file: 886MB used!!! : suicide
izgleda da bez minimalno 2gb nebu bilo igranja na Visti
The Satara je offline   Reply With Quote
Staro 13.10.2006., 18:45   #21
kaiserrex
kaiserrex's Avatar
Postovi: 208
Lightbulb
Autor The Satara Pregled postova
Da pokusao igrat Call of Juarez Demo, hmm igrivo na max details ali ovo je stvar drivera no slazem se 2Gb optimalno, no vidjet cemo...?!
Staro 13.10.2006., 19:19   #22
Razer
Razer's Avatar
Postovi: 11,642
Hm, ja iz nekog čudnog razloga nikako nemogu instalirati Vistu na svoj komp...nikako...neki error izbaci pri instalaciji...: stoopid
Staro 15.10.2006., 19:40   #23
paklenik
Lokacija: vodice
Postovi: 42
imali veze 32_ica i 64_orka
Staro 15.10.2006., 20:13   #24
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
tko ima RC2? 64bitnu?
nek mi se javi na PM, još ako je iz ZG, još bolje
Staro 16.10.2006., 13:26   #25
nicko
Postovi: 4,190
Sutra dobivam RC2 x64...javi se na pm, pa da se dogovorimo
nicko je offline   Reply With Quote
Staro 16.10.2006., 16:07   #26
mrtvi
mrtvi's Avatar
Postovi: 183
jel ima bar aplikaciju za masovno preimenovanje i nekakav konverter
kaj je sa registryem - jel se da kontrolirat kaj di pripada, tak da netrebam ove registry cleanere
mrtvi je offline   Reply With Quote
Staro 16.10.2006., 16:58   #27
sick_boy
sick_boy's Avatar
Postovi: 680
Ljudi, Vista je samo jedan skin za XP. Nikakvih novosti tu nema. Sve što je bilo najavljeno kao novo i revolucionarno, otkazano je.
Ja je skinuo, jer ne radi Nero (a treba mi Nero Vision), nema supporta za Lightscribe (niti službenog niti neslužbenog) i ne da mi se strepati nad svakom novim programom koji želim instalirati, hoće li raditi ili ne.
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 17.10.2006., 19:53   #28
nescuppir
nescuppir's Avatar
Lokacija: Sveta Nedelja
Postovi: 129
negde sam pročital da ak se hoćeš igrat na Visti da treba optimalno 2GB??? ljudi, ja mislim da ostajem na XP-u....
nescuppir je offline   Reply With Quote
Staro 21.10.2006., 17:25   #29
VistaMan
Postovi: 27
E jel ko zna kako na wisti RC1 instalirati ili gdje ima driver-a za MaxAdsl
modem simens A-100-I
pčiz help
VistaMan je offline   Reply With Quote
Staro 22.10.2006., 11:37   #30
VistaMan
Postovi: 27
: Drone :
KAJ NIKO NE ZNA?
