Postovi: 69
evo ovako iman jedan problemcic odnosno moj frend. Isao je raditi usere na svoj komp i sebe staviti kao administratora sa sifrom naravno i naravno zaboravio je sifru heheh. e sad ja znam jednu verziju ulaska preko run u safe modu znaci upisati cmd pa net users i tak to ali je problem taj sto ja u safe modu nemogu uci ni u guest i administrator tako da je moj frend u go.....ma . Dali postoji kakav program preko boot upa sa diskete dsa srusi pass ili tako nesto cua sam da postoji ali neznam koji unaprid fala |
#2 | |
Laughing Man
Postovi: 3,041
Postovi: 69
hvala nadam se da ce upaliti hehehe |
Postovi: 194
Jeli se mozes logirat kao Administrator? Na login screenu dva puta (ili 3) stisnes Ctrl+Alt+Del i pod username(ili kako vec kaže...) upises Administrator i bubnes enter. Ako i za njega trazi pass pokusaj nesto tipa 1234, 0000, itd... Ako ni to ne upali onda se pozabavi s gore stavljenim linkom ![]() |
Contra bonos mores
Postovi: 159
#6 | |
Kernel panic
Postovi: 522
Keyboard error or no keyboard present Press F1 to continue, DEL to enter SETUP |
#9 | |
Datum registracije: May 2005
Lokacija: Online
Postovi: 2,404
Austrumi is a Linux bootable ISO image for recovering NT passwords and other cool tools and methods, sized for Business Card size CD media (50Mb). It allows you to change any password, including that of the Administrator, on a partition occupied by Windows NT, Windows 2000 or Windows XP. Simply boot the CD and when you get to the initial boot prompt, type: boot: nt_pass This will launch a console utility that will detect Windows partitions on the hard disk and provide you with a menu to modify any user or Administrator passwords on the Windows system. It will even give access to the Windows registry for recovery purposes. Quite a handy utility to keep in your wallet (AUSTRUMI is small enough to fit on a business card-size CD) if you are unfortunate enough to having to deal with Windows machines in your line of work. http://sourceforge.net/projects/austrumi |
Postovi: 2,105
Lokacija: Online
Postovi: 2,404
Mali ispravak, sa verzijom austrumi-1.2.0 nt_pass ne radi nego treba koristit verziju austrumi-0.9.2 Evo tu piše malo više o tome http://sourceforge.net/forum/forum.p...orum_id=355015 |
Postovi: 2,105
heh a ja vec skinuo. hvala svejedno na ispravku p.s. bilo bi dobro za ovakve stvari imati posebno mjesto na sajtu ili na forumu. tako da se stvara lagana baza korisnih stvari... |
