Staro 10.09.2006., 10:25   #1
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
turion 64 x2 TL-60
Evo odgovora na Conroa, malo prelistajte testove. Fakat je bolji, ali naravno nisu usporedili najjači Core Duo za laptope
http://www.tomshardware.com/2006/08/...ed/page16.html
At first glance, it seems as though the MSI S271 with the Turion 64 X2 processor is up to 8 percent faster than the Asus W5F equipped with the Core Duo T2400 CPU. However, if you consider that the CPU clock rate of the Turion 64 X2 TL-60 is almost 10 percent higher than that of the Core Duo T2400 in the Asus W5F, you will notice that the system performance of the Intel system is, on average, approximately 7 percent higher at the same clock rate.
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 10.09.2006., 11:16   #2
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
Ne kuzim... i dalje je Core Duo brzi clok-per-clock.... iako Core Duo NIJE Core 2 Duo, dakle to je ranija revizija nove Core arhitekture, ne onaj razvikani Conroe za desktop.
Jedino sto je vidljivo je to da je AMD napravio pomak u brzini procesora... no meni to nije nista cudno, pa imali su vremena raditi na poboljsanju K8 arhitekture, nisu oni spavali dok je Intel forsirao NetBurst. Samo nisu imali razloga plasirati nesto brze i bolje na trziste...
Kako god okrenes, nece AMD propasti.
Staro 10.09.2006., 11:25   #3
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
To su oba dva procesora za laptope. Na stolna računala se ne stavljaju isti procesori kao u laptope
Ryzen 7 2700X
2x 8gb Crucial
B450 Aurus Elite
GTX 1060
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
Harman Kardon
MX revolution
Battery grip
Sony: 18-70, 55-200
Staro 10.09.2006., 11:44   #4
sick_boy
sick_boy's Avatar
Postovi: 680
Istina, ali tvoj inicijalni post je bio "odgovor na Conroe", a Core Duo, s kojim se uspoređuje, nije Conroe.
iBase MI980VF-4700EQ Motherboard
Intel Core I7-4700EQ (2.4-3.4Ghz, 4 cores, 8 threads)
16GB DDR3L RAM 1600 MHz
250 GB Samsung 860 Evo mSATA SSD
1TB Seagate Barracuda 7200 2.5" HDD
ATI RX550 4GB
Kolink Satellite mATX Cube Case
Delta Electronics GPS-350EB-200 A ATX 350W PSU
Acer 27" 1440p 75Hz Freesync IPS monitor
Cherry MX Board 1.0 keyboard, brown switches
LOGITECH G305 Lightspeed mouse
Arch Linux/Win 10
Lenovo Idepad 5 pro:
AMD Ryzen 7 6800HS
16GB DDR5 RAM 5600 MHz
1TB Micron nVme HDD
16" 2160x1600 16:10 IPS Display
Windows 11
Fujitsu Esprimo:
Intel(R) Core(TM)2 Duo CPU E7500
4GB DDR2 RAM
WDC WD1600AAJS-0 160GB
Seagate ST4000DM000 4TB
openmediavault 4.1.17
Philips 55PUS7373/12 55" 4K HDR VA Direct LED TV
Toshiba 50" QLED 4K Dolby Vision/Dolby Atmos TV
TCL 40ES560 40" FullHD TV
Pioneer BDP-160 BD player
Maxell SB-3000 soundbar
Onkyo TX-SV444 AV Receiver
Onkyo DX-7333 CD Player
Audio-Technica AT-LP2XGY gramofon
Mirage 290is bookshelf speakers
sick_boy je offline   Reply With Quote
Staro 10.09.2006., 12:32   #5
nicko
Postovi: 4,190
A sad dolazi Merom iliti Conroe za laptope
Tako da....
nicko je offline   Reply With Quote
