Staro 20.09.2006., 10:37   #1
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Konfiguracija do 3000 kn AMD , bez monitora i hard diska
znaci sve vam pise u naslovu...pozeljno je da je konfa iz linksa....konfa je za zensku osobu pa ne bude previse dirala/gledala unutra i nije toliko vazno kuciste, ovdje se gleda max stabilnost za ove pare...hvala unaprijed
ja sam slozio ovo:
MBO ASUS A8N-SLI SE, nForce4 SLI, DDR, zvuk 5.1, S-ATA, G-LAN, PCI-E, s. 939
CPU AMD Athlon64 3200+ BOX, socket 939, Venice, 2000MHz, 512kb c., HTT 1000MHz
RAM PC-3200, 1024MB, DDR, Corsair, KIT, Value Select, DDR 400 MHz, 2 x 512MB
VGA PCI-E SAPPHIRE ATI RADEON X550 Advantage, 128MB DDR, DVI, TV
Kućište Aplus CS-185A , MIDI, crno, bez PS
Napajanje FORTRON 350W, FSP-60THNP, Super Silent, 12cm vent., ATX2 ver 2.0
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
Staro 20.09.2006., 11:00   #2
Facelessone
Facelessone's Avatar
Postovi: 4,205
Za matičnu rađe uzmi MBO ASROCK 939Dual-VSTA 475kn koja ima uli chipset i puno je hladnija od ove asusice, netreba njoj SLI nikakav i ne misli clockat
Ostalo je ok, al di ti je hard, romovi...ili to vec ima?
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Zadnje izmijenjeno od: Facelessone. 20.09.2006. u 11:01. Razlog: dopuna
Staro 20.09.2006., 12:20   #3
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
ima hard disk i periferiju... znaci da mjenjam plocu i stavim eventualno 7600gs?
Logitech MX500
DELL 2007FP
Abit AV8
Staro 20.09.2006., 12:41   #4
Facelessone
Postovi: 4,205
pa ovisi kaj ce radit...ak se neče igrat dosta je i x550
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 20.09.2006., 13:55   #5
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
da znam al ono da se maximalno moguce pare iskoriste...jer ona bas nema para pa ono mora iskoristit svaku lipu... kuzis me ?
Logitech MX500
DELL 2007FP
Abit AV8
